A guide to finding your 3D printing material
Adam Kohut
Applications
When creating a 3D printed object, it’s important to choose the right material. Each offers different benefits, such as heat-resistance, flexibility or high-quality finish, and the type of 3D printing material used can make or break your prototype, tool, or end-use part.
An introduction to 3D printing materials
All 3D printers require material to create a finished product. But with a wealth of materials available, knowing which one to choose can be bewildering. Your choice largely depends on your requirements, which you should identify before you begin.
This guide outlines the most popular 3D printing materials, their properties, and how they can benefit your business.
Material properties to consider
All 3D printing material types have different properties. Broadly speaking, they are divided into three categories:
Aesthetic
Technical
Processing
If you are creating visual aids you will likely prioritize good aesthetics. A business printing end-use parts, however, may value technical performance over appearance.
The following are some of the most important properties materials can determine in your print:
Good surface quality. When presenting concepts to clients (as Killa Design does with its architectural 3D printed models), a high-quality surface finish is vital
Low shrinkage. Shrinkage can be an issue during printing. A material that is shrink-resistant means that dimensions are better preserved – this is important for precision tooling Ultimaker Tough PLA blends technical performance with minimal shrinkage
Toughness and durability. A company like Gerhard Schubert GmbH, which uses 3D printers to create tools for its packaging machines, values durability above all else. End-use parts must be tough and able to withstand repeated use
Thermal resistance. Heat resistance is beneficial for companies making prototypes, as it offers greater design freedom
High tensile strength. Materials sometimes need to withstand high levels of tension. High tensile strength is important for these types of tools
Chemical resistance. If an object will regularly come into contact with chemicals, it must be able to withstand their effects
Ease of use. When creating tools, it’s imperative that materials that print parts first-time right – and that those parts are not susceptible to atmospheric conditions
Flexibility. Some products need to have flexibility to properly function properly (and to not snap under pressure)
Electrical resistance. Although this is a less common requirement, some companies need materials that insulate electricity – or prevent the discharge of static electricity – for safety reasons
3D printed architectural models created by Killa Design require a high-quality surface finish
Different types of 3D printing technology
Technology also plays a part in determining the proper 3D printing material for you. Here’s a brief rundown of the main types of 3D printing technology – and the materials best suited for them:
Fused filament fabrication (FFF). This form of 3D printing uses thermoplastic filaments such as PLA, TPU, PET, and ABS
Stereolithography (SLA) and Direct Light Processing (DLP). These use light to print, and therefore require photopolymer resin
Selective laser sintering (SLS). SLS uses thermal energy to fuse powder particles inside a build area. As such, thermoplastic powders are best (i.e. different types of nylon).
Material Jetting (MJ) and Drop on Demand (DOD). As these use droplets of material, the material needs to be photopolymer resin
Binder Jetting (BJ). Binder Jetting uses a print head to drop binder droplets on a powder surface. The best materials to use are sand or metal powder
Direct Metal Laser Sintering (DMLS), Selective Laser Melting. This adds metal powder as the finished object is being printed. It requires aluminum, stainless steel, or titanium
Ultimaker 3D printers use FFF technology to create parts
Materials per industry
Common 3D printing materials also vary from industry to industry. The following is a list of some sectors that use 3D printers, and the materials they favor:
Architecture. Aesthetics is a key concern for architects like Make Architects, especially when presenting 3D designs to clients. A material such as PLA is a good option, as it offers a glossy, attractive finish, and prints in a high resolution
Automotive. The automotive industry often requires quick, easy prototyping, plus printed tools and end-use parts suitable for a factory floor. Robustness and high tensile strength are key, followed by thermal resistance – and sometimes chemical resistance. ABS is a popular choice, as it’s easy to use, strong, and can withstand some heat
Consumer goods. Consumer goods businesses must often test multiple iterations of a product before committing to a final design. Easy-to-use materials such as PLA or versatile ones such as nylon are ideal
Industrial goods. Industrial goods usually need to be strong, flexible, and resistant to breakage. Heineken’s 3D printed production line tooling is an example of this. Some companies may favor materials such as CPE (which has a high tensile strength) or PC (for its exceptional strength)
There are several types of 3D printing material. Below is a list of Ultimaker's 3D printing materials used in many common applications. But with new materials being developed all the time, the choice is almost limitless.
