Azoth
Driving the transformation of physical to digital inventory with additive manufacturing
Aliza Sterling
Industrial goods
End-use parts
Manufacturing aids
Azoth has built a new business helping manufacturing customers have machine parts right on time, while saving thousands of dollars.
When engineers get enthusiastic on the topic of additive manufacturing, it can be compelling. Indeed, in the presence of Cody Cochran, Azoth’s general manager, and Ronnie Sherrer, polymers engineering lead at Azoth, you can’t be anything but a fan. Their expertise and energetic approach have been successful in consistently delivering new value propositions to their manufacturing customers through the intelligent application of additive manufacturing and 3D data for end-use parts.
Additive manufacturing and materials have recently evolved to the point where many end-use parts can be produced tool-free and at a lower cost than traditional methods. According to Cochran, it is all about identifying parts in their customers’ inventories that meet the specifications and having a clear business case. Then they are evolved into a digital inventory for immediate, on-demand part production.
“Not all parts are ideal for additive,” said Cochran. “We sort through and find where the complexities are in the supply chain, the overload of inventory, where parts often fail, and build a business case for each one.”
Azoth was formed by the EWIE Group of Companies (EGC) to bring the advantages of additive manufacturing to its customer base. EGC focuses on fulfilling the indirect manufacturing needs of its Fortune 500 customer base across 12 countries, with customers such as John Deere, GM, and Ford. Azoth also focuses on those indirect needs by applying additive manufacturing to machine parts.
Azoth have achieved significant part cost reductions for customers, reduced inventory, and Significant part cost reductions for customers streamlined parts supply
The Azoth Approach
As customer engagement begins, the team at Azoth takes a methodical approach by working through their inventories and initially identifying machine parts that are overstocked as a result of minimum order quantities or that are often out of stock because of lengthy production lead times of five to 10 weeks—or longer. The team then goes on to identify parts that have a high failure rate or that need some re-engineering for greater efficiency. All of these parts are wasting their customers’ money, wasting time, and causing unnecessary complexity in the supply chain.
The Azoth team is equipped with 3D scanners and software so that parts without CAD data can be reverse-engineered and then re-engineered, if necessary, to improve mean time between failure (MTBF). Material analysis is applied, as well as an understanding of the tolerances in play. And asa part is validated, an analysis of cost—including post-processing, material, build times, and part size—is delivered.
Selecting the right 3D printer and materials is also part of this equation. Azoth uses both metal and plastic additive manufacturing and is particularly reliant on its Ultimaker 3D printers in this process. The Ultimaker systems use fused filament fabrication (FFF) technology and are compact enough to fit on a desktop while delivering generous build sizes: The S3 offers a build size of up to 230 x 190 x 200 mm and the S5 can build up to 330 x 240 x 300 mm—both with dual material extrusion and layer thicknesses as small as 20 microns.
“The materials and the printers from Ultimaker are key in this process,” said Cochran. “The low cost of operation, the high-quality materials, have made our success possible—providing significant cost reductions for our customers.”
The team also looks at metal parts to see if they can be produced more efficiently in plastic while maintaining tolerances and performance.
“The Ultimaker materials are less expensive and often outperform traditional plastics, and even some metals,” said Cochran. “With some gripper finger parts that were originally machined from metal, we took the cost from $350 down to $75 per part by re-engineering them for plastic additive production. And they maintained performance.”
Aluminum gripper fingers converted to 3D printed polymer gripper fingers, designed with added hardened dowel pins
The types of parts that the Azoth team analyzes include jigs and fixtures, gripper fingers, blow-off nozzles, gage handles, and more. They look for parts that will benefit from being produced additively, and with no tooling, tool setup, or minimum order quantities, amazing time and cost savings can be made.
“The average person wouldn’t find these parts sexy in any way,” said Cochran, “but these are the workhorse parts that enable production to continue. We work to eliminate machine downtime on our customers’ shop floors, reduce complexity, reduce cost, and shrink physical inventory. And we have been successful at it!”
Azoth increased performance by designing a nozzle that hits the part exactly where it should – previously this was unable to be manufactured
Take One, Make One
Once the customer’s digital inventory is in play, Azoth uses a model it calls “Take One, Make One.” This is a direct form of on-demand production where as soon as a replacement part is taken, a new part is made. Azoth operates this through synchronization with parts vending machines and ERP/MRP systems that send an order to Azoth’s competency center. The new part is typically built and shipped within 24 hours.
"The vending machine implementation can generate instant work orders,” said Sheerer. “This means that the customer maintains a limited inventory driven by actual usage and not based on random requirements, such as minimum order requirements. This saves money and increases efficiency for the manufacturer.”
