Steven van de Staak
Consumer goods
End-use parts
With over 150 breweries around the world, Heineken is one of the largest global producers of beer. One brewery in Seville, Spain, produces famous brands such as Cruzcampo, Desperados, Heineken, and Amstel. The beer is brewed, packed, and then shipped throughout Spain and beyond. Packaging Manager, Juan Padilla González has implemented 3D printing to increase uptime and efficiency at the Seville brewery.
The Seville plant is able to produce up to 500 million liters of beer per year. But Heineken is always looking into new ways to improve their already impressive efficiency. That’s why they started to investigate the possibilities of 3D printing.
After setting up a 3D printing lab, the team set goals to improve the manufacturing process in terms of output, uptime, and safety. Heineken started looking for various methods of optimizing the manufacturing machines. They quickly realized that 3D printing gives them the flexibility and speed they need, while still being affordable and easy to implement.
We’re still in the first stages of 3D printing but have already seen a reduction of costs in the applications that we found by 70 - 90%, and also a decrease of delivery time of 70 - 90%.
Safety first
Employee safety is the top priority within Heineken, and they first designed improved safety latches, which are used during machine maintenance. These are applied to almost all the machines in the brewery. When the machines are stopped, these latches will be locked, preventing anyone from accidentally starting a machine while someone is doing maintenance.
The latches are printed in bright red to ensure their visibility. This application was not only useful, but the extra safety feature created awareness and appreciation of 3D printing among employees.
Heineken's custom 3D printed key depository
3D printed safety lock preventing machines from starting up during maintenance
Functional parts for the manufacturing line
After the initial success of the safety latches, other 3D printed application opportunities were identified.
Ideas were investigated, and new parts designed. The first of these was to print spare parts that had proven difficult to replace. Outsourcing discontinued parts or importing them is expensive and time-consuming. The team immediately saw that 3D printing these not only saved time and money, but was also able to print plastic parts which could function as structural replacements for metal parts.
3D printed functional parts remove the design constraints associated with traditional manufacturing processes
3D printed functional replacement parts can be created without stock
Optimizing part designs
The great thing about 3D printing is that it’s easy to iterate designs to perfection. An engineer can rapidly create alternative designs and test parts on-site, all while keeping cost and production times relatively low. Plastics are lighter than most metals, and are relatively strong when the right design principles and materials are applied. It’s also very easy to redesign parts to work even better, without the constraints of outsourcing.
At the Seville brewery, Juan’s team was able to replace various redesigned parts with an optimized design. For example, a metal part used with a quality sensor on a conveyor belt would often knock bottles over, creating a blockage, or ejecting good bottles onto the ground. Redesigned 3D printed parts prevented this problem, saving bottles, money, and time.
Heineken optimized the conveyor belt bottle guide with 3D printed parts so that blockages are prevented
Tools for quality control and maintenance
Companies commonly 3D print custom tools, jigs, and fixtures. Heineken has made various tools to make maintenance easier and faster on their machines. These tools are usually printed from Tough PLA, which is easy to print, with similar strength and flexibility to ABS. One of these tools is the stopper tool, which loosens and tightens the columns of guiding wheels that apply bottle labels. Before adopting 3D printing, this tool had to be custom made using CNC machining.
With 3D printing, the tool’s production cost was reduced by 70%, and delivery time from three days to one day. A simple tool like the toroidal rubber cutter is printed in under an hour, which on average takes over 10 days to deliver when outsourced.
3D printed tools make maintenance easier and less time consuming
3D printing enables Heineken to create custom quality check tools
Choosing the right material
Ultimaker’s range of materials has proven useful to Heineken Spain. Many of the printed parts will endure stress, high temperatures, moisture, or numerous impacts over a long period of time. That’s why having the right materials for applications is so important.
Heineken Spain makes use of a variety of Ultimaker materials such as Tough PLA, Nylon, and semi-flexible material TPU 95A. These materials have excellent mechanical properties to withstand the wear and tear of the manufacturing line. Tough PLA is often used for pushers and tools, while Nylon is used for parts that need to function with metal parts. TPU 95A’s flexibility is ideal for bumpers and protective parts.
