Cura
Method series slicing and better prime towers in the Cura 5.6 stable release
November 28, 2023
In this article, we will take a look at some of the new features of Cura that you can look forward to in this 5.6 stable release. Including, the long-awaited support for Method series printers, as well as additional settings that now let you control the base of your prime towers. Additionally, since the previous 5.5 release, the Cura team has leveraged the engine plugin capabilities introduced in that release to create a new plugin that gives you a bunch of new infill options!
Cura now supports Method series printers!
Method XL in Cura
Why did this take so long?
Why use Cura instead of CloudPrint?
Local slicing
Extensive settings selection.
How do I slice files for a Method series printer in Cura?
Will there be more Cura updates for the Method series in the future?
Additional settings for adjusting prime tower bases
Prime tower base settings
  • Prime Tower Base Size
  • Prime Tower Base Height
  • Prime Tower Base Slope
  • Prime Tower Raft Line Spacing
An engine plugin for added infill flexibility
Infill plugin patterns
Additional improvements
The following improvements have also been implemented in the Cura 5.6 stable release:
  • Start and end gcode now accepts variables and math that includes variables
  • Spanish translations related to lightning infill have been updated (contributed by @Pelochus)
  • Additional bug fixes
DOWNLOAD NOW
