NavVis
Rapid prototyping wearable scanners with 3D printing
David Durbin
Product development
The NavVis VLX is no ordinary indoor scanner.
It's the world's most accurate wearable mapping device with simultaneous mapping and localization (SLAM) technology. Fast, precise, and compact, it allows operators to efficiently capture as-built indoor data for visualization in the AEC industry and elsewhere.
The job of developing such a revolutionary piece of hardware fell to NavVis industrial designers Sarah Godoj and Nils Christensen. To achieve this formidable task, they leveraged the power of rapid prototyping to test and perfect the design.
The result? The ideal balance of device accuracy, accessibility, and ergonomics – validated using Ultimaker 3D printers.
"It's a marvelous feat of engineering from our team," said Nils. "You can go hiking with NavVis VLX if you want."
Nils Christensen 3D printed many shoulder pad iterations to ensure that the NavVis VLX was comfortable
For Sarah Godoj, fast development cycles with 3D printing were key to launching the NavVis VLX on time
Sensors first
Headquartered in Munich, Germany, NavVis specializes in developing next-generation technology that enables accurate mapping of indoor spaces. And given that the wearable NavVis VLX system's accuracy had to compete with terrestrial solutions, the scanner’s sensor positioning would be the designers' top priority.
After many iterations, the team zeroed in on an innovative design that combines two multi-layer LiDAR sensors with four high-res cameras. Together, they measure and map a 360-degree view of the indoor space – mounted at the perfect distance above the operator's head to keep the operator out of the field of view while allowing the user to see everything in the environment.
With their Ultimakers running day and night, the designers quickly validated designs by connecting PVC tubing to accurately 3D printed angle pieces
But soon after deciding the basic concept, the designers realized that they also wanted to set NavVis VLX apart from other wearable scanners and require nothing to be worn on the users' back. This was to avoid bumping into anything when the user turned in tight spaces.
Sarah explained, "We used alternatives, like wood and cardboard, but closer to the final design, we didn't consider anything else, because there was no better alternative than 3D printing."
Everything in easy reach
This led to a uniquely complicated challenge to keep every user interaction accessible. The touchscreen in particular required a lot of iteration. It had to be in the field of view, but still allow the user to see the floor to find ground control points and avoid hazards.
With so many variables to find the best display angle and positioning, the team once again turned to 3D printing to validate their ideas in more accurate detail.
Joining PVC pipes with 3D printed angles allowed them to test configurations as quickly as possible. The PVC pipes could be easily cut to any length, leaving just the connecting angles to be 3D printed.
“We wanted to have precise angles to really prove the CAD,” said Nils. “This meant it was the perfect mixture of rapid prototyping and real precision.”
With this technique, the team also became well-acquainted with the dimensional accuracy of their in-house Ultimaker 3D printers. Although all 3D prints shrink a small amount as the material cools, they worked out the shrinkage by printing multiple connectors with 0.1 mm difference between each version.
Using Ultimaker Cura settings, the designers increased the detail of their prints as they refined their CAD designs
Designed to fit any body
“Creating a device that fits the human body brings a lot of challenges." explained Sarah. "But with 3D printing, we could make lots of iterations to get to a good combination of the right size and weight.”
The team's goal was to create an ergonomic experience that would feel like the user was wearing a backpack on their chest. They loaded filled water bottles onto rough wooden and 3D printed shapes to simulate that weight. If any test user found it uncomfortable, Sarah and Nils knew that they needed to make an adjustment.
This was especially necessary for the shoulder pads. To find the optimal design, the team adjusted settings in Ultimaker Cura to create fast "draft" prints, before progressing to detailed prints. This approach ensured the pads would be comfortable for anyone – without the chance of NavVis VLX sliding off.
The wearable scanner presented so many ergonomic design challenges that 3D printing became their go-to prototyping technology
Another ergonomic challenge was the device's secure storage in a transport case that a single user could carry and quickly set up on site. For this, a folding mechanism would be required. But where should NavVis VLX safely fold to result in the smallest volume?
Again, the industrial designers used 3D printing to verify the CAD model. They left holes in the arms and temporarily secured them with a long screw inserted into the 3D print.
Rapid prototyping during a pandemic
To create these fast iterations, the team relied on the workhorse output of the Ultimaker 2+ and Ultimaker S5.
Thanks to the printers' reliability, Sarah and Nils developed a 24-hour iteration cadence that allowed them to test new ideas as quickly as possible:
You could just hit "print" on Friday and go home for the weekend and come back on Monday and it was finished.
