cura-4-7-beta-hero
Achieve print success rates with Ultimaker Cura 4.7 beta
The beta of Ultimaker Cura 4.7 has arrived, and with it core improvements including ease-of-use adjustments and integration with the Ultimaker Digital Factory. Ultimaker Cura 4.7 beta will allow you to simplify your print preparation while simultaneously achieving higher success rates.
Add a Cloud printer workflow
add a cloud
New features
Other new features in Ultimaker Cura 4.7 beta include:
improved-search
Model error detection. Whenever you load a part that is not manifold – or that contains errors – Ultimaker Cura will automatically issue a warning. Errors in the model are clearly indicated, and an alert appears in a pop-up window. Model error detection (available since Ultimaker Cura 4.6, but not officially announced) decreases the chance for accidental outcomes and improves success rates.
model-error
After the pop-up warning, you can review your models in CAD, then fix any errors before starting your print. Thanks to fieldofview, smartavionics, and bagelorb for their contributions to this feature.
Bug fixes
More than 70 bugs and performance issues have been solved in Ultimaker Cura 4.7 beta, among them:
Support not generated on some parts of model. Fixed an issue in which bottom layers of support were not accurately generated, resulting in missing support material in the 3D printed model.
Upgraded Ultimaker 3 profiles for Ultimaker CPE/CPE+. To boost print performance for the Ultimaker 3, print profiles for Ultimaker CPE and CPE+ materials have been updated.
Cubic Subdivision infill does not move with model. Fixed an issue in which Cubic Subdivision infill didn't move with the model.
Gradual infill overlaps too much with skin. When slicing with the gradual infill option, the infill would sometimes overlap with the skin of the 3D model. This issue has been fixed.
Want more information on new features, bug fixes, and more for Ultimaker Cura 4.7 beta? Visit our the our GitHub page for a full overview.
Give us your feedback
Discover other exciting developments by downloading the Ultimaker Cura 4.7 beta today. Beta releases are all about user feedback, so don’t forget to give us yours on our community of 3D printing experts.
Download the beta