Dynamism, a provider of 3D printing solutions, materials, and consulting expertise located in Chicago, Illinois, was a key collaborator in the company’s TOMO initiative. The Azoth team was introduced to the Ultimaker platforms by Dynamism, and both teams maintain a strategic relationship to push the boundaries of 3D printing.
“The continual support, expertise, and creativity from the Dynamism team allows us to meet the needs of our customers,” said Cochran. “Their help means we can always offer the best solutions, materials, and outcomes.”
This automotive fixture is 3D printed with magnet inserts for self-locating the component
In the event of running out of inventory of a steel injector pin, a polymer replacement can be 3D printed in two days
The results
Each part produced by Azoth is delivered with a proven business case for the customers. Depending on the part, the business case can be quite different.
“Our approach disrupts the status quo in a positive way for our customers,” said Sheerer. “When we transitioned a simple wear pad part to additive with Ultimaker, it resulted in $30,000 in cost savings for the customer. That is what we call a business case.”
The ability to rapid prototype parts is also a part of the work done by the Azoth team. For some prototype cutter parts, the customer would typically have them CNC machined in steel, which took 12-14 weeks. The Azoth team had plastic prototypes that could be used for a direct, accurate fit and checked within one day. Azoth’s results speak for themselves. They are regularly achieving cost reductions of 50-90%.
The lead time for this prototype cutter part is one day with 3D printing, compared to 12-14 weeks with CNC machining
“With one gripper finger part, we produce about 30 a month at about half the cost of the traditionally manufactured part,” said Cochran. “We tested the new part with SLS nylon, SLA-based resin, but ended up using the PA 4035 on the Ultimakers. It replaced Delrin, and that’s a tough, workhorse material in our world.”
The Azoth team is also able to produce emergency parts to help reduce machine downtime. One example was of a tool steel injector pin that ran out in inventory. The team had a polymer replacement pin in 48 hours, whereas the 3D metal replacement took a week.
Azoth are able to produce 30 of these gripper fingers for end of arm tooling each month with Ultimaker 3D printers
With the tools and expertise, the Azoth team is also able to re-engineer parts for better performance. Complex blow-off nozzles with designs that accurately target the air flow are great examples—and are simple to produce with additive manufacturing.
The Azoth team has proven to itself and its customers that additive has a valuable and important place in the manufacturing supply chain, and both Cochran and Sherrer are keen to continue to lead, innovate, and help customers be more successful.
“Daily, we are changing mindsets within our customers as we deliver valid business cases on their parts inventory using additive manufacturing,” said Cochran. “With Ultimaker 3D printers and materials, the cost is right—they offer easily scalable production and a reliability that we couldn’t have anticipated.”
Azoth: Driving the transformation of physical to digital inventory with additive manufacturing
Azoth builds a new business helping manufacturing customers have machine parts right on time while saving thousands of dollars.
Industrial goods
End-use parts
Manufacturing aids
NavVis: Rapid prototyping wearable scanners with 3D printing
Discover how two industrial designers at NavVis used rapid prototyping and 3D printing to validate their breakthrough design for a professional wearable indoor scanner.
Product development
Metro Plastics: Injection mold company looks to 3D printing to solve bottlenecks
With the always-on productivity of the Ultimaker S5 Pro Bundle, Metro Plastics found a solution to their long lead times, while saving up to 90% on manufacturing parts.
Industrial goods
Manufacturing aids
End-use parts
Van Amersfoort Racing: 3D printing when every second counts
Success hasn’t stopped Van Amersfoort Racing from finding new ways to literally put it ahead of the competition. That’s why the team has begun to utilize 3D printing.
Automotive / aviation
Manufacturing aids
End-use parts
ERIKS: Working clean, certified, and in control with 3D printing
ERIKS offers technical components and related services to all sections of industry. By adding 3D printing technology to its workflow, the company is able to provide its customers with a service that holds the potential to shake up industries around the globe.
End-use parts
Industrial goods
Manufacturing aids
ZEISS: 3D printing precision parts for serial production
Carl Zeiss Optical Components uses Ultimaker printers to create adapter plates customized to its industrial microscopes and capable of serial production.
End-use parts
Industrial goods
Kootenay-Columbia Schools: 3D printers teach lessons in creativity and resilience
Kootenay-Columbia School district uses 3D printing to provide new learning opportunities, sparking creativity, imagination, and engagement across subjects and grade levels.
