Over 280 materials to choose from.
Explore our support content
Pricing or financing options
Press and general inquiries
Contact our support team directly
Arun Chapman
7月 29, 2024In the Cura 5.8 stable release, everyone can now tune their Z seams to look better than ever. Method series users get access to new material profiles, and the base Method model now has a printer profile, meaning the whole Method series is now supported in Cura!
New settings have been added that let you tweak how and where the Z seam is placed. The settings are:
When “User Selected” or “Shortest” is selected as your Z seam location option, the Z seam will follow the selected (or shortest) position exactly. However, when the new “Z Seam On Vertex” option is selected, the Z seam will instead be placed on the nearest vertices (usually a corner). This allows you to hide your Z seam on areas of your model where it will not be so noticeable. You can see this behavior in the following image:
The new “Seam Overhang Angle” allows you to choose an angle after which seams will not be printed on overhangs (including when “Z Seam On Vertex” is selected). This improves print quality as seams placed on steep overhangs can cause ugly print defects.
Finally, the “Support Z Seam Away From Model” setting will ensure when selected that the seam on the support material is placed away from the model itself so that the bulge caused by the seam will not intersect with your model and cause scarring or make removing supports more difficult.
The UltiMaker Method X and Method XL printers were added to Cura in the 5.6 release and, in this release, we have also added the original Method printer so that the full range of Method series printers is now supported in Cura!
The Method will have a material profile for Nylon12 Carbon Fiber as well as profiles for PLA and PVA which have also been added to the Method X and Method XL. In addition, many of the existing material profiles have been tweaked and improved. With this release, we are making it easier than ever to leverage the power and flexibility of Cura when using your Method series printer!
When adding a new non-networked printer, it’s now possible to search for the printer you want to add, meaning you no longer need to manually look through the hundreds of printers that are supported by Cura.
The following improvements have also been implemented in the Cura 5.8 beta release:
Check out the full release notes on GitHub for a complete list of changes. Also, we made a new 3D model for this release that was used to show off the Z seam changes above. It's a fun toast-themed post-it holder. If you want to try it out for yourself, you can download it from Thingiverse!
Download this latest release to start discovering new 3D printing possibilities right now. And please, go to the UltiMaker community site to give us your feedback.
DOWNLOAD NOW