Parts are being developed and printed in Heineken's 3D Lab
Initial pilot plant results
After using Ultimaker S5 printers in Seville for a year, Heineken considers the pilot project a success. The results of increased employee safety, lead time, and cost reduction of all printed parts have added to that.
By 3D printing functional end-use parts for the manufacturing line on-demand, Heineken was able to optimize the functionality and on time availability. By adjusting the design of functional machine parts, Heineken has increased line efficiency. The custom tools have made performing maintenance and production changeovers considerably easier and faster for employees.
On average, Heineken sees the delivery of all the required parts is on average 80% faster than external sourcing. The costs of a printed part versus a historically sourced part are also on average 80% lower.
3D printing has proven to be a technology that helps us, brings value to us, and enables our people to work more efficiently
Global adoption of 3D printing
Seville’s success with 3D printing has not gone unnoticed. The company is setting the next steps to identify the potential of scaling the benefits of 3D printing. Additive manufacturing enables engineers and other employees to look at challenges and opportunities from different perspectives.
Designs and solutions can be easily shared over the network. This accelerates the global deployment of new applications because parts can be sent digitally rather than physically. It also avoids international freight costs and reduces transportation movement, in turn reducing environmental costs.
Want to discover how 3D printing can help your business? Download our food and beverage manufacturer's playbook to identify your own applications and get inspired by more industry-proven examples, or request a custom quote today.
Azoth: Driving the transformation of physical to digital inventory with additive manufacturing
Azoth builds a new business helping manufacturing customers have machine parts right on time while saving thousands of dollars.
Industrial goods
End-use parts
Manufacturing aids
NavVis: Rapid prototyping wearable scanners with 3D printing
Discover how two industrial designers at NavVis used rapid prototyping and 3D printing to validate their breakthrough design for a professional wearable indoor scanner.
Product development
Metro Plastics: Injection mold company looks to 3D printing to solve bottlenecks
With the always-on productivity of the Ultimaker S5 Pro Bundle, Metro Plastics found a solution to their long lead times, while saving up to 90% on manufacturing parts.
Industrial goods
Manufacturing aids
End-use parts
Van Amersfoort Racing: 3D printing when every second counts
Success hasn’t stopped Van Amersfoort Racing from finding new ways to literally put it ahead of the competition. That’s why the team has begun to utilize 3D printing.
Automotive / aviation
Manufacturing aids
End-use parts
ERIKS: Working clean, certified, and in control with 3D printing
ERIKS offers technical components and related services to all sections of industry. By adding 3D printing technology to its workflow, the company is able to provide its customers with a service that holds the potential to shake up industries around the globe.
End-use parts
Industrial goods
Manufacturing aids
ZEISS: 3D printing precision parts for serial production
Carl Zeiss Optical Components uses Ultimaker printers to create adapter plates customized to its industrial microscopes and capable of serial production.
End-use parts
Industrial goods
Kootenay-Columbia Schools: 3D printers teach lessons in creativity and resilience
Kootenay-Columbia School district uses 3D printing to provide new learning opportunities, sparking creativity, imagination, and engagement across subjects and grade levels.
Education
Product development
Industrial goods
End-use parts
Architecture
Consumer goods
End-use parts
Industrial goods
Medical
Industrial goods
Manufacturing aids
Manufacturing aids
End-use parts
Architecture
Industrial goods
Product development
Product development
Consumer goods
Product development
Consumer goods
Product development
Architecture
Education
Industrial goods
Product development
The Ultimaker S5 is here
Consumer goods
Product development
Medical
Education
End-use parts
Consumer goods
Consumer goods
Product development
Education
Industrial goods
Product development
Product development
Consumer goods
Consumer goods
Product development
Architecture
Education
Architecture
Education
Education
Consumer goods
End-use parts
Industrial goods
End-use parts
Consumer goods
Product development
Tucci Hot Rods: 3D printing final custom car parts
Tucci Hot Rods uses 3D printing to create custom car parts for its vehicle modification projects. The 3D printed parts can be made in a couple of hours and - after a bit of post-processing - will be used as a final part on the custom cars.
End-use parts
Rapid design iterations for the early project stages
Honeybee Robotics is a design and engineering solutions firm known for contributions of critical planetary analysis technology to NASA’s past three Mars missions. Their designs are “destined for work on Earth, Mars, and beyond.” Their work extends to other industries as well, leveraging hard-fought...
