11月 28, 2023In this article, we will take a look at some of the new features of Cura that you can look forward to in this 5.6 stable release. Including, the long-awaited support for Method series printers, as well as additional settings that now let you control the base of your prime towers. Additionally, since the previous 5.5 release, the Cura team has leveraged the engine plugin capabilities introduced in that release to create a new plugin that gives you a bunch of new infill options!
Local slicing
Extensive settings selection.
The following improvements have also been implemented in the Cura 5.6 stable release:
DOWNLOAD NOW