Of course, when COVID-19 forced most of the designers to work from home, their workflow had to change. For this, they depended on the remote 3D printing capability of the Ultimaker S5 and Ultimaker Digital Factory.
Despite COVID-19 restrictions, remote printing and monitoring on the Ultimaker S5 meant rapid prototyping could continue without disruption
They were able to securely monitor their print jobs and simply ask someone at the office, "could you please remove the print and press 'confirm'?" To avoid needing to add new filament halfway through a print, they also set up a second webcam to monitor the spools. This way they could keep iterating regardless of pandemic restrictions.
Nils said, “We always thought that 3D printers are a bit complicated, but the Ultimaker was a nice easy-to-use solution. It always explains the next step or what is happening right now.”
This ease of use meant that – even though their team consists of 15 designers and mechanical engineers – everyone is slicing parts to 3D print, and "no one is really afraid of touching the Ultimakers".
Continuous improvement
Because NavVis builds its scanners to order, the design team continues to iterate and improve their products using 3D printing. Nils revealed:
Every development step that we have mechanically, in 80% of the cases we 3D print first. Doing that instead of creating parts out of metal blocks with a lead time of up to five weeks. You can imagine it's quite a cost-saving.
Nils and Sarah continue to refine their 3D printing process. And thanks to Ultimaker's open filament system, they contribute to NavVis' sustainable goals by printing increasingly with recyclable materials.
In that way, they are helping NavVis build a better world – as well as better indoor scanners.
Inspired to learn more?
Discover how rapid prototyping with 3D printing can speed up your design cycles by downloading the white paper below – or check out our product development application page.
Go to market faster
Free in-depth white paper
Discover how 3D printing can accelerate your development cycles, with insights including:
• How to 3D print faster to test more iterations
• 4 essential applications for designers
• The ideal design studio setup and workflow
Azoth: Driving the transformation of physical to digital inventory with additive manufacturing
Azoth builds a new business helping manufacturing customers have machine parts right on time while saving thousands of dollars.
Industrial goods
End-use parts
Manufacturing aids
NavVis: Rapid prototyping wearable scanners with 3D printing
Discover how two industrial designers at NavVis used rapid prototyping and 3D printing to validate their breakthrough design for a professional wearable indoor scanner.
Product development
Metro Plastics: Injection mold company looks to 3D printing to solve bottlenecks
With the always-on productivity of the Ultimaker S5 Pro Bundle, Metro Plastics found a solution to their long lead times, while saving up to 90% on manufacturing parts.
Industrial goods
Manufacturing aids
End-use parts
Van Amersfoort Racing: 3D printing when every second counts
Success hasn’t stopped Van Amersfoort Racing from finding new ways to literally put it ahead of the competition. That’s why the team has begun to utilize 3D printing.
Automotive / aviation
Manufacturing aids
End-use parts
ERIKS: Working clean, certified, and in control with 3D printing
ERIKS offers technical components and related services to all sections of industry. By adding 3D printing technology to its workflow, the company is able to provide its customers with a service that holds the potential to shake up industries around the globe.
End-use parts
Industrial goods
Manufacturing aids
ZEISS: 3D printing precision parts for serial production
Carl Zeiss Optical Components uses Ultimaker printers to create adapter plates customized to its industrial microscopes and capable of serial production.
End-use parts
Industrial goods
Kootenay-Columbia Schools: 3D printers teach lessons in creativity and resilience
Kootenay-Columbia School district uses 3D printing to provide new learning opportunities, sparking creativity, imagination, and engagement across subjects and grade levels.
Education
Product development
Industrial goods
End-use parts
Architecture
Consumer goods
End-use parts
Industrial goods
Medical
Industrial goods
Manufacturing aids
Manufacturing aids
End-use parts
Architecture
Industrial goods
Product development
Product development
Consumer goods
Product development
Consumer goods
Product development
Architecture
Education
Industrial goods
Product development
The Ultimaker S5 is here
Consumer goods
Product development
Medical
Education
End-use parts
Consumer goods
Consumer goods
Product development
Education
Industrial goods
Product development
Product development
Consumer goods
Consumer goods
Product development
Architecture
Education
Architecture
Education
Education
Consumer goods
End-use parts
Industrial goods
End-use parts
Consumer goods
Product development
Tucci Hot Rods: 3D printing final custom car parts
Tucci Hot Rods uses 3D printing to create custom car parts for its vehicle modification projects. The 3D printed parts can be made in a couple of hours and - after a bit of post-processing - will be used as a final part on the custom cars.
