Code your 3D designs with Tinkercad’s new Codeblocks app
  • Informal learning
  • Technology
Tinkercad released Codeblocks last June, and now that it's out of beta, Pioneer Pioneer Rob Morrill tells us how he uses it at St. Matthew's Episcopal Day School.
Tinkercad has brought coding to its 3D modeling platform with the introduction of the web app Codeblocks. Rather than drawing the design, as one might in a turtle art graphics environment, this is object-oriented programming, meaning that you place a predefined object on the workplane and then modify it. The basket in the example below consists of a six-sided torus shape that is repeatedly rotated up and around 27 times to form a circle.
01 codeblocks design
02 codeblocks project example 03
In traditional Tinkercad, you build models by dragging basic shapes like a box, cone, or wedge onto the workplane. Codeblocks is similar, but rather than dragging a shape out to the workplane and then resizing it, you drag a block of code for an object whose parameters you can adjust.
03 solid 01
Note that the shape loads on the workplane at X, Y, Z coordinates 0, 0, 0. This means that half of a 20 x 20 x 20 millimeter cube will be underneath the workplane. Red, green, and blue lines delineate X, Y, and Z respectively. Following the Add Box block with a purple Move block with a value of 10 for the Z axis will raise the cube to sit on the workplane.
04 solids 02
Here, a box and a sphere have been added and raised in the Z axis, while the cone was not only raised and rotated 180 degrees, but also turned into a hole.
05 adding solids
Adding a Create Group block groups these three shapes together.
06 adding solids 01
The power of Codeblocks becomes apparent the more you take advantage of coding aspects like loops and variables to control and iterate your designs. Here is a simple loop that uses a variable to rotate rings around 0, 0, 0.
07 rotation
This laser-cut cardboard disk helps students understand the polar and Cartesian movements in the Codeblocks environment.
Add a torus shape to 0, 0, 0.
08 quadrants 03
Move the torus in a positive Y direction.
09 quadrants 06
Rotate the torus around 0, 0, 0.
10 quadrants
Add, move, and rotate a second torus.
11 quadrants 02
Add, move, and rotate a third torus.
12 quadrants 05
Repeat 8 times.
13 quadrants 04
This basket is made up of hearts that have been duplicated and rotated.
14 codeblocks and tinkercad 02
The export button allows you to export as STL or OBJ files for 3D printing, but you can also export the design as a “Part”.
15 export
When you save a Part, the design becomes available back in traditional Tinkercad, where you can resize it and add it to other creations.
16 create a part
The red elements of this design have been added to the original blue Codeblocks design using traditional Tinkercad.
17 codeblocks and tinkercad 01
From traditional Tinkercad, you can also export the design in SVG format, which then allows you to paper or laser cut it.
18 products 03
These earrings were designed in Codeblocks and then laser cut.
19 products 01
The sides of this lamp were designed using a combination of traditional Tinkercad and Codeblocks.
20 products 02
This sign uses a combination of traditional Tinkercad and Codeblocks.
21 codeblocks and tinkercad 03
This clock’s face was designed in Codeblocks and laser cut.
22 products 04
For a good introduction to generative design, see “Some Thoughts on Generative Art” by Anders Hoff, and watch Kate Compton’s presentation “Generative Art (and Games and More)” from JSConf Iceland.
JSConf Iceland 2018
Codeblocks also makes it easy to experiment with generative design. The building heights in this cityscape and the ridges in this Martian crater were randomly generated.
23 parametric 01
24 codeblocks project example 02
25 codeblocks project example 01
Another great feature of Codeblocks for teachers and learners is the ease with which you can comment on your code. This helps students make their thinking visible, which aids both in their own metacognition as well as in allowing teachers to gain insight into their understanding.
26 blocks
Access Codeblocks either by going to traditional Tinkercad and finding the link, or by going straight to: https://www.tinkercad.com/codeblocks
27 codeblocks
Codeblocks’ opening page contains starter projects that let you see how a variety of blocks can be used in different ways.
28 starters
Here is a quick video on a “Codeblocks Intro”:
codeblocks
And here is a longer tutorial: “Getting Going with Codeblocks”:
codeblocks-1
Explore, have fun, and share your designs.
Read more education blogs
  • College of the Desert 3D printing club
    Testing Quadcopter
    Ultimaker Met
  • Smithsonian Learning Lab
    Harvard calculus courses use 3D printed models to engage students
    Mathematica Tea Light Holder
  • Code your 3D designs with Tinkercad’s new Codeblocks app
    Tinkercad released Codeblocks last June, and now that it's out of Beta, Pioneer Rob Morrill tells us how he uses it.
    printingUltibot
    Modifying an STL with Tinkercad
    When Ultimaker Pioneer Alex Larson contacted me about the Ultibot-D project, I was super excited. As a teacher and parent, I am a huge cheerleader for risk. I printed the base models at ⅕ scale and gave it to my students to explore
    Ultimaker at Camp
    Math Camp: Having fun doing stuff
    Pioneer Dr Toni Szymanski writes about summer fun at camp with 4th and 5th graders, math, and 3D printing.
