November 10, 2023
The beta release of UltiMaker Cura 5.6 has arrived and it brings prime tower improvements and support for Method series printers! Also, since the last update, the Cura team has released a new plugin that makes use of the engine plugin capabilities unlocked in Cura 5.5. Read on to find out more!
Local slicing
Extensive settings selection.
The following improvements have also been implemented in the Cura 5.6 beta release:
DOWNLOAD NOWUltiMaker uses functional, analytical and tracking cookies. Tracking cookies enhance your experience on our website and may also collect your personal data outside of Ultimaker websites. If you agree with the use of tracking cookies, click “Accept all”. You can withdraw your consent at any time. If you do not consent with the use of tracking cookies, click “Manage”. You can find more information about cookies on our Privacy and Cookie Policy page.
