David Durbin
5月 24, 2023This application concept was designed by Steve Cox from AMFORi to showcase one of the many possible ways that metal FFF technology can improve existing processes.
The higher the surface area of a heat exchanger, the more effectively it can transfer heat. Creating a high-efficiency metal heat exchanger in a compact form factor is challenging when using traditional manufacturing techniques.
Additive manufacturing makes it possible create parts with novel internal geometries that would be difficult or impossible to create otherwise.
This concept part is a three-to-one compact, single-piece heat exchanger for thermal management in the smallest possible form factor.
The optimized internal geometry of the part allows for massively increased efficiency over a heat exchanger using a traditional design such as a shell and tube or a plate-based heat exchanger.
Print time | Weight | Cost | |
31 hours 39 minutes | 877 g | $130.30 |
The internal curved fin geometry of this part was designed to maximize the surface area of the model, therefore increasing its heat transfer capabilities. The part has little-to-no overhangs, so no structural support material is required.
The result is a part that would be reliable and easy to print, while also being easier to post-process. As it is printed in metal, it would also have no problem operating at the high temperatures this part would be subject to.
This part showcases the many ways metal 3D printing can achieve breakthrough results in the production of small parts and components.
Meet the Metal Expansion Kit