ABS (Acrylonitrile butadiene styrene). ABS is suitable for prototyping and fit testing, making it a popular choice for industries including aviation, automotive, and industrial product development. Its properties include:
Durable
Thermal resistance (up to 85°C)
Good mechanical properties
Adversely affected by UV light
CPE (co-polyester). CPE is as strong as ABS, but odorless. It’s popular material for industrial use (prototypes, tooling, etc.). Its properties include:
Strong
Odorless
Emits limited VOCs and UFPs
Dimensionally stable
Chemical-resistant
CPE+ (co-polyester). CPE+ is stronger than CPE and has greater heat resistance. This makes it even more suitable for industrial purposes
Nylon (polyamide). Nylon can be used to print tools, prototypes, and end-use parts. It’s popular across a wide range of industries, due to its reliability and ease of use. Its properties include:
Strong
Impact-resistant
Flexible
Resistant to abrasion and corrosion
Easy to use
Reliable
PC (polycarbonate). Favored by engineers, PC is one of the toughest materials available. It’s ideal for making molds, lighting, short-run manufacturing, and engineering parts. Its properties include:
Tough
Stable in UV light
Heat-resistant
Chemical-resistant
Flame-retardant
PLA (polylactic acid). PLA is aesthetically pleasing, and useful for creating visualization aids and concept models. Architects often choose PLA. Its properties include:
Easy to print
Reliable
Low shrinkage
Not so strong (not suitable for functional / mechanical parts)
PP (polypropylene). PP is popular, with a wide variety of sectors using it to create prototypes and end-use parts. Its properties include:
Durable
Retains its shape, even after being bent or flexed
Low friction
Chemical-resistant
High electrical resistance
TPU 95A (thermoplastic polyurethane). This semi-flexible material is useful for businesses that require a rubber-like effect for prototypes or end-use parts. Its properties include:
Flexible
Strong
Doesn’t deform or break under high impact
Resistant to many common oils and chemicals
Easy to print
If you’d like to find out more about the 3D printing material types, please explore Ultimaker’s three-part materials series.
News
Trends
Applications
News
News
Applications
Applications
Ultimaker Cura 4.8 is ready for the Ultimaker 2+ Connect
Ultimaker Cura 4.8 is ready for use with the Ultimaker 2+ Connect – and includes a host of new features that will have you working faster and more efficiently than ever.
News
News
News
News
Applications
Applications
Applications
Applications
News
News
Ultimaker Cura 4.7 is live, and with it improvements to functionality, workflow acceleration, and Cloud integration. Download for free now!
News
Applications
Applications
Achieve higher success rates with Ultimaker Cura 4.7 beta
Ultimaker Cura 4.7 beta has arrived, and with it core improvements including ease-of-use adjustments and integration with Ultimaker Digital Factory.
News
Applications
Applications
News
Applications
Trends
Applications
News
Applications
Trends
Applications
Applications
Applications
News
News
Applications
Trends
Ultimaker Cura 4.6 beta expands on the popular Intent profiles feature to include new materials, enabling you to further simplify your print preparation workflow, produce better output from your printer, and improve dimensional accuracy.
News
Applications
News
Applications
News
News
News
News
Discover the Benefits of 3D Printing for your Industry | Ultimaker
Applications
News
Applications
Applications
News
News
Applications
News
Trends
News
Applications
News
News
News
News
Applications
News
News
News
News
News
Applications
News
Applications
Trends
News
Applications
Trends
News
Trends
News
Applications
News
News
News
News
News
Applications
News
Trends
Applications
News
Applications
Applications
News
News
News
News
News
Trends
News
Trends
News
News
Applications
Applications
News
Applications
Trends
Trends
Applications
Applications
Applications
Applications
The five key 3D printing applications
Integrating a desktop 3D printer into your workflow can yield impressive results, from creating concepts and prototypes for products to small batches of tooling, or even medical models for surgeons. Here’s a look at five of the ways 3D printing can improv
Applications
Applications
News
News
Applications
Applications
Applications
Print detailed objects faster using adaptive layers in Ultimaker Cura
Most slicing software will assign a constant spacing between each layer–known as the layer height. Very fine layer height will result in a high-resolution model, but each extra layer will add time to the printing process. A thicker layer height will print
News
Firmware 4.3 available for the Ultimaker 3
Get the latest features and a better Cura Connect experience by upgrading your Ultimaker 3 to Firmware 4.3. The latest firmware release takes your hardware further with a new accessibility feature. Learn more here.
News
News
Applications
News
Applications
Ultimaker Firmware 4.1 release adds new functionality, features, and printing performance to your Ultimaker 3 and Cura Connect. Discover what's new in this blog post.
News
News
Applications
Trends
News
News
Welcome to Ultimaker Cura 3.0
News
Applications
Applications
Applications
Applications
Applications
Applications
News
Understanding firmware
Applications
Get started with Cura: Printing with two colors
Printing with two colors not only looks visually impressive but makes it easier to highlight aspects of your 3D printed model. Here’s a handy guide, explaining how to create a dual color print.
Applications
Applications
News
News
News
News
News
News
News
News
News
Ultimaker Original upgrades
News
Trends
Applications
Applications
Applications
News
News
Applications
Applications
Painting 3D-printed models
Applications