End-use parts
Rapid design iterations for the early project stages
Honeybee Robotics is a design and engineering solutions firm known for contributions of critical planetary analysis technology to NASA’s past three Mars missions. Their designs are “destined for work on Earth, Mars, and beyond.” Their work extends to other industries as well, leveraging hard-fought...
Industrial goods
Product development
Volkswagen Autoeuropa: Maximizing production efficiency with 3D printed tools, jigs, and fixtures
Learn how Volkswagen Autoeuropa is using 3D printing to maximize assembly efficiency. By using 3D printed manufacturing aids the company reduces cycle time operation, labor, and the need for reworking, while improving tool ergonomics.
Manufacturing aids
print+: 3D printed DIY headphones
print+ is a product line of DIY kits that allows consumers to build and customize their own headphone. As the mechanical parts can be 3D printed locally, less material needs to be shipped - reducing costs and lowering environmental impact.
Consumer goods
End-use parts
Faster, more accurate dental models
Using 3D printing technology, OpLab can quickly and easily create physical models of dental arches, reducing time, labor, and expenses in the process. The new approach means the team can achieve greater model accuracy, resulting in less error and a better service for their clients.
Medical
Cardiff University: Accessible 3D printed microfluidic devices
The 3D printed microfluidic devices developed by researchers at Cardiff University offer a cost-effective alternative to the traditional ones, which are expensive and require specialized skills and equipment.
Education
End-use parts
Rapid prototyping to solve 21st century problems
Native Union used their Ultimaker 3 to rapidly prototype parts and mechanisms for their latest device designed to resolve a common 21st century issue, making messy USB charging cables a thing of the past.
Consumer goods
Product development
3D printing in landscape architecture and pool design
3D printing is changing the face of architectural design. Discover how landscape designers are transforming outdoor spaces into memorable locations that allow people to fully engage in their surroundings, while making a positive impact on the environment.
Architecture
Open Bionics: 3D printed prosthetic limbs
Using an Ultimaker 3D printer, Open Bionics is developing tailor-made 3D printed prosthetics at a fraction of the cost of traditional ones. Read all about their remarkable story here.
Medical
3D printing in furniture design
3D printing can be used to create virtually anything. Designer Jon Christie used his Ultimaker 3D printer to create some impressive 3D printed furniture, which offers flexibility and reduced costs. Learn more here.
Consumer goods
Product development
Inholland University: Building a 3D printed rocket
Students at Inholland University of Applied Sciences use 3D printing to design and build rockets as part of their course in aviation technology. Read on and download a ready-to-use lesson plan to include 3D printing in your school's educational program.
Education
Vathorst College: Integrating 3D printing in high school education
Creative STEM projects allow students to expand their knowledge and develop basic 3D printing skills. Read on for lesson plans that focus on both science and mathematical applications.
Education
Eventuri: Functional and fit testing of performance car intakes
With 3D printing companies like Eventuri can be flexible in their design process, run quick iterations and perform functional and fit testing of their 3D printed car intakes in a short period of time.
Product development
MATT Architecture: Rapid model making with 3D printing
MATT Architecture creates architectural models in central London. They use 3D printing to quickly reiterate the models they are working on, which saves a lot of time and development costs.
Architecture
Changing lives in developing countries with 3D printed prosthetics
The Victoria Hand Project creates customized prosthetic hands for amputees in third world countries – using Ultimaker 3D printers to make the process more efficient and cost-effective.
Medical
Using Ultimaker to cast silicone for soft robotics
Using their Ultimaker 2+ 3D printer, students from Delft University of Technology have discovered a way to cast silicone for soft robotics. This has huge implications for soft actuators, and for the medical sector. Read on to learn more.
Education
Product development
Henchmen Props: 3D printed props workshop
Henchmen Props creates props and costumes for industry-leading video game companies like Blizzard and Respawn. 3D printing has allowed them to greatly reduce their production times and rapidly prototype new parts.
Product development
Teaching STEM with 3D printed bottle rockets
There are many ways in which 3D printing can be used to enhance the students' learning experience in modern-day primary education. Discover how 3D printing can boost learning here.
Education
The Ultimaker 3: Behind the scenes
3D printers let product designers and engineers test, evaluate and improve their ideas. Even more importantly, they’re a powerful tool for various professional applications. Read on to find out how we developed the Ultimaker 3.
