Cura Method series S series
New printers, hardware support, and more in the stable release of Cura 5.10
Marzo 25, 2025
Introducing the UltiMaker S8
The new and super-productive UltiMaker S8 is now supported in Cura. The S8 is the newest professional desktop printer in the S series, and it achieves up to 4x the speed of its predecessor while also improving print quality. That is possible thanks to the new UltiMaker Cheetah motion planner and new high flow cores, all of which will be usable at launch with Cura!
Precise model control using the 3D SpaceMouse by 3Dconnexion
SpaceMouse
Check out the official integration page provided by 3Dconnexion to find out more!
New materials and intent profiles for UltiMaker and MakerBot printers
Lots of new material profiles this release with the Method X and XL printers both getting profiles for the PC-ABS and PC-ABS-FR materials. All S series printers also now have support for the Nylon Slide material and all Sketch printers have a new Metallic PLA material profile. The Sketch Sprint has also received new ‘Visual’, ‘Extra Fast’, and ‘Draft’ intent profiles. In addition, the MakerBot Replicator+ printer is also now supported in Cura!
Nylon-CF slide
Note that the beta release of 5.10 included 'High Speed' and 'High Speed Solid' intent profiles for Method series printers. However, they did not meet our quality standards and have therefore been temporarily removed. They will be reintroduced in a future Cura release after further optimization.
Upcoming changes for USB-connected printing
USB printing notice
Keep printing over cloud – quick action needed
Additional improvements
The following improvements have also been implemented in the Cura 5.10 stable release:
  • You can now tune the Bottom Surface Skin, like you can tune the Top Surface Skin! You can now tune Extruder, Layers, Line Width, Pattern, Line Directions, Outer Wall Flow, Inner Wall(s) Flow, Flow, Outer Wall Speed, Inner Wall Speed, Skin Speed, Inner Wall Acceleration, Skin Acceleration, Outer Wall Jerk, Inner Wall Jerk, Skin Jerk, and Monotonic Bottom Surface Order
  • Introduced a new Marlin-like Gcode flavor called Cheetah
  • Enabled printing over the cloud with Digital Factory for Sketch Sprint users
  • Moved Interlocking materials settings out of experimental and into expert
  • Upgraded the build system from Conan 1 to Conan 2. Updated documentation is available
  • Added an option to flip the Y-axis translate tool handle in preferences, contributed by @GregValiant
  • Introduced rotation by input & snap angle input, contributed by @GregValiant
  • Added a Purge Lines and Unload Filament Post Processing Script, contributed by @GregValiant
  • Enabled the "Open in Cura" button from Thingiverse to open files in Linux, contributed by @hadess
  • Introduced 3 new configuration options in machine settings for multitool printers, contributed by @TheSin-
  • Significantly improved the Search and Replace post-processing plug-in with features like replacing only the first instance, limiting search to a layer range, and ignoring start-up or ending G-code, contributed by @GregValiant and @FieldofView
DOWNLOAD NOW
