parts in cura
My reintroduction to Netfabb
Secondary educationTechnology
A NetFabb workshop convinced me that I can't live without this application. See why it's time to take another look at Netfabb.
Before Autodesk purchased Netfabb, I often used the free software to repair files, reverse engineer models, and to cut files into parts. While I still had my copy of Netfabb Basic on my computer, I could no longer freely recommend Netfabb to teachers who were new to 3D design and printing. Now a windows only application, the licensed version of Netfabb, while free to educators and students, was no longer available to those schools that were solely Mac-based. This would include the school where I taught for fourteen years.
Netfabb had been an important node in my workflow, so I installed Parallels (I might have done this so that I could run Rhino with Grasshopper too and installed Netfabb Standard 2018. I then attended a NetFabb workshop. I now wonder how I was so easily willing to give up this tool.
What can Netfabb do for you? Well, it first and foremost allows you to check and repair files. Bring in a file, see if there is an exclamation point in a triangle, and if so, click on the red cross button. The easiest repair and often the only one you’ll need is the default repair. Click on Execute the Repair, remove the old part, then export your repaired mesh, and print.
Recently I created a two color model of the Ultimaker robot in Fusion 360. The one thing I did not want to do was export the tiny white parts and the tiny black parts as individual STL files. My solution? Attach a .2 mm extruded plane to each of them, then export the two files as STLs, import into Netfabb and cut the plane off from each. Unlike Fusion 360, Netfabb doesn’t care if the parts are separate, it will still allow you to export them as a single STL file.
In the workshop I found that Netfabb can do much more to help your workflow. I also realized that there are other tools, like Meshmixer  and Meshlab, that do similar things. I find Meshmixer a great tool, but not very intuitive, and my biggest complaint with Meshlab, is that it doesn’t support an undo command.
So what am I now doing with Netfabb? I’m duplicating my models, setting up the positions on the build plate, applying extruded or embossed text to the models, changing the mesh densities and exporting the group as a 3MF file.
1. Import your STL file:
01 import stl
2. Select the Move Icon:
02 move
3. Select To Origin:
03 to origin
4. Click on the Translate button to accept the transformation:
04 translate
5. Select Arrange → Orient Part:
05 arrange orient part
6. Click on the Search button. Netfabb will now start processing how your part can be oriented:
06 search
7. Netfabb has determined how the different orientations take different resources. Scroll through your options and find the balance between part strength and material usage.
8. Under Prepare select Load Machine Workspace. Since you’re spending time arranging your part, you might as well have the proper buildplate to work with:
08 load printer
9. Start typing the company name and Netfabb will jump to that option. Then click on the selection on the left and press OK:
09 start typing printer name
10. You have now loaded the buildplate, but your model seems to have disappeared. In the left panel, you need to drag your model onto the named workspace:
10 ultimaker workspace
11 drag model into workspace
11. Select the Move Icon and move the model to the center of the buildplate by selecting to Platform Center:
12 move model to platform center
12. CTRL+click on the model and select Duplicate or type Ctrl+X to bring up the dialog window:
13 right click duplicate
13. Determine how many copies you want and select how you prefer them to be arranged, then click on the Duplicate button:
14 create number
14. Now select Arrange→ 2D Packing to efficiently place the models across the buildplate:
15 arrange 2d packing
15. Click on the Move Icon. Select all the models and translate them to the center of the buildplate:
16 packed
16. Next is one of my favorite actions: Text Labeling. Netfabb will take your text and automatically wrap it over your mesh. Under the abc Icon, select Text Labeling:
18 select a model and labeling
17. In the caption box, type the text you want to apply to your model. Now you may just want to add decorative text, but Netfabb makes it really  easy to apply text, that you might want to consider applying codes to your models that identify the iteration. Maybe you are developing a project and you want to test options. You could print your model and write the code on the bottom with a sharpie, but by applying the text to the model in Netfabb, you don’t have to worry about smearing the ink. The trick here is that you need to keep track of what your codes mean. I would suggest using a spreadsheet to keep track of codes and changes to models.
