Ultimaker-Original-Detail-3
Three reasons for open source tech in your 3D printing classroom
UniversityTechnology
Pioneer Joshua Pearce explains why educators (and everyone else) should always consider using free and open source options in and out of the classroom.
Joshua M. Pearce
Department of Materials Science & Engineering
Department of Electrical & Computer Engineering
Michigan Technological University
Although educators should always consider the use of free and open source software (FOSS) for education, the preponderance of evidence shows that in the area of 3D printing/additive manufacturing the case for FOSS is clear. Three reasons you should only use an open source toolchain in the classroom to teach 3D printing include:
1. History: Open source is the only reason you have a 3D printing class at all
3D printing is actually a pretty old technology. It goes all the way back to the 1980’s. Unfortunately, it was locked away with intellectual property for 20 years with only a few lucky well-funded people able to access it (in the old days the only available 3D printers cost hundreds of thousands of dollars). That all changed with the open sourcing of the  RepRap (self replicating rapid prototyper) 3D printer after the overly-broad patent on all fused filament printing expired. The RepRap project’s goal was to make a 3D printer that could print itself.
RepRap is an open source hardware project licensed under an open source license, which means that over the last decade or so, hundreds of innovators all over the world have been improving RepRap technology: both hardware and software. The open sourcing of the RepRap has led to dozens of 3D printer companies including Ultimaker (see source files) that used the RepRap designs as a foundation to jump-start their own products. As you know, now there are many affordable high-quality 3D printers that make excellent educational tools at every academic level. To remain consistent with the spirit of that development and to avoid unethical coercion and forced dependency of your students on proprietary software, you should utilize an open source toolchain.
Pc-va
Adrian Bowyer (left) and Vik Olliver (right) with a parent RepRap machine, made on a conventional rapid prototyper, and the first complete working child RepRap machine, made by the RepRap on the left. The child machine made its first successful grandchild part at 14:00 hours UTC on 29 May 2008 at Bath University in the UK, a few minutes after it was assembled. (https://reprap.org/wiki/About)
ultimaker original
Ultimaker Original open source 3D printer
2. Cost: $0
It is not only the hardware in 3D printing that can be free, but also the software. The “free” in FOSS refers to software that respects your freedom. Thus it means that the users have the freedom to run, copy, distribute, study, change, and improve the software. In the context of 3D printing software it also means that because you have access to the source code and the freedom to use it, the software is free - i.e. cost of $0. This has an obvious benefit as it reduces the cost of your 3D printing program at your school. However, the benefits also extend to your students. They can download the software for free at home, so they can practice or work on their projects at home without purchasing expensive licenses. The benefits extend into the future as well. After your students graduate from your school, they will be able to freely open and edit their own work and build upon it. This is not true of most proprietary packages. They may get educational discounts now (or even freeware), however, when they graduate this is rarely true.
free
For example, 3D printing design normally begins with CAD (computer aided design). A typical proprietary CAD package like Autodesk’s Autocad costs $1,400 per year! At Michigan Tech for our award winning 3D printing class we use three FOSS CAD packages. First, we use OpenSCAD, which is a script based CAD package for students that are already familiar with computer coding and because it is extremely powerful at parametric designs. For students more familiar with conventional CAD packages, there is FreeCAD. Finally, for students with more of an artistic bent, there is a free 3D modeling program called Blender, which was originally meant to help make 3D movies, but also makes for an aesthetically pleasing 3D printing design tool.
With all of these FOSS CAD packages it will make it easy for you and your students to share designs on websites like YouMagine. Then rather than others only be able to customize the STL files with significant effort, they will also be able to use your source files with free software to improve upon the design. This creates a technological evolution, which can pay dividends to your students for sharing their designs.
openscad
Example of OpenSCAD for 3D printing.
blender
Example of FreeCAD for 3D printing.
blender
Example of Blender for 3D printing.
Next you need a slicer to break your 3D model into 2D slices of toolpaths for your print head. There are several excellent FOSS options available including Slic3r and Cura. Next you need a print controller if you do not use the built in version in Cura such as Printrun or Franklin. It is absolutely possible to completely run a 3D printer from start to finish using only FOSS.
3. Control: You are never held hostage
If you use FOSS and FOSH you always have control over your 3D printing tools. With access to the code you always have the ability to continue to work with the software. If you are reliant on commercial proprietary software you are beholden to the companies that own it. This means you could literally lose control of your own 3D printer if you go the closed-source route.
Your 3D printers could be held for ransom or simply cease functionality completely if  proprietary vendors no longer offer support for their products due to a litany of reasons including:
  • loss of key technical staff,
  • planned obsolescence of equipment to sell new models (or software)
  • ends a product line,
  • stopped supporting software to run their old hardware as operating systems change with time,
  • they have canceled making specific products or components, or
  • in the worst case, simply gone out of business.
In addition, if your 3D printing vendor is bought by another company that changes policy or price, with a proprietary technology you have no control. With FOSS and FOSH your equipment can never be held ransom. You truly own it - which means you can fix it (or pay someone else to), improve it, upgrade it, and use it indefinitely. Best of all, so can your students  - so what they learn in your classroom they can take when they graduate. You and your students only have this kind of control with free and open source technology.
