Explore our support content
Pricing or financing options
Press and general inquiries
11월 10, 2023The beta release of UltiMaker Cura 5.6 has arrived and it brings prime tower improvements and support for Method series printers! Also, since the last update, the Cura team has released a new plugin that makes use of the engine plugin capabilities unlocked in Cura 5.5. Read on to find out more!
Local slicing
Extensive settings selection.
The following improvements have also been implemented in the Cura 5.6 beta release:
DOWNLOAD NOW
