6 factors that affect indoor air quality when 3D printing
뉴스
New research has prompted an important question: Do all the benefits of in-house 3D printing come at the cost of indoor air quality?
So what are the factors?
1. Your room's dimensional volume
2. Your room's air exchange rate
When 3D printing with multiple machines in the same room, it's best practice to have good ventilation and a high air exchange rate
When 3D printing with multiple machines, it's best practice to have good ventilation and a high air exchange rate
3. How many 3D printers you are using at the same time
4. What material(s) you're 3D printing
Some materials affect air quality more than others, so it's always good to check the manufacturer's datasheets
5. How long you're 3D printing for
Your print job's duration will cause the emission of different levels of UFPs and VOCs.
6. Whether there are other emission sources in the room
  • Photocopiers
  • Laser printers
  • Vacuum cleaners
  • Cleaning agents
  • Computers
  • Citrus fruit peel
  • And many more...
The Air Manager is part of the Ultimaker S5 Pro Bundle. Its efficient UFP filtration provides greater air quality peace of mind with multiple printer setups or when printing a wide range of materials
The Ultimaker S5 Air Manager's efficient air filtration provides greater peace of mind when printing with multiple printers or a wide range of materials
Conclusion: 3D print indoors with more confidence
However, if you want to have more flexibility in your 3D printing setup – 3D printing with more printers or a wider range of materials – the Ultimaker S5 Air Manager as part of the Ultimaker S5 Pro Bundle is now available.
This top enclosure integrates with the Ultimaker S5 to provide a fully validated air filtration solution. It includes a multi-speed fan and EPA filter that removes up to 95% of UFPs – a percentage that's based on data rather than guesswork.
PDF 다운로드
