Michael Delaney
Informal learning
Technology
Michael Delaney, a student at Avenues in NYC, writes about his iterative process of integrating electronics and 3D printing in his programmable quadcopter project.
Creating and refining a design through testing is an inherent aspect of making. Over the past several years, the tools and resources that facilitate this process have become readily available, through resources like the internet and digital fabrication. These technologies present a revolutionary method of design and manufacturing, giving rise to incredible new inventions. As a 17-year-old maker and a budding engineer, these developments excite me greatly. Over the course of the last few months, I have been designing and building a programmable quadcopter in an attempt to learn more about systems like PID controllers, I2C communication, and radio transmission.
Throughout this process, I’ve faced repeated challenges with the quadcopter development. While most were trivial, some forced me to reconsider the project as a whole. Using the tools available to me, I have been able to create real solutions for issues, such as measuring the quadcopter’s position and tuning the flight control algorithm. In the end, regardless of the design, the ability to solve these common issues – inherent to any project – will come to define its eventual success.
Today, hobbyists and amateur designers, like myself, can create designs on a computer and turn their most complicated designs into a manufactured product. This is facilitated through revolutionary new services and technologies, from rapid prototyping tools like CNC machines and 3D printers, to professional manufacturing services available through the internet. It was through this widespread accessibility to professional tools that I was able to have my custom-designed quadcopter circuit board (or PCB) fabricated in China for only a few dollars.
Tools in the design process
This project began with lots of ideation and testing of the overall quadcopter design layout. As I planned on doing the majority of the flight controller development at school, I needed a format that was simple, portable, and safe to test in an indoor environment around other students and teachers. These factors restricted the design to a small, light-weight quadcopter that could sustain flight with relatively low-power motors. This design decision helped to ensure the safety of others around me, in addition to reducing the number of self-inflicted scars from the “attack-quadcopter” that emerged as a result of my limited programming experience.
Ultimately, this design helped to reduce the dangers posed by the quadcopter, yet, in testing the basic functionality of the device, a number of issues were discovered that resulted due to the small format. By looking at measurements of the quadcopter’s position with the motors on and off, it became apparent that vibrations produced by the motors prevented the device from accurately measuring its environment. The inaccuracy of these measurements prevented the flight control algorithm (or, more specifically, the PID controller) from making proper adjustments to the flight of the quadcopter.
Solving this issue proved to be a much greater challenge than diagnosing it as the noise from the motors could not be attributed to a single source. This meant that the entire circuit board would have to be isolated from the motors in order to reduce the impact of vibrations on the measurement sensor.
I tested a number of different methods of insulating the motors from the circuit board. My first attempt was based on a simple 3D printed frame that separated the motors from the circuit board. This design also incorporated a layer of rubber as a barrier between the frame and PCB to further reduce the effect of the remaining vibrations.
This first prototype was a significant step forward on the path to making a usable product, and while it greatly helped to mitigate the measured vibrations, the additional weight added by the frame ultimately prevented the quadcopter from lifting off the ground.
Dissatisfied with the outcome of the first prototype frame, I began to reconsider the best approach to making this quadcopter function. I went back to the drawing board, starting from scratch with a new circuit board and frame. Given the challenges with the previous design, the new circuit board incorporated both larger motors and propellers to achieve as much thrust as possible. After a couple of iterations, I ultimately settled on a frame design that mounted the top of the PCB. This helped to protect the sensitive electronics and gave the appearance of a finished product while simultaneously reducing the influence of vibrations on the measurement sensor.
3D printing is a remarkable technology, but one still in the infancy of its development and not without limitations. This method of manufacturing offers many advantages for makers and hobbyists in terms of the rapid production and testing of small parts and models. That being said, in this revised frame design, the large unsupported cavities, or overhangs, on the underside of the model presented several challenges during production. While printing, the heated plastic would sag under its own weight into these cavities for the circuit board, preventing the circuit board from properly fitting into the frame. In the future I intend to take advantage of techniques like using dissolvable support material to aid in fabrication when confronted with similar issues. However, in order to combat this now, I decided to embed the physical PCB into the part during the printing process to act as a type of support while the overhangs were printed. This helped to prevent any serious issues with fitting the circuit board and also ensured proper alignment, but some post-production clean up was still necessary after printing.
Using this new frame design in combination with a digital low pass filter, the quadcopter proved to be capable of dampening most of the disturbances affecting the measurement sensor. This achievement made it possible to move forward to the testing and tuning phase of the development process.
Tools in testing
Having finished the bare bones programming and solved all of the (known) bugs and issues related to the code, I moved on to the next phase of development – testing.
The quadcopter uses information from the sensors and pilot to calculate how fast to spin the motors in order to move to the desired position. This process is handled by an algorithm known as a PID controller – a simple program that determines how to get the quadcopter where it wants to be. The program itself is managed by a set of predetermined values that influence the individual motor speeds. These numbers can be found through laborious testing, but figuring out where to start can be fairly daunting. After hundreds of tests and no significant improvement, I had begun to think that this project wouldn’t become anything more than a fancy paperweight.
