Felipe Castaneda
February 26, 2026
Cura 5.12 is now available. This release focuses on something simple: better real-world results. Cleaner bridges, faster and more reliable infill, smarter defaults, fewer small frustrations in day-to-day work.
If 5.11 expanded control, 5.12 refines performance.
Bridging over non-rectangular surfaces has been improved, producing more consistent spans on complex geometries.
We’ve also updated combing behavior for thin parts. Travel moves now better avoid walls, reducing oozing across delicate features. The outcome is straightforward: fewer cosmetic defects and less cleanup on precision parts.
Scarf seams have also been refined to behave more reliably alongside overhangs, improving surface consistency where transitions matter.
Cura 5.12 introduces Honeycomb and Octagon infill types. Both are fast, structurally effective, and do not self-intersect.
Why that matters: at higher speeds, self-intersecting infills like Grid, Triangular, and Cubic can introduce surface artifacts. In Recommended mode, these patterns are now hidden for certain printers to prioritize quality. They remain available in Custom mode for users who want full control.
Two new settings improve infill performance and wall quality:
These updates help deliver stronger parts and cleaner surfaces, especially at higher throughput.
A new Middle option has been added for Z Seam positioning, offering additional flexibility for part aesthetics.
We’ve also introduced a Print Estimation Factor in printer settings. If estimated times consistently differ from actual production times, you can now calibrate predictions to better match your environment. That means more accurate planning and fewer scheduling surprises.
In Preview mode, the layer slider now shows both layer number and actual height, making part inspection more precise.
Several updates reduce friction in everyday use:
Small changes, but meaningful in production environments.
UltiMaker S6 & S8: Updated wall settings for improved strength
Cura 5.12 expands flexibility across post-processing:
For teams that fine-tune workflows, these updates remove limitations without adding complexity.
UltiMaker S6 & S8:
Connectivity has also been improved, with better responsiveness when printers are connected via Digital Factory and the ability to abort stalled CloudPrint jobs.
Cura 5.12 continues to evolve through open-source collaboration. Multiple printer definitions and profiles have been updated, and overall stability has been improved across the platform.
This release isn’t about adding noise. It’s about reducing friction.
Because professionals don’t need surprises. They need predictable results, part after part.
Download Cura 5.12 and put it to work.
Download this latest release to start discovering new 3D printing possibilities right now.
Download nowThis website uses cookies and similar technologies for website operation, analytics, improving your experience, and, where applicable, advertising or marketing purposes. By clicking “Accept all,” you consent to our use of non-essential cookies as described in our Privacy Policy. If you do not consent to non-essential cookies, please click “Reject.” You can manage your cookie preferences at any time by clicking “Manage.” You may withdraw your consent at any time. Learn more.