Once you type your text, figure out if you will extrude or emboss. 1mm is a printable extrusion for text in most orientations. Adjust the location and size of the text in the window on the right and when you are satisfied, click Apply:
19 add text depth how to add
18. Now remove old part:
20 apply and remove old part
19. Select one of your coded models and hit the Repair Icon:
21 select label another but subtract
20. Select Mesh Edit → Reduce Triangles:
22 select model repair mesh edit reduce
21. Enter a number for the target Triangle count. I generally enter 80K. Then click on Execute:
23 set a target and execute
22. Remove old part:
24 remove old part
23. Click on another coded model and this time reduce the triangles to a target that is as low as possible. Netfabb will work to preserve the integrity of your mesh:
25 select other labeled model repar mesh edit reduce low
24. Select all your coded models and select Export part from the File menu. Export these models as 3MF:
26 select all models export as 3mf
25. Name your file and set where you want to save it. Optimize, then click the OK button:
27 rename optimize save
26. Now import the 3MF file into Cura and print:
frogs in cura
What other tips and tricks did I learn?
Here’s a fun one: adding pins to join parts. Import a part, cut it in two pieces, but before you click the cut button, enable Automatic Pin Creation and Create Group. Then click on Pin Settings. If you only want a pin in the center, set the Distance of pins to the radius. Make sure to set your tolerance: a pin with the same diameter as a hole with no tolerance won’t fit together. Also note that you can change the top and bottom radii of the pins to get a tapered pin.
before cutting
pin settings
hole in bottom
And there are quite a few hidden gems in the Part Library. You might expect the availability of basic primitive shapes, but you might be surprised to find mechanical parts like gears, mathematical functions, like gyroids, and a slew of random “design” parts that are parametrically driven.
gear
gears
gyroid
design parts
Try the mold design:
mold ultimaker
Or create a custom configuration of a brick:
brick
Move nodes around to create a custom vase:
custom vase
It seems that every time I look deeper into the application, I find another handy surprise. I could spend hours exploring, creating and printing. Now if only Autodesk will reintroduce a mac version!
The frog STL used in this blog was created by Victor De Los Angeles of CuboDesigns.
Read more education blogs
    • Naturalis Biodiversity Center: Prehistoric prints, cutting-edge technology
      Naturalis Biodiversity Center, the Netherlands’ national natural history museum, is using 3D printing to create both partial and full dinosaur skeletons for public display.
      • History
      • Informal learning
    • Ultimaker Met
      • Secondary education
      • History
    • College of the Desert 3D printing club
      • Special education
      • Technology
    • Testing Quadcopter
      • Informal learning
      • Technology
    • Smithsonian Learning Lab
      • Informal learning
      • Art
    • Harvard calculus courses use 3D printed models to engage students
      • University
      • Mathematics
    • Code your 3D designs with Tinkercad’s new Codeblocks app
      Tinkercad released Codeblocks last June, and now that it's out of Beta, Pioneer Rob Morrill tells us how he uses it.
      • Informal learning
      • Technology
    • Mathematica Tea Light Holder
      • Informal learning
      • Mathematics
    • printingUltibot
      Modifying an STL with Tinkercad
      When Ultimaker Pioneer Alex Larson contacted me about the Ultibot-D project, I was super excited. As a teacher and parent, I am a huge cheerleader for risk. I printed the base models at ⅕ scale and gave it to my students to explore
      • Primary education
      • Technology
    • Ultimaker at Camp
      Math Camp: Having fun doing stuff
      Pioneer Dr Toni Szymanski writes about summer fun at camp with 4th and 5th graders, math, and 3D printing.
      • Primary education
      • Mathematics
    • 3D printing for glass
      GlitchCraft
      Guest blogger Astrida Valigorsky writes about combining the old and the new at Timothy Belliveau's GlitchCraft class where students combined 3D printing and glass blowing.
      • Informal learning
      • Technology
    • 3D printing in math and chemistry
      A unique 3D printing collaboration between mathematics and chemistry faculty
      Passing it on. After integrating 3D printing into her own math courses, Kristen Schreck helps spread 3D printing across disciplines at Saint Xavier University.