A substantial portion of this challenge was due to the fact that I had no relevant data to analyze from the flight of the quadcopter. Having neglected to include any memory for storing information onboard the quadcopter, data could only be acquired through a direct connection over USB, which could not be used in-flight without affecting the flight of the quadcopter.
This caused me to wonder, how might I control and analyze the movement of the quadcopter without it flying away and crashing into the wall?
This question led to the creation of a “PID test jig” – a contraption designed to hold the device in a fixed location, while still allowing it to move freely. Such a design allows for free rotation in all axes without the device physically moving position, making it easier to adjust the quadcopter flight parameters in addition to reducing the number of broken quadcopters that ended up in my electronics graveyard.
This test jig was manufactured and assembled using both 3D printing and laser cutting tools, in addition to a few mechanical parts such as bearings and screws to hold it together. The premise of the design has the quadcopter mounted to an enclosing frame along one axis, joined by a set of bearings, which allow the device to rotate on the corresponding axis. This contraption holding the quadcopter is itself attached to a stand using another set of bearings on the other axis, allowing for rotation in both the X and Y axis. The entire jig can expand and contract using a set of brackets in order to compensate for any variation in the size of the quadcopters being tested. This functionality, as described above, can be seen in the animation below.
This additional tool has helped tremendously in making improvements to my flight controller program, allowing for more accurate testing and less time spent rebuilding broken quads.
Throughout this process, there have been countless times where I wondered whether the project would ever function. Since the first prototypes, I have worked to further develop both the hardware and software of the quadcopter and continued to make changes and seek out new tools and techniques to improve my work as technology evolves.
If you are interested in learning more about this project, check out the full write-up on my website for further details and explanation of the design process.
Naturalis Biodiversity Center: Prehistoric prints, cutting-edge technology
Naturalis Biodiversity Center, the Netherlands’ national natural history museum, is using 3D printing to create both partial and full dinosaur skeletons for public display.
History
Informal learning
Special education
Technology
Informal learning
Technology
Secondary education
History
Informal learning
Art
Harvard calculus courses use 3D printed models to engage students
University
Mathematics
Informal learning
Mathematics
Code your 3D designs with Tinkercad’s new Codeblocks app
Tinkercad released Codeblocks last June, and now that it's out of Beta, Pioneer Rob Morrill tells us how he uses it.
Informal learning
Technology
Modifying an STL with Tinkercad
When Ultimaker Pioneer Alex Larson contacted me about the Ultibot-D project, I was super excited. As a teacher and parent, I am a huge cheerleader for risk. I printed the base models at ⅕ scale and gave it to my students to explore
Primary education
Technology
Math Camp: Having fun doing stuff
Pioneer Dr Toni Szymanski writes about summer fun at camp with 4th and 5th graders, math, and 3D printing.
Primary education
Mathematics
GlitchCraft
Guest blogger Astrida Valigorsky writes about combining the old and the new at Timothy Belliveau's GlitchCraft class where students combined 3D printing and glass blowing.
Informal learning
Technology
Using Basecamp to manage your classroom/makerspace projects and print queue
Pioneer Andrew Woodbridge uses Basecamp to organize his students' projects, and he explains how you can too.
Secondary education
Technology
A unique 3D printing collaboration between mathematics and chemistry faculty
Passing it on. After integrating 3D printing into her own math courses, Kristen Schreck helps spread 3D printing across disciplines at Saint Xavier University.
University
Science
Living world monuments assignment
Pioneer Joanne Barrett shares about a middle school project that combines 3D printing, Augmented Reality, History, and Art.
Secondary education
History
My reintroduction to Netfabb
A recent NetFabb workshop convinced the writer that they can't live without this application. See why it's time to take another look at Netfabb.
Secondary education
Technology
Wrench Engineering
Primary education
Engineering
Pioneer Chris Hanusa shares one way he integrated 3D printing into his Integral Calculus class
University
Mathematics
3D printers in the public library: Finland ahead of the curve
US Professor Joshua Pearce, sponsored by Fulbright Finland for Research, shares his first impressions of Finnish libraries.
Informal learning
Technology
Lessons in letting go - releasing student energy speeds creation and use of our art and innovation lab
Pioneer John Nordell enlisted his students to put the Art and Innovation Lab together. The result was one of the best experiences he has had as an educator.
University
Technology
Teacher training for 3D printing
Pioneer Dr. Toni Szymanski thought that 3D printing could engage students in math classes. To test this out, she had to learn all about 3D printing first.
Secondary education
Mathematics
Digital fabrication informs ceramics decorative process
Pioneer Young Kim blends his classical arts background with digital fabrication to create a ceramic project that incorporates 3D printing.
Secondary education
Art
Modeling rocks at iCREATE
iCREATE's Tiffany Huang shared an iCREATE success story about Jackie Zheng.
Secondary education
Science
Elementary-College Engineering Design partnership
Pioneer Matthew Wigdahl writes about how his fifth graders and local undergraduate engineering students learn from each other.
