Keeping it real: 4 applications for increasing productivity
Keep it real: 4 applications for increasing productivity
用途
Working more efficiently and effectively is a goal of essentially every organization, regardless of sector or industry. Using 3D printing, many companies around the world can do just that in warehouses, assembly lines, and factories, enabling them to achieve results otherwise impossible. Read on for real-world applications that companies are leveraging to increase their productivity.
Support tools and quick fixes
In a fast-moving environment, time matters. Take Heineken’s bottling plant in Seville, Spain, for instance, which produces more than 500 million liters of beer each year. Efficiency is the name of the game, which means spare parts and other tools must be quickly available should the need arise. Using 3D printing, Heineken is able to print spare parts and tools on demand, minimizing downtime and ensuring that product is continuously manufactured.
heineken video
ビデオを見る
Trivium, which manufactures tin packaging for products used in industries such as beauty and personal care, food and beverage, and pharmaceutical, uses a device that measures the speed of its conveyer belts. When the wheel of this device broke, however, the company was often left waiting on a replacement. By 3D printing the wheel, downtime was reduced from days – or even weeks – to hours.
trivium-conveyor
Assembly tools
Workers at both Ford's Cologne and the Volkswagen Autoeuropa plant, use 3D printing to create tools, jigs, fixtures, and other manufacturing aids used daily on its assembly lines. These tools save the companies time and money. VW’s 3D printed wheel protection jig, for example, previously sourced for €800, but can now be printed at just €21.
3Dプリントされたホイール保護具(Volkswagen Autoeuropa社)
This 3D printed wheel protection jig was previously sourced for €800, but can now be printed at just €21. Tool development time has shrunk from 56 to 10 days.
Ford, meanwhile, uses more than 50 custom-printed tools and parts to assemble the Ford Focus.
Ultimaker-Ford-36
ビデオを見る
Quality parts
3D printing isn’t just for prototypes. As the technology evolves, more and more companies are using it to create parts fit for hard work in a hard environment. Azoth is an Ann Arbor, Michigan-based company that focuses on combining traditional manufacturing quality with the efficiencies of rapid prototyping. Using 3D printing, it enables companies such as John Deere, GM, and Ford to create digital inventories of parts that can be printed whenever, wherever.
Take these aluminum gripper fingers, which were converted to polymer gripper fingers, and are able to be produced more quickly, at a fraction of the cost – with added, replaceable hardened dowel pins.
adam-kohut-azoth-1
Created by Azoth, these aluminum gripper fingers were converted to polymer gripper fingers
Or these stop block or wear pad parts, traditionally produced in nylon. When 3D printed, the parts outperformed the original component thanks to its fiber-based materials – and result in cost savings of nearly $30,000.
adam-kohut-azoth-2
A stop block or wear pad part, created by Azoth
Transport tools
Gerhard Schubert GmbH and Trivium are both using 3D printers to create parts or tools that improve the guidance of end-use parts within production lines.
One tool inside a Schubert top-loading packaging machine, for example, is used to gently handle delicate products, ensuring that they remain in good condition.
Trivium, meanwhile, uses carbon-reinforced nylon to create a “worm” tool that guides tin cans down a production line.
trivium-worm
Want to learn more about identifying high-value 3D printing applications? Check out our guide to finding the perfect application for you.
ultimaker-guide-3d-printing-application-finder small
Identify more applications
Free in-depth guide
Get the strategies used by Ultimaker Application Engineers to help our biggest customers save with 3D printing. Including:
• 3 checklists to ensure no potential application goes undiscovered
• Industry-tested application examples proven to achieve ROI
• 2 simple criteria to prioritize the right applications
• And lots more!
