PLA is a great material for early concept models because it is easy to use, office-friendly, and works great with breakaway supports which print faster and can be removed faster than dissolvable supports. PLA is a corn-based plastic and is considered biodegradable under industrial processes.
Select the material properties you would like to compare all Method series materials.
Print complex mechanical assemblies with real production materials
Extruder
Tensile strength:
Heat deflection:
Tensile Modulus
Extruder
Tensile strength:
Heat deflection:
Flexural modulus:
Extruder
Tensile strength:
Heat deflection:
Flexural modulus:
Extruder
Tensile strength:
Heat deflection:
Flexural modulus:
Extruder
Tensile strength:
Heat deflection:
Flexural modulus:
Extruder
Tensile strength:
Heat deflection:
Flexural modulus:
Extruder
Tensile strength:
Heat deflection:
Flexural modulus:
Extruder
Tensile strength:
Heat deflection:
Flexural modulus:
Extruder
Tensile strength:
Heat deflection:
Flexural modulus:
