Using Ultimaker Cura 3D printing software
Try it today and share your feedback
ニュース
The beta version of Ultimaker Cura 4.9 has landed. The release contains a bundle of bug fixes and feature improvements – including several to print visualization – increasing software stability, and further simplifying and streamlining print preparation as you continuously strive for first-time right results.
Under the microscope
Several new features provide a better, more detailed visual representation of how a model is printed, making it a snap to fine-tune settings and improve first-time right. They include:
  • “Line type” is now the default color scheme. This improves your user experience – as you will no longer have to manually switch to “line type” each time you enter Preview mode
  • An indicator now clearly shows a print’s starting point
  • The Z-seam is now clearly indicated in Preview mode. This ensures that you will know whether the seam will be sufficiently hidden in the end product
Thanks to BasF0 for contributing to this feature.
Z-seam clearly indicated in print
The 'Z-seam' (shown in white) is a small mark visible on each layer of some prints caused by the extrusion process
More new features
Other new features and fixes in Ultimaker Cura 4.9 beta include:
Simplified Ultimaker Cura onboarding. A new sign-in flow makes it easier than ever to get started with Ultimaker Cura – plus feature highlights, so you can immediately check out what’s new!
Weight estimation in decimals. This provides a more detailed idea of the amount of material used – which is especially useful for smaller prints.
More accurate weight estimations in Ultimaker Cura
See more accurate material weight estimations with decimal places
18 printer definitions added for third-party printers. This makes Ultimaker Cura more accessible to community users.
Bug fixes
The following bug fixes are available in Ultimaker Cura 4.9 beta:
“Connect top/bottom polygons” setting. We have fixed a bug in which this setting was unintentionally hidden when initial layer bottom layers are set to “concentric”.
Ultimaker Cura not slicing. We have fixed a bug causing Ultmaker Cura not to slice a model if one sub-model of a group was below the build plate
Security patch. Fixed a security vulnerability on Windows permitting the openssl library used to launch other programs. Thanks to Xavier Danest for raising this bug.
Want more information on new features, bug fixes, and more for Ultimaker Cura 4.9 beta? Visit our GitHub page for a full overview.
Try it now and share your feedback
Discover other exciting developments by downloading the Ultimaker Cura 4.9 beta today. Beta releases are all about user feedback, so don’t forget to give us yours on our community of 3D printing experts.
Download the beta
Level-up your slicing skills