Primary education
Engineering
Introducing Ultimaker’s Core Lessons Set for STEAM Educators
Designed by the Ultimaker North America Community Team, our new Core Lessons: STEAM Set is a resource for educators who need inspiration and ideas when they bring 3D printing into their classrooms.
Primary education
Technology
Empower one MakerGirl, empower the world
how the group traveled 10,000 miles around the country to help bring 3D printing workshops to over 1,000 young girls. In this week's post we catch up with the organization that is still working to create a new generation of confident, creative women leade
Primary education
Technology
Building a mobile maker space: part 2—up and rolling
So what exactly does a Mobile MakerSpace look like? That's the question I had to ask myself once I began the project of bringing 3D printing technology to virtual students. When we started this project, we knew we needed something that would be easy to
Secondary education
Technology
Building a mobile makerspace: part 1— getting started
Pioneer Wendy Aracich is putting together and implementing a mobile MakerSpace for her virtual school of 4000 students spread across the state of Georgia.
Secondary education
Technology
Tactile Problem/Solution Bank Community Project
3D modeling and printing should be accessible of every educator so that they may offer their students tactile means to understand spatial concepts.
Secondary education
Languages
Design Engine community project
We want to challenge educators and students to help evolve the Design Engine game. We want to see how you're using or modifying the game with your students, and we want to incorporate your ideas into the next edition.
Informal learning
Technology
Upcycling community project
Upcycling challenges students and educators to use their creativity and 3D printing skills to breathe new life into a few familiar objects.
Informal learning
Technology
Construct3D to Kamehameha Ed Tech Conference
Last year Pioneer Greg Kent traveled from Hawaii to North Carolina to attend Construct3D 2017. We thought we'd share his reflections with you now since we recently announced Construct3D 2018
Secondary education
Technology
Ocean Plastic Community Project
The Ultimaker Community Team will be launching a series of interdisciplinary projects over the next few months that challenge students to research, explore, design, and 3D print. Ocean Plastic is the first project of this series.
Secondary education
Geography
3D printed fractals at JMU 3SPACE
Pioneer Professor Laura Taalman, (a.k.a. mathgrrl), reviews a multi-week study of fractals by general education math students in the JMU 3D printing classroom.
University
Mathematics
Using drones and 3D printing to develop design thinking during a summer robotics camp
Pioneer Yuriy Drubinskiy writes about his experience leading a summer program and how creating drones with 3D printing brings form, structure, and design together.
Secondary education
Technology
Introducing the Ultimaker Design Engine Starter Pack
Presenting the Ultimaker Design Engine Starter Pack: a game created to provoke, inspire, and entertain students, educators, 3D designers, artists, and engineers of all experience levels!
Informal learning
Technology
Davidson Desktop Doohickeys: Puzzle cubes
Pioneer Adam Davidson writes about a project in his curriculum that is a rite of passage for his high school's engineering program students. He explains at how it started and what caused it to change
Secondary education
Engineering
3D printing with UMaine Bioengineering students
University
Science
3D printing, Arduino, and Star Wars: A guide to K-12 STEAM engagement
Secondary education
Technology
3D printable molecular models
Tandy Grubbs, Professor of Chemistry, writes about how chemistry students at Stetson University are taking advantage of 3D printing to better visualize the molecular world.
University
Science
Nautilus cam ball launcher
Design process is about discovery through iteration. Pioneer Brad Whitehead describes how his FTC robotics team learned this while working on a unique ball launcher.
Special education
Technology
Animal Adaptations
Primary education
Technology
3D water rockets
Pioneer Tim Cooper explains what to do with a First Lego League team in the off season when they love rockets and 3D printing.
Primary education
Science
Three reasons for open source tech in your 3D printing classroom
Pioneer Joshua Pearce explains why educators should consider using free and open source options in and out of the 3D printing classroom.
University
Technology
Our 3D printing journey in Multivariable Calculus
Here’s a story of the next generation of 3D printing pioneers exploring the 3D printing technology in Multivariable Calculus with the Ultimaker 2+.
University
Mathematics
#1 reason to love math: 3D printed puzzles
Pioneer Andreas Kaiser writes about the power of puzzles in the classroom and how recreating or designing puzzles is a perfect fit for his engineering students.
Secondary education
Mathematics
Thinking about the environment
The learning curve associated with 3D printing can produce a lot of 3D printed waste. It's time to start exploring and thinking about more sustainable options.
Informal learning
Geography
Why I use 3D printing in the classroom (and why you should too!)
While 3D printing is not new to designers, engineers and other professionals in need of rapid prototyping tools, it is still a new and exciting technology for our students. Pioneer Grace Bennett shares why teachers should get started with 3D printing.
Secondary education
Technology
3D printing artifacts from the Penn Museum
The chance to hold a 3D printed historical artifact in our hands is one of the greatest ways to boost students' engagement with science, engineering, and culture. Learn how challenging and exciting it can really be.
Secondary education
History
Managing an open 3D printing lab
What’s it like to be a student administrator for a 3D printing lab space? What kind of knowledge and experiences could you offer to students at your own school by hiring them for such position?