Industrial goods
Product development
Volkswagen Autoeuropa: Maximizing production efficiency with 3D printed tools, jigs, and fixtures
Learn how Volkswagen Autoeuropa is using 3D printing to maximize assembly efficiency. By using 3D printed manufacturing aids the company reduces cycle time operation, labor, and the need for reworking, while improving tool ergonomics.
Manufacturing aids
print+: 3D printed DIY headphones
print+ is a product line of DIY kits that allows consumers to build and customize their own headphone. As the mechanical parts can be 3D printed locally, less material needs to be shipped - reducing costs and lowering environmental impact.
Consumer goods
End-use parts
Faster, more accurate dental models
Using 3D printing technology, OpLab can quickly and easily create physical models of dental arches, reducing time, labor, and expenses in the process. The new approach means the team can achieve greater model accuracy, resulting in less error and a better service for their clients.
Medical
Cardiff University: Accessible 3D printed microfluidic devices
The 3D printed microfluidic devices developed by researchers at Cardiff University offer a cost-effective alternative to the traditional ones, which are expensive and require specialized skills and equipment.
Education
End-use parts
Rapid prototyping to solve 21st century problems
Native Union used their Ultimaker 3 to rapidly prototype parts and mechanisms for their latest device designed to resolve a common 21st century issue, making messy USB charging cables a thing of the past.
Consumer goods
Product development
3D printing in landscape architecture and pool design
3D printing is changing the face of architectural design. Discover how landscape designers are transforming outdoor spaces into memorable locations that allow people to fully engage in their surroundings, while making a positive impact on the environment.
Architecture
Open Bionics: 3D printed prosthetic limbs
Using an Ultimaker 3D printer, Open Bionics is developing tailor-made 3D printed prosthetics at a fraction of the cost of traditional ones. Read all about their remarkable story here.
Medical
3D printing in furniture design
3D printing can be used to create virtually anything. Designer Jon Christie used his Ultimaker 3D printer to create some impressive 3D printed furniture, which offers flexibility and reduced costs. Learn more here.
Consumer goods
Product development
Inholland University: Building a 3D printed rocket
Students at Inholland University of Applied Sciences use 3D printing to design and build rockets as part of their course in aviation technology. Read on and download a ready-to-use lesson plan to include 3D printing in your school's educational program.
Education
Vathorst College: Integrating 3D printing in high school education
Creative STEM projects allow students to expand their knowledge and develop basic 3D printing skills. Read on for lesson plans that focus on both science and mathematical applications.
Education
Eventuri: Functional and fit testing of performance car intakes
With 3D printing companies like Eventuri can be flexible in their design process, run quick iterations and perform functional and fit testing of their 3D printed car intakes in a short period of time.
Product development
MATT Architecture: Rapid model making with 3D printing
MATT Architecture creates architectural models in central London. They use 3D printing to quickly reiterate the models they are working on, which saves a lot of time and development costs.
Architecture
Changing lives in developing countries with 3D printed prosthetics
The Victoria Hand Project creates customized prosthetic hands for amputees in third world countries – using Ultimaker 3D printers to make the process more efficient and cost-effective.
Medical
Using Ultimaker to cast silicone for soft robotics
Using their Ultimaker 2+ 3D printer, students from Delft University of Technology have discovered a way to cast silicone for soft robotics. This has huge implications for soft actuators, and for the medical sector. Read on to learn more.
Education
Product development
Henchmen Props: 3D printed props workshop
Henchmen Props creates props and costumes for industry-leading video game companies like Blizzard and Respawn. 3D printing has allowed them to greatly reduce their production times and rapidly prototype new parts.
Product development
Teaching STEM with 3D printed bottle rockets
There are many ways in which 3D printing can be used to enhance the students' learning experience in modern-day primary education. Discover how 3D printing can boost learning here.
Education
The Ultimaker 3: Behind the scenes
3D printers let product designers and engineers test, evaluate and improve their ideas. Even more importantly, they’re a powerful tool for various professional applications. Read on to find out how we developed the Ultimaker 3.
Product development
Bringing the Ultimaker 3 to market with bridge manufacturing
Ultimaker 3 has proven to be a reliable solution for businesses. Learn how bridge manufacturing helps you launch products on time, with a 3D printer that's primed to deliver results.
