ABS R 3D printing Material for Method
ABS R
for Method series
ABS, finally as easy as PLA.
Method X and Method XL can print manufacturing-grade ABS without warping and without weakening additives thanks to its heated chamber. With our proprietary RapidRinse™ support achieve incomparable ABS parts with unprecedented ease.
Shop ABS R
ABS R Material properties
Extruder
1XA
Tensile Modulus
2,600 MPa
Tensile Strength
41 MPa
Thermal resistance
102-105 °C
Spool weight
650 g
Filament diameter
1.75 mm
Material properties
Select the material properties you would like to compare all Method series materials.
1
Properties to compare
2
Available materials
Polymers
Print complex mechanical assemblies with real production materials
Tough PLA
Extruder
1A
Tensile strength:
39.3 MPa
Heat deflection:
No data
Tensile Modulus
2,364 MPa
Learn more
PLA
Extruder
1A
Tensile strength:
No data
Heat deflection:
No data
Flexural modulus:
No data
Learn more
PETG
Extruder
1A
Tensile strength:
50 MPa
Heat deflection:
70°C
Flexural modulus:
2,050 MPa
Learn more
ABS
Extruder
1XA
Tensile strength:
43 MPa
Heat deflection:
84°C
Flexural modulus:
No data
Learn more
ABS-R
Extruder
1XA
Tensile strength:
41 MPa
Heat deflection:
102-105 °C
Flexural modulus:
2,600 MPa
Learn more
ASA
Extruder
1XA
Tensile strength:
49 MPa
Heat deflection:
96°C
Flexural modulus:
2,300 MPa
Learn more
Nylon
Extruder
1A
Tensile strength:
66 MPa
Heat deflection:
91°C
Flexural modulus:
1,700 MPa
Learn more
PC-ABS
Extruder
1XA
Tensile strength:
37 MPa
Heat deflection:
108°C
Flexural modulus:
No data
Learn more
PC-ABS-FR
Extruder
1XA
Tensile strength:
60 MPa
Heat deflection:
104°C
Flexural modulus:
No data
Learn more