  • 3D printing for glass
    GlitchCraft
    Guest blogger Astrida Valigorsky writes about combining the old and the new at Timothy Belliveau's GlitchCraft class where students combined 3D printing and glass blowing.
    basecampProject
    Using Basecamp to manage your classroom/makerspace projects and print queue
    Pioneer Andrew Woodbridge uses Basecamp to organize his students' projects, and he explains how you can too.
    3D printing in math and chemistry
    A unique 3D printing collaboration between mathematics and chemistry faculty
    Passing it on. After integrating 3D printing into her own math courses, Kristen Schreck helps spread 3D printing across disciplines at Saint Xavier University.
  • World monument project
    Living world monuments assignment
    Pioneer Joanne Barrett shares about a middle school project that combines 3D printing, Augmented Reality, History, and Art.
    parts in cura (1)
    My reintroduction to Netfabb
    A recent NetFabb workshop convinced the writer that they can't live without this application. See why it's time to take another look at Netfabb.
    hero wrenchs
    Wrench Engineering
  • goblet project
    Pioneer Chris Hanusa shares one way he integrated 3D printing into his Integral Calculus class
    Finland’s mobile libraries
    3D printers in the public library: Finland ahead of the curve
    US Professor Joshua Pearce, sponsored by Fulbright Finland for Research, shares his first impressions of Finnish libraries.
    Happiness
    Lessons in letting go - releasing student energy speeds creation and use of our art and innovation lab
    Pioneer John Nordell enlisted his students to put the Art and Innovation Lab together. The result was one of the best experiences he has had as an educator.
  • toni teaching fusion
    Teacher training for 3D printing
    Pioneer Dr. Toni Szymanski thought that 3D printing could engage students in math classes. To test this out, she had to learn all about 3D printing first.
    ceramic stamps
    Digital fabrication informs ceramics decorative process
    Pioneer Young Kim blends his classical arts background with digital fabrication to create a ceramic project that incorporates 3D printing.
    buckeyball
    Modeling rocks at iCREATE
    iCREATE's Tiffany Huang shared an iCREATE success story about Jackie Zheng.
  • Empathy map
    Elementary-College Engineering Design partnership
    Pioneer Matthew Wigdahl writes about how his fifth graders and local undergraduate engineering students learn from each other.
    014-SchoolHero
    Introducing Ultimaker’s Core Lessons Set for STEAM Educators
    Designed by the Ultimaker North America Community Team, our new Core Lessons: STEAM Set is a resource for educators who need inspiration and ideas when they bring 3D printing into their classrooms.
    MakerGirl
    Empower one MakerGirl, empower the world
    how the group traveled 10,000 miles around the country to help bring 3D printing workshops to over 1,000 young girls. In this week's post we catch up with the organization that is still working to create a new generation of confident, creative women leade
  • Georgia Connections Academy
    Building a mobile maker space: part 2—up and rolling
    So what exactly does a Mobile MakerSpace look like? That's the question I had to ask myself once I began the project of bringing 3D printing technology to virtual students. When we started this project, we knew we needed something that would be easy to
    Building a mobile makerspace: part 1— getting started
    Pioneer Wendy Aracich is putting together and implementing a mobile MakerSpace for her virtual school of 4000 students spread across the state of Georgia.
    LibraryLyna
    Tactile Problem/Solution Bank Community Project
    3D modeling and printing should be accessible of every educator so that they may offer their students tactile means to understand spatial concepts.
  • Design Engine Box
    Design Engine community project
    We want to challenge educators and students to help evolve the Design Engine game. We want to see how you're using or modifying the game with your students, and we want to incorporate your ideas into the next edition.
    coca cola upcycle
    Upcycling community project
    Upcycling challenges students and educators to use their creativity and 3D printing skills to breathe new life into a few familiar objects.
    pecha-kuchas
    Construct3D to Kamehameha Ed Tech Conference
    Last year Pioneer Greg Kent traveled from Hawaii to North Carolina to attend Construct3D 2017. We thought we'd share his reflections with you now since we recently announced Construct3D 2018
  • Plastic Ocean by Kevin Krejci
    Ocean Plastic Community Project
    The Ultimaker Community Team will be launching a series of interdisciplinary projects over the next few months that challenge students to research, explore, design, and 3D print. Ocean Plastic is the first project of this series.
    fractal2
    3D printed fractals at JMU 3SPACE
    Pioneer Professor Laura Taalman, (a.k.a. mathgrrl), reviews a multi-week study of fractals by general education math students in the JMU 3D printing classroom.
    Drone1
    Using drones and 3D printing to develop design thinking during a summer robotics camp
    Pioneer Yuriy Drubinskiy writes about his experience leading a summer program and how creating drones with 3D printing brings form, structure, and design together.
  • The Starter Pack launch event at Digital Harbor Foundation
    Introducing the Ultimaker Design Engine Starter Pack
    Presenting the Ultimaker Design Engine Starter Pack: a game created to provoke, inspire, and entertain students, educators, 3D designers, artists, and engineers of all experience levels!
    first puzzle cube and package to be made on a 3D printer entirely out of PLA
    Davidson Desktop Doohickeys: Puzzle cubes
    Pioneer Adam Davidson writes about a project in his curriculum that is a rite of passage for his high school's engineering program students. He explains at how it started and what caused it to change
    soft robot mold
    3D printing with UMaine Bioengineering students
