- News
New research has prompted an important question: Do all the benefits of in-house 3D printing come at the cost of indoor air quality?
So what are the factors?
1. Your room's dimensional volume
2. Your room's air exchange rate
3. How many 3D printers you are using at the same time
4. What material(s) you're 3D printing
5. How long you're 3D printing for
Your print job's duration will cause the emission of different levels of UFPs and VOCs.
6. Whether there are other emission sources in the room
Photocopiers
Laser printers
Vacuum cleaners
Cleaning agents
Computers
Citrus fruit peel
And many more...
Conclusion: 3D print indoors with more confidence
However, if you want to have more flexibility in your 3D printing setup – 3D printing with more printers or a wider range of materials – the Ultimaker S5 Air Manager as part of the Ultimaker S5 Pro Bundle is now available.
This top enclosure integrates with the Ultimaker S5 to provide a fully validated air filtration solution. It includes a multi-speed fan and EPA filter that removes up to 95% of UFPs – a percentage that's based on data rather than guesswork.
- News
- Applications
- News
- News
- Trends
- News
- News
- News
- News
- Applications
- News
- News
- News
- News
- News
- Applications
- News
- Applications
- Trends
- News
- Applications
- Trends
- News
- Trends
- News
- Applications
- News
- News
- News
- News
- News
- News
- Applications
- News
- Trends
- Applications