Product development
Bringing the Ultimaker 3 to market with bridge manufacturing
Ultimaker 3 has proven to be a reliable solution for businesses. Learn how bridge manufacturing helps you launch products on time, with a 3D printer that's primed to deliver results.
Industrial goods
End-use parts
Functional prototyping at ABB Robotics
3D printing gives businesses around the world the opportunity to save time and money. ABB Robotics turned to the Ultimaker 2 Extended+ for making prototype fingers for their robot YuMi, bringing new opportunities to the company.
Industrial goods
Product development
Breaking barriers in education with 3D printing
With a desktop 3D printer, teachers can empower their students to design, collaborate, and create amazing things they never thought possible. But what is it actually like to have a 3D printer in the classroom?
Education
From a market-tested prototype to an eye-saving game-changer
oDocs Eye Care Kit has the potential to save millions from blindness. But this wouldn’t be possible without functional prototyping. And 3D printing is the most accurate, not to mention time and cost-effective, way to achieve it.
Medical
3D-powered prototyping by the Bhold Studio
How far can you get with a dream and a 3D printer? You can think of the most sophisticated forms and textures, turn them into successful products and blaze through prototyping and production at lightning speed.
Consumer goods
Product development
Surgical planning using 3D printed bone models
Professional 3D printers are now being actively used by healthcare professionals not only to educate patients about their condition, but also to plan complex surgeries – even using the models during the operation as a guide.
Medical
3D printing a Tyrannosaurus rex skeleton
To build a 13 meter long T. rex skeleton, Naturalis turned to 3D printing. Thanks to the incredible accuracy and flexibility of the Ultimaker 2+, the skeleton will be restored in even greater detail than initially anticipated.
Education
Developing sustainable fuel with Team FAST
Using their Ultimaker 3D printer, Team FAST was able to design and print custom mounts and fittings for their car prototype fueled with formic acid.
Education
Using 3D printed shapes to create food molds
3D printing shapes and prototypes for food-safe molds is becoming a popular 3D printer application in the food industry that allows entrepreneurs to escape the demands of industrial-sized production runs.
Consumer goods
Product development
Saving eyesight with a 3D printed eye examination kit
oDocs Eye Care creates open source medical equipment for eye diagnoses. Using 3D printing, they developed a cost-effective and accurate eye examination kit to help diagnose treatable and preventable blindness.
Medical
End-use parts
Using Ultimaker 3D printers for manufacturing at Siemens
Learn how Siemens Rail Automation are using their Ultimaker 3D printers to assist in prototyping of new components and products, as well as manufacturing end-use parts.
Industrial goods
Product development
Project Seafood, creating waves of change on our shores
Desktop 3D printing allows anyone to transform ideas into tangible products in a matter of hours. This is a story of a couple who took their Ultimaker Original out for a spin in their mini-van to make a better world.
Product development
Architects use 3D printing to prototype huge city project
To help bring their ideas to life Sweco architects needed a rapid prototyping tool they could rely on every day to create models with tight deadlines. So they turned to 3D printing.
Architecture
The Olsson Block - a community invention by Anders Olsson
We're proud to say that an essential part of the Ultimaker DNA is our strong community. we’d like to highlight the work of an ingenious community member called Anders Olsson, the man who gave us the Olsson block.
Education
Product development
The world's fastest 3D printed R/C car
What do you do when you want to build the world's fastest radio controlled car? Build it yourself! Read this story to find out how one man designed and created a 3D printed RC car from scratch.
Product development
3D printing in education for inspirational learning
More and more, 3D printing is being used in education. Teachers use 3D objects to help primary school kids grasp concepts, refine students' creative skills in high school and help them learn technical subjects at university.
Education
100% recycled filament from Perpetual Plastic Project
At this moment there are huge amounts of waste plastic, and only 10 to 12% of it is being recycled. The team behind the Perpetual Plastic Project is looking to change the world by reducing the amount of plastic.
Consumer goods
Product development
Meet Luke and his 3D printed e-NABLE hand
With a global network of over 5,000 volunteers, the e-NABLE foundation designs, creates, and donates their 3D printed hands free of charge to children and adults using Ultimaker 3D printers.
Medical
3D printed and prototyped shoes by Julian Hakes
Learn how fashion designer Julian Hakes brought his award-winning Mojito Shoe to life. With his Ultimaker 3D printer, he was able to create multiple prototypes in-house and perfect his designs.
