6月 30, 2025If your company is involved in producing or manufacturing goods, chances are you’ve faced delays due to missing or broken parts - whether it’s jigs, fixtures, or custom tools. Traditionally, sourcing these parts from third-party suppliers can lead to extended downtimes, increased costs, and unnecessary stockpiling.
Many industries are turning to additive manufacturing (AM) - commonly known as 3D printing - as a smart, flexible solution. With 3D printing, companies can produce parts in-house and on demand, drastically reducing lead times and improving agility on the factory floor.
So, how can your organization begin integrating additive manufacturing into existing workflows?
Here’s a practical, step-by-step guide to help you get started:
Start by identifying the right person to lead your additive manufacturing efforts. This could be an engineer, technician, or production manager with an interest in 3D printing, or someone already experimenting with the technology.
Your subject matter expert will act as the internal champion for AM, bridging the gap between departments, understanding technical needs, and driving the implementation forward. Having a go-to expert ensures smoother adoption and better communication across teams.
Next, assess where 3D printing can bring the most value to your operations. Common starting points include:
Look for use cases that are high-cost, time-sensitive, or frequently in need of modification. This will help you build a solid business case and demonstrate ROI early on.
Once your use cases are clear, select a 3D printer that aligns with your goals. Consider:
Materials play a key role in part performance. Depending on your application, you may need engineering-grade polymers, composites, or flexible filaments. The right combination of hardware and material unlocks reliable, repeatable results.
If you are looking for a reliable printer made in Europe, where quality meets speed, UltiMaker S6 might be suitable for your needs.
Additive manufacturing enables rapid iterations, so take advantage of it. Once you’ve selected your printer and material, start designing or importing 3D models for your chosen use cases. Many parts can be reverse-engineered or adapted from existing files.
Expect to go through a few iterations - this is part of the process. Test, gather feedback, and refine designs as needed to ensure parts perform as intended in real-world conditions.
Want to learn more about how 3D printing can be benefical in prototyping? Read our free guide on rapid prototyping
To make additive manufacturing sustainable in the long term, share knowledge and build buy-in across departments. Offer training sessions for designers, engineers, and operators so they understand the benefits and basics of 3D printing.
Encourage experimentation and create a system for submitting ideas or requests. The more people see what’s possible with AM, the more use cases will emerge.
Adopting 3D printing doesn’t have to be complicated. With UltiMaker S6, you get easy access to the whole UltiMaker ecosystem and fast prints without compromising quality. The new S6 comes with:
Backed by Cura Cloud, UltiMaker Digital Factory, and hundreds of validated materials, the S6 is a versatile, open option that delivers first-class productivity without compromising the rock-solid reliability your workflow demands.
