6月 6, 2025Welcome back to our application spotlight series, where we explore how UltiMaker 3D printing technology helps streamline operations across industries. From boosting productivity to cutting manufacturing costs, each story highlights the power of additive manufacturing to solve real-world challenges. This week, we’re diving into the fast-paced world of automated bottling lines—where precision and timing are everything. The unsung hero? A custom 3D printed timing screw.
Also known as a feed screw, this component plays a vital role in ensuring that products are correctly spaced, aligned, and delivered into downstream machines - like fillers, cappers, or labelers - at exactly the right time. It’s especially important in high-speed production environments, where even minor misalignment can lead to jams or slowdowns.
Traditionally machined from materials like POM, timing screws can be expensive and slow to produce - especially when customized to fit specific product shapes. By switching to in-house 3D printing with UltiMaker Nylon CF Slide, manufacturers can create tailored, wear-resistant screws that meet their exact needs.
The design is even split into two parts for easier assembly and maintenance - no complex tooling or long lead times required.
This timing screw was printed on the UltiMaker S6 - our latest professional 3D printer designed for high-demand applications. Powered by the new Cheetah motion planner, the S6 delivers faster print speeds without compromising dimensional accuracy or surface quality. That means teams can move from design to deployment faster than ever, with confidence that every part will perform under pressure.
Switching to 3D printing delivered dramatic efficiency gains:
** Thanks to Nylon CF Slide’s low-friction and high-wear resistance properties, the timing screw is ideal for continuous motion environments. The printed geometry is optimized for smooth product handling, while dual extrusion allows for built-in wear indicators—making proactive maintenance easier than ever.
This application shows how even highly specialized parts can benefit from additive manufacturing. When you need precision, speed, and durability - UltiMaker has you covered.
The UltiMaker S6 is your most straightforward and accessible entry point into the comprehensive UltiMaker ecosystem. Get up to 4x productivity, hundreds of materials, and powerful tools like Cura Cloud and UltiMaker Digital Factory, all within easier reach.
Discover how professional 3D printing can unlock new efficiencies in your production line, one part at a time.
