PRO Webinar
Tips & Tricks — Designing for 3D Printing with Fusion 360° + METHOD
Sr. Technical Specialist
Jason Lichtman
Join us and Jason Lichtman, Sr. Technical Specialist at Fusion 360, for a live demo of tips and tricks that will help you design for 3D printing. Design for manufacturing is critical to getting good results out of any manufacturing process, including 3D printing. If you 3D print prototypes or use additive manufacturing for production, be sure to watch and learn the best tips & tricks on how you can improve your final parts using Fusion 360° and METHOD X.
Primary Topics Covered:
In this LiveStream, Jason will show you tips and tricks that will help you design for 3D printing. If you struggle to get good-quality 3D prints, your design itself could be part of the problem. Design for Manufacturing (DFM) is critical to getting good results out of any manufacturing process, including 3D printing. If you 3D print prototypes or use additive manufacturing for your final production, this live stream is for you.
  • What you will learn:
    • - Use Parameters
    • - Minimizing Z Height
    • - Avoid Fillets
    • - Testing your feature, not your part
    • -Accessibility analysis
    • -Using Generative Design's Additive Manufacturing Constraint
    • -Mesh to B-rep
