cura-47-hero
  • News
Ultimaker Cura 4.7 is officially live – and with it, improvements to workflow acceleration, ease of use, and Cloud integration. It’s the fastest, most optimized Ultimaker Cura yet, making print preparation as seamless as ever.
elder-cura-video-4
Add a Cloud printer workflow
add a cloud
New features
Other new features in Ultimaker Cura 4.7 include:
improved-search
Model error detection. Whenever you load a part that is not manifold – or that contains errors – Ultimaker Cura will automatically issue a warning. Errors in the model are clearly indicated, and an alert appears in a pop-up window. Model error detection (available since Ultimaker Cura 4.6, but not officially announced) decreases the chance for accidental outcomes and improves success rates.
model-error
After the pop-up warning, you can review your models in CAD, then fix any errors before starting to print. Thanks to fieldofview, smartavionics, and bagelorb for their contributions to this feature.
Check for account updates manually. A check for the update/sync/refresh button was added near the account, allowing you to manually check for updates and start the syncing package flow, or have cloud printers added in Ultimaker Cura. 
Moved tree support from experimental to normal settings. We've made stability fixes and tested thoroughly, so tree support can be considered stable.
Rotation widgets. fieldofview has contributed code that adds three pairs of arrow widgets to the Rotate tool handle, enabling you to rotate objects by exactly 90 degrees.  
Performance improvements with multiple 3D models.  In previous versions, many objects on a build plate could cause Ultimaker Cura's performance and responsiveness to be slow. We have implemented code optimizations to increase responsiveness in such cases. 
Bug fixes
More than 70 bugs and performance issues have been solved in Ultimaker Cura 4.7, among them:
Lower start-up time by improving performance of loading profile metadata. This fix improves the start-up time of Ultimaker Cura. 
Tree support improvements. In addition to moving tree support out of the “experimental” category, we have also fixed multiple reported issues in which support branches would interfere with the model, or the support bottom distance was too small, or printing in vase mode. 
 X-Ray View error wrong color. The error color in the X Ray View turned translucent green. This version fixes it so it's a more logical solid red. 
Initial layer build plate temperature. An exception in our code prevented setting the build plate temperature to 0 when printing in one-at-a-time mode. 
Build volume shrinks with prime tower brim and no adhesion. The usable build plate volume was reduced (by increasing the disallowed areas) when there was a brimmed prime tower and the adhesion set to None. This is no longer the case.
Start printing now
Download Ultimaker Cura 4.7 today to make your print preparation even easier and more reliable. Have an idea or a comment? Be sure to let us know on our community of 3D printing experts, where you can offer questions, feedback, or suggestions directly to our development team.
Download for free
Level-up your slicing skills
  • webinar-recap-schubert-og
    • Applications
  • schubert-materials-og
    • Applications
    • News
    • Trends
    • Applications
    • Applications
    • News
  • og-webinars
    • News
    • Applications
    • Applications
  • 2-plus-connect-og
    • News
  • essentials-og
    • News
  • cura 4 8 beta og 1200X630
    • News
    • Applications
    • Applications
  • wear-resistant-materials-og
    • Applications
    • Applications
    • News
  • real-world-roi-og
    • Applications
    • News
  • cura-47-og
    Ultimaker Cura 4.7 is live, and with it improvements to functionality, workflow acceleration, and Cloud integration. Download for free now!
    • News
    • Applications
  • uv-resistant-og
    • Applications
  • cura-4-7-beta-og
    Achieve higher success rates with Ultimaker Cura 4.7 beta
    Ultimaker Cura 4.7 beta has arrived, and with it core improvements including ease-of-use adjustments and integration with Ultimaker Digital Factory.
    • News
  • design-for-FFF-og
    • Applications
  • chemical-resistant-og
    • Applications
    • News
  • cura-webinar-og
    • Applications
    • Trends
    • Applications
    • News
  • support-og
    • Applications
  • work-from-home-og
    • Trends
  • eventuri-og
    • Applications
  • Flexible TPU 95A 3D prints
    • Applications
  • wear-resistant-heineken-og
    • Applications
  • talking-additive-podcast-og
    • News
  • ultimaker-eriks-og
    • News
    • Applications
  • future-of-3d-printing-og
    • Trends
  • zeiss-cura-4.6
    Ultimaker Cura 4.6 beta expands on the popular Intent profiles feature to include new materials, enabling you to further simplify your print preparation workflow, produce better output from your printer, and improve dimensional accuracy.
