Explore our support content
Pricing or financing options
Press and general inquiries
David Durbin
Maggio 25, 2023This application concept was designed by application engineers at Ultimaker to showcase one of the many possible ways that metal FFF technology can improve existing processes.
3D printed parts have a specific look and feel that distinguishes them from parts that were created using traditional manufacturing methods.
Layer lines and other visual defects can cause users to incorrectly dismiss them as lower quality or less reliable.
Post-processing techniques can be used to make plastic 3D printed parts indistinguishable from parts that were made using other techniques like injection molding. This is also true of metal parts made using MFFF technology.
This 21-ounce framing hammer is a concept application that was printed on the Ultimaker S5. The head is printed in BASF Forward AM Ultrafuse® 17-4PH stainless steel while the handle is printed in Ultrafuse® PET CF.
After sintering, the metal was sanded to flatten and round the base of the head. Prior to assembly of each component, the metal head was was wet polished and sprayed red to reproduce the touch and feel of tradition tools.
Print time | Weight | Cost |
1 day 8 hours 34 minutes | 594 g | $168.29 |
This application is proof that tools produced using MFFF can be made to look and feel indistinguishable from traditionally manufactured parts.
Simple and easy to achieve finishing techniques like wet polishing, sand blasting, or grinding, which are often also used on non 3D printed parts, can also be used to great effect for MFFF parts.
This hammer showcases the many ways metal 3D printing can achieve breakthrough results in the production of functional stainless steel tools.
Click below for more explore more MFFF application inspiration. Or discover how to buy the Ultimaker Metal Expansion Kit for yourself. ###More metal applications | ![]() |
Vacuum gripper | Spherical gripper | Engine assembly tool |
Meet the Metal Expansion Kit