Read more education blogs
    • Naturalis Biodiversity Center: Prehistoric prints, cutting-edge technology
      Naturalis Biodiversity Center, the Netherlands’ national natural history museum, is using 3D printing to create both partial and full dinosaur skeletons for public display.
      • History
      • Informal learning
    • Ultimaker Met
      • Secondary education
      • History
    • College of the Desert 3D printing club
      • Special education
      • Technology
    • Testing Quadcopter
      • Informal learning
      • Technology
    • Smithsonian Learning Lab
      • Informal learning
      • Art
    • Harvard calculus courses use 3D printed models to engage students
      • University
      • Mathematics
    • Code your 3D designs with Tinkercad’s new Codeblocks app
      Tinkercad released Codeblocks last June, and now that it's out of Beta, Pioneer Rob Morrill tells us how he uses it.
      • Informal learning
      • Technology
    • Mathematica Tea Light Holder
      • Informal learning
      • Mathematics
    • printingUltibot
      Modifying an STL with Tinkercad
      When Ultimaker Pioneer Alex Larson contacted me about the Ultibot-D project, I was super excited. As a teacher and parent, I am a huge cheerleader for risk. I printed the base models at ⅕ scale and gave it to my students to explore
      • Primary education
      • Technology
    • Ultimaker at Camp
      Math Camp: Having fun doing stuff
      Pioneer Dr Toni Szymanski writes about summer fun at camp with 4th and 5th graders, math, and 3D printing.
      • Primary education
      • Mathematics
    • 3D printing for glass
      GlitchCraft
      Guest blogger Astrida Valigorsky writes about combining the old and the new at Timothy Belliveau's GlitchCraft class where students combined 3D printing and glass blowing.
      • Informal learning
      • Technology
    • 3D printing in math and chemistry
      A unique 3D printing collaboration between mathematics and chemistry faculty
      Passing it on. After integrating 3D printing into her own math courses, Kristen Schreck helps spread 3D printing across disciplines at Saint Xavier University.
      • University
      • Science
    • basecampProject
      Using Basecamp to manage your classroom/makerspace projects and print queue
      Pioneer Andrew Woodbridge uses Basecamp to organize his students' projects, and he explains how you can too.
      • Technology
    • World monument project
      Living world monuments assignment
      Pioneer Joanne Barrett shares about a middle school project that combines 3D printing, Augmented Reality, History, and Art.
      • History
    • toni teaching fusion
      Teacher training for 3D printing
      Pioneer Dr. Toni Szymanski thought that 3D printing could engage students in math classes. To test this out, she had to learn all about 3D printing first.
      • Mathematics
    • Finland’s mobile libraries
      3D printers in the public library: Finland ahead of the curve
      US Professor Joshua Pearce, sponsored by Fulbright Finland for Research, shares his first impressions of Finnish libraries.
      • Informal learning
      • Technology
    • parts in cura (1)
      My reintroduction to Netfabb
      A recent NetFabb workshop convinced the writer that they can't live without this application. See why it's time to take another look at Netfabb.
      • Technology
    • buckeyball
      Modeling rocks at iCREATE
      iCREATE's Tiffany Huang shared an iCREATE success story about Jackie Zheng.
      • Science
    • goblet project
      Pioneer Chris Hanusa shares one way he integrated 3D printing into his Integral Calculus class
      • University
      • Mathematics
    • Happiness
      Lessons in letting go - releasing student energy speeds creation and use of our art and innovation lab
      Pioneer John Nordell enlisted his students to put the Art and Innovation Lab together. The result was one of the best experiences he has had as an educator.
      • University
      • Technology
    • hero wrenchs
      Wrench Engineering
      • Primary education
      • Engineering
    • ceramic stamps
      Digital fabrication informs ceramics decorative process
      Pioneer Young Kim blends his classical arts background with digital fabrication to create a ceramic project that incorporates 3D printing.
      • Art
    • Empathy map
      Elementary-College Engineering Design partnership
      Pioneer Matthew Wigdahl writes about how his fifth graders and local undergraduate engineering students learn from each other.
      • Primary education
      • Engineering
    • 014-SchoolHero
      Introducing Ultimaker’s Core Lessons Set for STEAM Educators
      Designed by the Ultimaker North America Community Team, our new Core Lessons: STEAM Set is a resource for educators who need inspiration and ideas when they bring 3D printing into their classrooms.
      • Primary education
      • Technology
    • MakerGirl
      Empower one MakerGirl, empower the world
      how the group traveled 10,000 miles around the country to help bring 3D printing workshops to over 1,000 young girls. In this week's post we catch up with the organization that is still working to create a new generation of confident, creative women leade
      • Primary education
      • Technology
    • Georgia Connections Academy
      Building a mobile maker space: part 2—up and rolling
      So what exactly does a Mobile MakerSpace look like? That's the question I had to ask myself once I began the project of bringing 3D printing technology to virtual students. When we started this project, we knew we needed something that would be easy to
      • Technology
    • Building a mobile makerspace: part 1— getting started
      Pioneer Wendy Aracich is putting together and implementing a mobile MakerSpace for her virtual school of 4000 students spread across the state of Georgia.