Education
Product development
Industrial goods
End-use parts
Architecture
Consumer goods
End-use parts
Industrial goods
Medical
Industrial goods
Manufacturing aids
Manufacturing aids
End-use parts
Architecture
Industrial goods
Product development
Product development
Consumer goods
Product development
Consumer goods
Product development
Architecture
Education
Industrial goods
Product development
The Ultimaker S5 is here
Consumer goods
Product development
Medical
Education
End-use parts
Consumer goods
Consumer goods
Product development
Education
Industrial goods
Product development
Product development
Consumer goods
Consumer goods
Product development
Architecture
Education
Architecture
Education
Education
Consumer goods
End-use parts
Industrial goods
End-use parts
Consumer goods
Product development
Tucci Hot Rods: 3D printing final custom car parts
Tucci Hot Rods uses 3D printing to create custom car parts for its vehicle modification projects. The 3D printed parts can be made in a couple of hours and - after a bit of post-processing - will be used as a final part on the custom cars.
End-use parts
Rapid design iterations for the early project stages
Honeybee Robotics is a design and engineering solutions firm known for contributions of critical planetary analysis technology to NASA’s past three Mars missions. Their designs are “destined for work on Earth, Mars, and beyond.” Their work extends to other industries as well, leveraging hard-fought...
Industrial goods
Product development
Volkswagen Autoeuropa: Maximizing production efficiency with 3D printed tools, jigs, and fixtures
Learn how Volkswagen Autoeuropa is using 3D printing to maximize assembly efficiency. By using 3D printed manufacturing aids the company reduces cycle time operation, labor, and the need for reworking, while improving tool ergonomics.
Manufacturing aids
print+: 3D printed DIY headphones
print+ is a product line of DIY kits that allows consumers to build and customize their own headphone. As the mechanical parts can be 3D printed locally, less material needs to be shipped - reducing costs and lowering environmental impact.
Consumer goods
End-use parts
Faster, more accurate dental models
Using 3D printing technology, OpLab can quickly and easily create physical models of dental arches, reducing time, labor, and expenses in the process. The new approach means the team can achieve greater model accuracy, resulting in less error and a better service for their clients.
Medical
Cardiff University: Accessible 3D printed microfluidic devices
The 3D printed microfluidic devices developed by researchers at Cardiff University offer a cost-effective alternative to the traditional ones, which are expensive and require specialized skills and equipment.
Education
End-use parts
Rapid prototyping to solve 21st century problems
Native Union used their Ultimaker 3 to rapidly prototype parts and mechanisms for their latest device designed to resolve a common 21st century issue, making messy USB charging cables a thing of the past.
Consumer goods
Product development
3D printing in landscape architecture and pool design
3D printing is changing the face of architectural design. Discover how landscape designers are transforming outdoor spaces into memorable locations that allow people to fully engage in their surroundings, while making a positive impact on the environment.
Architecture
Open Bionics: 3D printed prosthetic limbs
Using an Ultimaker 3D printer, Open Bionics is developing tailor-made 3D printed prosthetics at a fraction of the cost of traditional ones. Read all about their remarkable story here.
Medical
3D printing in furniture design
3D printing can be used to create virtually anything. Designer Jon Christie used his Ultimaker 3D printer to create some impressive 3D printed furniture, which offers flexibility and reduced costs. Learn more here.
Consumer goods
Product development
Inholland University: Building a 3D printed rocket
Students at Inholland University of Applied Sciences use 3D printing to design and build rockets as part of their course in aviation technology. Read on and download a ready-to-use lesson plan to include 3D printing in your school's educational program.
Education
Vathorst College: Integrating 3D printing in high school education
Creative STEM projects allow students to expand their knowledge and develop basic 3D printing skills. Read on for lesson plans that focus on both science and mathematical applications.
Education
Eventuri: Functional and fit testing of performance car intakes
With 3D printing companies like Eventuri can be flexible in their design process, run quick iterations and perform functional and fit testing of their 3D printed car intakes in a short period of time.
Product development
MATT Architecture: Rapid model making with 3D printing
MATT Architecture creates architectural models in central London. They use 3D printing to quickly reiterate the models they are working on, which saves a lot of time and development costs.
Architecture
Changing lives in developing countries with 3D printed prosthetics
The Victoria Hand Project creates customized prosthetic hands for amputees in third world countries – using Ultimaker 3D printers to make the process more efficient and cost-effective.
Medical
Using Ultimaker to cast silicone for soft robotics
Using their Ultimaker 2+ 3D printer, students from Delft University of Technology have discovered a way to cast silicone for soft robotics. This has huge implications for soft actuators, and for the medical sector. Read on to learn more.
Education
Product development
Henchmen Props: 3D printed props workshop
Henchmen Props creates props and costumes for industry-leading video game companies like Blizzard and Respawn. 3D printing has allowed them to greatly reduce their production times and rapidly prototype new parts.
Product development
Teaching STEM with 3D printed bottle rockets
There are many ways in which 3D printing can be used to enhance the students' learning experience in modern-day primary education. Discover how 3D printing can boost learning here.