      • University
      • Science
    • basecampProject
      Using Basecamp to manage your classroom/makerspace projects and print queue
      Pioneer Andrew Woodbridge uses Basecamp to organize his students' projects, and he explains how you can too.
      • Technology
    • World monument project
      Living world monuments assignment
      Pioneer Joanne Barrett shares about a middle school project that combines 3D printing, Augmented Reality, History, and Art.
      • History
    • toni teaching fusion
      Teacher training for 3D printing
      Pioneer Dr. Toni Szymanski thought that 3D printing could engage students in math classes. To test this out, she had to learn all about 3D printing first.
      • Mathematics
    • Finland’s mobile libraries
      3D printers in the public library: Finland ahead of the curve
      US Professor Joshua Pearce, sponsored by Fulbright Finland for Research, shares his first impressions of Finnish libraries.
      • Informal learning
      • Technology
    • parts in cura (1)
      A recent NetFabb workshop convinced the writer that they can't live without this application. See why it's time to take another look at Netfabb.
      • Technology
    • buckeyball
      Modeling rocks at iCREATE
      iCREATE's Tiffany Huang shared an iCREATE success story about Jackie Zheng.
      • Science
    • goblet project
      Pioneer Chris Hanusa shares one way he integrated 3D printing into his Integral Calculus class
      • University
      • Mathematics
    • Happiness
      Lessons in letting go - releasing student energy speeds creation and use of our art and innovation lab
      Pioneer John Nordell enlisted his students to put the Art and Innovation Lab together. The result was one of the best experiences he has had as an educator.
      • University
      • Technology
    • hero wrenchs
      Wrench Engineering
      • Primary education
      • Engineering
    • ceramic stamps
      Digital fabrication informs ceramics decorative process
      Pioneer Young Kim blends his classical arts background with digital fabrication to create a ceramic project that incorporates 3D printing.
      • Art
    • Empathy map
      Elementary-College Engineering Design partnership
      Pioneer Matthew Wigdahl writes about how his fifth graders and local undergraduate engineering students learn from each other.
      • Primary education
      • Engineering
    • 014-SchoolHero
      Introducing Ultimaker’s Core Lessons Set for STEAM Educators
      Designed by the Ultimaker North America Community Team, our new Core Lessons: STEAM Set is a resource for educators who need inspiration and ideas when they bring 3D printing into their classrooms.
      • Primary education
      • Technology
    • MakerGirl
      Empower one MakerGirl, empower the world
      how the group traveled 10,000 miles around the country to help bring 3D printing workshops to over 1,000 young girls. In this week's post we catch up with the organization that is still working to create a new generation of confident, creative women leade
      • Primary education
      • Technology
    • Georgia Connections Academy
      Building a mobile maker space: part 2—up and rolling
      So what exactly does a Mobile MakerSpace look like? That's the question I had to ask myself once I began the project of bringing 3D printing technology to virtual students. When we started this project, we knew we needed something that would be easy to
      • Technology
    • Building a mobile makerspace: part 1— getting started
      Pioneer Wendy Aracich is putting together and implementing a mobile MakerSpace for her virtual school of 4000 students spread across the state of Georgia.
      • Technology
    • coca cola upcycle
      Upcycling community project
      Upcycling challenges students and educators to use their creativity and 3D printing skills to breathe new life into a few familiar objects.
      • Informal learning
      • Technology
    • LibraryLyna
      Tactile Problem/Solution Bank Community Project
      3D modeling and printing should be accessible of every educator so that they may offer their students tactile means to understand spatial concepts.
      • Languages
    • pecha-kuchas
      Construct3D to Kamehameha Ed Tech Conference
      Last year Pioneer Greg Kent traveled from Hawaii to North Carolina to attend Construct3D 2017. We thought we'd share his reflections with you now since we recently announced Construct3D 2018
      • Technology
    • Plastic Ocean by Kevin Krejci
      Ocean Plastic Community Project
      The Ultimaker Community Team will be launching a series of interdisciplinary projects over the next few months that challenge students to research, explore, design, and 3D print. Ocean Plastic is the first project of this series.
