Cura Digital Factory
Method series printers come to UltiMaker Cura in the 5.6 beta
november 10, 2023
The beta release of UltiMaker Cura 5.6 has arrived and it brings prime tower improvements and support for Method series printers! Also, since the last update, the Cura team has released a new plugin that makes use of the engine plugin capabilities unlocked in Cura 5.5. Read on to find out more!
You can now slice files for Method series printers in Cura!
Method XL in Cura
Why did this take so long?
Why use Cura instead of CloudPrint?
Local slicing
Extensive settings selection.
How do I slice files for a Method series printer in Cura?
Will there be more Cura updates for the Method series in the future?
Prime tower improvements
Prime tower base settings
  • Prime Tower Base Size
  • Prime Tower Base Height
  • Prime Tower Base Slope
  • Prime Tower Raft Line Spacing
New engine plugin
Infill plugin patterns
Additional improvements
The following improvements have also been implemented in the Cura 5.6 beta release:
  • Start and end gcode now accepts variables and math that includes variables
  • Spanish translations related to lightning infill have been updated (contributed by @Pelochus)
  • Additional bug fixes
DOWNLOAD NOW