Education
The Ultimaker 3: Behind the scenes
3D printers let product designers and engineers test, evaluate and improve their ideas. Even more importantly, they’re a powerful tool for various professional applications. Read on to find out how we developed the Ultimaker 3.
Product development
Bringing the Ultimaker 3 to market with bridge manufacturing
Ultimaker 3 has proven to be a reliable solution for businesses. Learn how bridge manufacturing helps you launch products on time, with a 3D printer that's primed to deliver results.
Industrial goods
End-use parts
Functional prototyping at ABB Robotics
3D printing gives businesses around the world the opportunity to save time and money. ABB Robotics turned to the Ultimaker 2 Extended+ for making prototype fingers for their robot YuMi, bringing new opportunities to the company.
Industrial goods
Product development
Breaking barriers in education with 3D printing
With a desktop 3D printer, teachers can empower their students to design, collaborate, and create amazing things they never thought possible. But what is it actually like to have a 3D printer in the classroom?
Education
From a market-tested prototype to an eye-saving game-changer
oDocs Eye Care Kit has the potential to save millions from blindness. But this wouldn’t be possible without functional prototyping. And 3D printing is the most accurate, not to mention time and cost-effective, way to achieve it.
Medical
3D-powered prototyping by the Bhold Studio
How far can you get with a dream and a 3D printer? You can think of the most sophisticated forms and textures, turn them into successful products and blaze through prototyping and production at lightning speed.
Consumer goods
Product development
Surgical planning using 3D printed bone models
Professional 3D printers are now being actively used by healthcare professionals not only to educate patients about their condition, but also to plan complex surgeries – even using the models during the operation as a guide.
Medical
3D printing a Tyrannosaurus rex skeleton
To build a 13 meter long T. rex skeleton, Naturalis turned to 3D printing. Thanks to the incredible accuracy and flexibility of the Ultimaker 2+, the skeleton will be restored in even greater detail than initially anticipated.
Education
Developing sustainable fuel with Team FAST
Using their Ultimaker 3D printer, Team FAST was able to design and print custom mounts and fittings for their car prototype fueled with formic acid.
Education
Using 3D printed shapes to create food molds
3D printing shapes and prototypes for food-safe molds is becoming a popular 3D printer application in the food industry that allows entrepreneurs to escape the demands of industrial-sized production runs.
Consumer goods
Product development
Saving eyesight with a 3D printed eye examination kit
oDocs Eye Care creates open source medical equipment for eye diagnoses. Using 3D printing, they developed a cost-effective and accurate eye examination kit to help diagnose treatable and preventable blindness.
Medical
End-use parts
Using Ultimaker 3D printers for manufacturing at Siemens
Learn how Siemens Rail Automation are using their Ultimaker 3D printers to assist in prototyping of new components and products, as well as manufacturing end-use parts.
Industrial goods
Product development
Project Seafood, creating waves of change on our shores
Desktop 3D printing allows anyone to transform ideas into tangible products in a matter of hours. This is a story of a couple who took their Ultimaker Original out for a spin in their mini-van to make a better world.
Product development
Architects use 3D printing to prototype huge city project
To help bring their ideas to life Sweco architects needed a rapid prototyping tool they could rely on every day to create models with tight deadlines. So they turned to 3D printing.
Architecture
The Olsson Block - a community invention by Anders Olsson
We're proud to say that an essential part of the Ultimaker DNA is our strong community. we’d like to highlight the work of an ingenious community member called Anders Olsson, the man who gave us the Olsson block.
Education
Product development
The world's fastest 3D printed R/C car
What do you do when you want to build the world's fastest radio controlled car? Build it yourself! Read this story to find out how one man designed and created a 3D printed RC car from scratch.
Product development
3D printing in education for inspirational learning
More and more, 3D printing is being used in education. Teachers use 3D objects to help primary school kids grasp concepts, refine students' creative skills in high school and help them learn technical subjects at university.
Education
100% recycled filament from Perpetual Plastic Project
At this moment there are huge amounts of waste plastic, and only 10 to 12% of it is being recycled. The team behind the Perpetual Plastic Project is looking to change the world by reducing the amount of plastic.
Consumer goods
Product development
Meet Luke and his 3D printed e-NABLE hand
With a global network of over 5,000 volunteers, the e-NABLE foundation designs, creates, and donates their 3D printed hands free of charge to children and adults using Ultimaker 3D printers.
Medical
3D printed and prototyped shoes by Julian Hakes
Learn how fashion designer Julian Hakes brought his award-winning Mojito Shoe to life. With his Ultimaker 3D printer, he was able to create multiple prototypes in-house and perfect his designs.