      • Geography
    • Design Engine Box
      Design Engine community project
      We want to challenge educators and students to help evolve the Design Engine game. We want to see how you're using or modifying the game with your students, and we want to incorporate your ideas into the next edition.
      • Informal learning
      • Technology
    • Drone1
      Using drones and 3D printing to develop design thinking during a summer robotics camp
      Pioneer Yuriy Drubinskiy writes about his experience leading a summer program and how creating drones with 3D printing brings form, structure, and design together.
      • Technology
    • fractal2
      3D printed fractals at JMU 3SPACE
      Pioneer Professor Laura Taalman, (a.k.a. mathgrrl), reviews a multi-week study of fractals by general education math students in the JMU 3D printing classroom.
      • University
      • Mathematics
    • The Starter Pack launch event at Digital Harbor Foundation
      Introducing the Ultimaker Design Engine Starter Pack
      Presenting the Ultimaker Design Engine Starter Pack: a game created to provoke, inspire, and entertain students, educators, 3D designers, artists, and engineers of all experience levels!
      • Informal learning
      • Technology
    • first puzzle cube and package to be made on a 3D printer entirely out of PLA
      Davidson Desktop Doohickeys: Puzzle cubes
      Pioneer Adam Davidson writes about a project in his curriculum that is a rite of passage for his high school's engineering program students. He explains at how it started and what caused it to change
      • Engineering
    • soft robot mold
      3D printing with UMaine Bioengineering students
      • University
      • Science
    • Star Wars and STEAM
      3D printing, Arduino, and Star Wars: A guide to K-12 STEAM engagement
      • Technology
    • Cam-ball-launcher
      Nautilus cam ball launcher
      Design process is about discovery through iteration. Pioneer Brad Whitehead describes how his FTC robotics team learned this while working on a unique ball launcher.
      • Special education
      • Technology
    • 3D-printed molecules
      3D printable molecular models
      Tandy Grubbs, Professor of Chemistry, writes about how chemistry students at Stetson University are taking advantage of 3D printing to better visualize the molecular world.
      • University
      • Science
    • animal adaptations
      Animal Adaptations
      • Primary education
      • Technology
    • Launching water rockets
      3D water rockets
      Pioneer Tim Cooper explains what to do with a First Lego League team in the off season when they love rockets and 3D printing.
      • Primary education
      • Science
    • Three reasons for open source tech in your 3D printing classroom
      Pioneer Joshua Pearce explains why educators should consider using free and open source options in and out of the 3D printing classroom.
      • University
      • Technology
    • 3D printing artifacts
      3D printing artifacts from the Penn Museum
      The chance to hold a 3D printed historical artifact in our hands is one of the greatest ways to boost students' engagement with science, engineering, and culture. Learn how challenging and exciting it can really be.
      • History
    • UTEP Lab
      Managing an open 3D printing lab
      What’s it like to be a student administrator for a 3D printing lab space? What kind of knowledge and experiences could you offer to students at your own school by hiring them for such position?
      • University
      • Engineering
    • 3D printing in the classroom
      Why I use 3D printing in the classroom (and why you should too!)
      While 3D printing is not new to designers, engineers and other professionals in need of rapid prototyping tools, it is still a new and exciting technology for our students. Pioneer Grace Bennett shares why teachers should get started with 3D printing.
      • Technology
    • 3D printed whistles
      Thinking about the environment
      The learning curve associated with 3D printing can produce a lot of 3D printed waste. It's time to start exploring and thinking about more sustainable options.
      • Informal learning
      • Geography
    • 3D printed Cryptex puzzle
      #1 reason to love math: 3D printed puzzles
      Pioneer Andreas Kaiser writes about the power of puzzles in the classroom and how recreating or designing puzzles is a perfect fit for his engineering students.
      • Mathematics
    • 3D printing in Multivariable Calculus
      Our 3D printing journey in Multivariable Calculus
      Here’s a story of the next generation of 3D printing pioneers exploring the 3D printing technology in Multivariable Calculus with the Ultimaker 2+.
      • University
      • Mathematics