    • News
  • aerospace-og
    • Applications
  • s5-pro-bundle
    • News
    • Applications
    • News
  • cura 4 5 OG
    • News
  • materials-og
    • Applications
    • News
  • cura-45-marketplace
    • News
    Discover the Benefits of 3D Printing for your Industry | Ultimaker
    • Applications
  • webinar-composites-og
    • News
  • 3d-printing-materials
    • Applications
    • Applications
  • 2019-in-review-og
    • News
  • material-wall-1
    • News
    • Applications
  • ultimaker-roi-calculator
    • News
    • Trends
  • Ultimaker Cura 4.4 og image
    • News
    • Applications
  • Ultimaker LEHVOSS Group
    • News
  • hero-og
    • News
    • News
    • News
    • Applications
  • marketplace-1m-og
    • News
  • TCT Show OG
    • News
    • News
    • News
    • Applications
  • cura-43-beta
    • News
  • A 3D printed part
    • Applications
  • lean-principles-og-image
    • Trends
    • News
  • 3d printing for molds
    • Applications
    • Trends
  • hero-user-context
    • News
  • Ford-hero-blog
    • Trends
  • Het Noordgebouw
    • News
  • Ultimaker manufacturing
    • Applications
  • Ultimaker Marketplace
    • News
  • Firmware 5.2
    • News
  • Ultimaker Cura 4.0
    • News
    • News
  • Ultimaker Cloud
    • News
  • Application focus: Jigs and fixtures
    • Applications
  • Ultimaker S5
    • News
    • Trends
    • Applications
    • News
    • Applications
    • Applications
  • Ultimaker at Formnext 2018
    • News
  • Pre-op planning
    • News
    • News
    • News
    • News
    • Trends
    • News
    • News
    • Trends
  • Ultimaker at SIGGRAPH
    • News
    • News
  • Designing with an Ultimaker
    • Applications
  • Ultimaker drill
    • Applications
  • Singapore skyline
    • News
  • dinara-kasko
    • Applications
  • Volkswagen
    • Trends
    • Trends
    • Applications
  • FFF-sla-sls
    • Applications
  • Ultimaker S5 with Tough PLA
    • Applications
    • Applications
    Integrating a desktop 3D printer into your workflow can yield impressive results, from creating concepts and prototypes for products to small batches of tooling, or even medical models for surgeons. Here’s a look at five of the ways 3D printing can improv
    • Applications
    • Applications
  • RepRap printer
    • News
    • News
  • PLA materials og
    • Applications
    • Applications
  • Jabil-Ultimaker
    • Applications
  • Firmware 4.3
    Firmware 4.3 available for the Ultimaker 3
    Get the latest features and a better Cura Connect experience by upgrading your Ultimaker 3 to Firmware 4.3. The latest firmware release takes your hardware further with a new accessibility feature. Learn more here.
    • News
    • News
    • Applications
  • SolidWorks integration
    • News
    • Applications
  • Firmware 4.1 and Cura Connect
    Ultimaker Firmware 4.1 release adds new functionality, features, and printing performance to your Ultimaker 3 and Cura Connect. Discover what's new in this blog post.
    • News
  • Siemens PLM
    • News
  • pittsfield-public-library
    • Applications
    • Trends
    • News
  • Ultimaker 3
    • News
  • Ultimaker Cura 3.0
    Welcome to Ultimaker Cura 3.0
    • News
    • Applications
  • Druxbury free library
    • Applications
    • Applications
    • Applications
    • Applications
  • Ultimaker company update
    • News
    Understanding firmware
    • Applications
  • 3D print farm
    • Applications
    • News
  • Jeffrey Wijkhuisen
    • News
  • Jasper van Damme
    • News
  • Anouschka Wodrada
    • News
  • Marcel Buter
    • News
  • Jacqueline Vulto
    • News
  • Lenneke de Penning
    • News
  • Layla Smid
    • News
    • News
  • Ultimaker Original upgrades
    • News
    • Trends
  • windmill-hero
    • Applications
    • Applications
    • Applications
    • News
    • News
    • Applications
    • Applications
    Painting 3D-printed models
    • Applications
    • Applications