      • Technology
    • coca cola upcycle
      Upcycling community project
      Upcycling challenges students and educators to use their creativity and 3D printing skills to breathe new life into a few familiar objects.
      • Informal learning
      • Technology
    • LibraryLyna
      Tactile Problem/Solution Bank Community Project
      3D modeling and printing should be accessible of every educator so that they may offer their students tactile means to understand spatial concepts.
      • Languages
    • pecha-kuchas
      Construct3D to Kamehameha Ed Tech Conference
      Last year Pioneer Greg Kent traveled from Hawaii to North Carolina to attend Construct3D 2017. We thought we'd share his reflections with you now since we recently announced Construct3D 2018
      • Technology
    • Plastic Ocean by Kevin Krejci
      Ocean Plastic Community Project
      The Ultimaker Community Team will be launching a series of interdisciplinary projects over the next few months that challenge students to research, explore, design, and 3D print. Ocean Plastic is the first project of this series.
      • Geography
    • Design Engine Box
      Design Engine community project
      We want to challenge educators and students to help evolve the Design Engine game. We want to see how you're using or modifying the game with your students, and we want to incorporate your ideas into the next edition.
      • Informal learning
      • Technology
    • Drone1
      Using drones and 3D printing to develop design thinking during a summer robotics camp
      Pioneer Yuriy Drubinskiy writes about his experience leading a summer program and how creating drones with 3D printing brings form, structure, and design together.
      • Technology
    • fractal2
      3D printed fractals at JMU 3SPACE
      Pioneer Professor Laura Taalman, (a.k.a. mathgrrl), reviews a multi-week study of fractals by general education math students in the JMU 3D printing classroom.
      • University
      • Mathematics
    • The Starter Pack launch event at Digital Harbor Foundation
      Introducing the Ultimaker Design Engine Starter Pack
      Presenting the Ultimaker Design Engine Starter Pack: a game created to provoke, inspire, and entertain students, educators, 3D designers, artists, and engineers of all experience levels!
      • Informal learning
      • Technology
    • first puzzle cube and package to be made on a 3D printer entirely out of PLA
      Davidson Desktop Doohickeys: Puzzle cubes
      Pioneer Adam Davidson writes about a project in his curriculum that is a rite of passage for his high school's engineering program students. He explains at how it started and what caused it to change
      • Engineering
    • soft robot mold
      3D printing with UMaine Bioengineering students
      • University
      • Science
    • Star Wars and STEAM
      3D printing, Arduino, and Star Wars: A guide to K-12 STEAM engagement
      • Technology
    • Cam-ball-launcher
      Nautilus cam ball launcher
      Design process is about discovery through iteration. Pioneer Brad Whitehead describes how his FTC robotics team learned this while working on a unique ball launcher.
      • Special education
      • Technology
    • 3D-printed molecules
      3D printable molecular models
      Tandy Grubbs, Professor of Chemistry, writes about how chemistry students at Stetson University are taking advantage of 3D printing to better visualize the molecular world.
      • University
      • Science
    • animal adaptations
      Animal Adaptations
      • Primary education
      • Technology
    • Launching water rockets
      3D water rockets
      Pioneer Tim Cooper explains what to do with a First Lego League team in the off season when they love rockets and 3D printing.
      • Primary education
      • Science
    • Three reasons for open source tech in your 3D printing classroom
      Pioneer Joshua Pearce explains why educators should consider using free and open source options in and out of the 3D printing classroom.
      • University
      • Technology
    • 3D printing artifacts
      3D printing artifacts from the Penn Museum
      The chance to hold a 3D printed historical artifact in our hands is one of the greatest ways to boost students' engagement with science, engineering, and culture. Learn how challenging and exciting it can really be.
      • History
    • UTEP Lab
      Managing an open 3D printing lab
      What’s it like to be a student administrator for a 3D printing lab space? What kind of knowledge and experiences could you offer to students at your own school by hiring them for such position?
      • University
      • Engineering
    • 3D printing in the classroom
      Why I use 3D printing in the classroom (and why you should too!)
      While 3D printing is not new to designers, engineers and other professionals in need of rapid prototyping tools, it is still a new and exciting technology for our students. Pioneer Grace Bennett shares why teachers should get started with 3D printing.
      • Technology
    • 3D printed whistles
      Thinking about the environment
      The learning curve associated with 3D printing can produce a lot of 3D printed waste. It's time to start exploring and thinking about more sustainable options.
      • Informal learning
      • Geography
    • 3D printed Cryptex puzzle
      #1 reason to love math: 3D printed puzzles
      Pioneer Andreas Kaiser writes about the power of puzzles in the classroom and how recreating or designing puzzles is a perfect fit for his engineering students.
      • Mathematics
    • 3D printing in Multivariable Calculus
      Our 3D printing journey in Multivariable Calculus
      Here’s a story of the next generation of 3D printing pioneers exploring the 3D printing technology in Multivariable Calculus with the Ultimaker 2+.
      • University
      • Mathematics
