Cura Method series S series
The Cura 5.10 beta introduces the UltiMaker S8, 3D mouse support, and more!
3월 11, 2025
The Cura 5.10 beta release is here, and it brings support for the new Ultimaker S8, as well as new materials and profiles for previously supported UltiMaker printers. In addition, you can now control your models in Cura using a 3D SpaceMouse and more!
Support added for the new UltiMaker S8
The super-productive UltiMaker S8 was just announced and is now supported in Cura. The S8 is the newest professional desktop printer in the S series, and it achieves up to 4x the speed of its predecessor while also improving print quality. That is possible thanks to the new UltiMaker Cheetah motion planner and new high flow cores, all of which will be usable at launch with Cura!
Interact with your object using the 3D SpaceMouse by 3Dconnexion
New materials and intent profiles for UltiMaker and MakerBot printers
Several new intent profiles have been added in this release. All UltiMaker Method printers now have ‘High Speed’ and ‘High Speed Solid’ profiles, while the Sketch Sprint now has ‘Visual’, ‘Extra Fast’, and ‘Draft’ profiles.
In addition, Method X and XL printers both have new material profiles for the PC-ABS and PC-ABS-FR materials. All S series printers also now have support for the Nylon Slide material and all Sketch printers have a new Metallic PLA material profile.
Lastly, the MakerBot Replicator+ printer is also now supported in Cura!
Upcoming changes for USB-connected printing
Keep printing over cloud – quick action needed
Additional improvements
The following improvements have also been implemented in the Cura 5.10 beta release:
  • You can now tune the Bottom Surface Skin, like you can tune the Top Surface Skin! You can now tune Extruder, Layers, Line Width, Pattern, Line Directions, Outer Wall Flow, Inner Wall(s) Flow, Flow, Outer Wall Speed, Inner Wall Speed, Skin Speed, Inner Wall Acceleration, Skin Acceleration, Outer Wall Jerk, Inner Wall Jerk, Skin Jerk, and Monotonic Bottom Surface Order
  • Introduced a new Marlin-like Gcode flavor called Cheetah
  • Enabled printing over the cloud with Digital Factory for Sketch Sprint users
  • Moved Interlocking materials settings out of experimental and into expert
  • Upgraded the build system from Conan 1 to Conan 2. Updated documentation is available
  • Added an option to flip the Y-axis translate tool handle in preferences, contributed by @GregValiant
  • Introduced rotation by input & snap angle input, contributed by @GregValiant
  • Added a Purge Lines and Unload Filament Post Processing Script, contributed by @GregValiant
  • Enabled the "Open in Cura" button from Thingiverse to open files in Linux, contributed by @hadess
  • Introduced 3 new configuration options in machine settings for multitool printers, contributed by @TheSin-
  • Significantly improved the Search and Replace post-processing plug-in with features like replacing only the first instance, limiting search to a layer range, and ignoring start-up or ending G-code, contributed by @GregValiant and @FieldofView
DOWNLOAD NOW