Industrial goods
End-use parts
Functional prototyping at ABB Robotics
3D printing gives businesses around the world the opportunity to save time and money. ABB Robotics turned to the Ultimaker 2 Extended+ for making prototype fingers for their robot YuMi, bringing new opportunities to the company.
Industrial goods
Product development
Breaking barriers in education with 3D printing
With a desktop 3D printer, teachers can empower their students to design, collaborate, and create amazing things they never thought possible. But what is it actually like to have a 3D printer in the classroom?
Education
From a market-tested prototype to an eye-saving game-changer
oDocs Eye Care Kit has the potential to save millions from blindness. But this wouldn’t be possible without functional prototyping. And 3D printing is the most accurate, not to mention time and cost-effective, way to achieve it.
Medical
3D-powered prototyping by the Bhold Studio
How far can you get with a dream and a 3D printer? You can think of the most sophisticated forms and textures, turn them into successful products and blaze through prototyping and production at lightning speed.
Consumer goods
Product development
Surgical planning using 3D printed bone models
Professional 3D printers are now being actively used by healthcare professionals not only to educate patients about their condition, but also to plan complex surgeries – even using the models during the operation as a guide.
Medical
3D printing a Tyrannosaurus rex skeleton
To build a 13 meter long T. rex skeleton, Naturalis turned to 3D printing. Thanks to the incredible accuracy and flexibility of the Ultimaker 2+, the skeleton will be restored in even greater detail than initially anticipated.
Education
Developing sustainable fuel with Team FAST
Using their Ultimaker 3D printer, Team FAST was able to design and print custom mounts and fittings for their car prototype fueled with formic acid.
Education
Using 3D printed shapes to create food molds
3D printing shapes and prototypes for food-safe molds is becoming a popular 3D printer application in the food industry that allows entrepreneurs to escape the demands of industrial-sized production runs.
Consumer goods
Product development
Saving eyesight with a 3D printed eye examination kit
oDocs Eye Care creates open source medical equipment for eye diagnoses. Using 3D printing, they developed a cost-effective and accurate eye examination kit to help diagnose treatable and preventable blindness.
Medical
End-use parts
Using Ultimaker 3D printers for manufacturing at Siemens
Learn how Siemens Rail Automation are using their Ultimaker 3D printers to assist in prototyping of new components and products, as well as manufacturing end-use parts.
Industrial goods
Product development
Project Seafood, creating waves of change on our shores
Desktop 3D printing allows anyone to transform ideas into tangible products in a matter of hours. This is a story of a couple who took their Ultimaker Original out for a spin in their mini-van to make a better world.
Product development
Architects use 3D printing to prototype huge city project
To help bring their ideas to life Sweco architects needed a rapid prototyping tool they could rely on every day to create models with tight deadlines. So they turned to 3D printing.
Architecture
The Olsson Block - a community invention by Anders Olsson
We're proud to say that an essential part of the Ultimaker DNA is our strong community. we’d like to highlight the work of an ingenious community member called Anders Olsson, the man who gave us the Olsson block.
Education
Product development
The world's fastest 3D printed R/C car
What do you do when you want to build the world's fastest radio controlled car? Build it yourself! Read this story to find out how one man designed and created a 3D printed RC car from scratch.
Product development
3D printing in education for inspirational learning
More and more, 3D printing is being used in education. Teachers use 3D objects to help primary school kids grasp concepts, refine students' creative skills in high school and help them learn technical subjects at university.
Education
100% recycled filament from Perpetual Plastic Project
At this moment there are huge amounts of waste plastic, and only 10 to 12% of it is being recycled. The team behind the Perpetual Plastic Project is looking to change the world by reducing the amount of plastic.
Consumer goods
Product development
Meet Luke and his 3D printed e-NABLE hand
With a global network of over 5,000 volunteers, the e-NABLE foundation designs, creates, and donates their 3D printed hands free of charge to children and adults using Ultimaker 3D printers.
Medical
3D printed and prototyped shoes by Julian Hakes
Learn how fashion designer Julian Hakes brought his award-winning Mojito Shoe to life. With his Ultimaker 3D printer, he was able to create multiple prototypes in-house and perfect his designs.
