David Durbin
News
New research has prompted an important question: Do all the benefits of in-house 3D printing come at the cost of indoor air quality?
So what are the factors?
1. Your room's dimensional volume
2. Your room's air exchange rate
When 3D printing with multiple machines, it's best practice to have good ventilation and a high air exchange rate
3. How many 3D printers you are using at the same time
4. What material(s) you're 3D printing
Some materials affect air quality more than others, so it's always good to check the manufacturer's datasheets
5. How long you're 3D printing for
Your print job's duration will cause the emission of different levels of UFPs and VOCs.
6. Whether there are other emission sources in the room
Photocopiers
Laser printers
Vacuum cleaners
Cleaning agents
Computers
Citrus fruit peel
And many more...
The Ultimaker S5 Air Manager's efficient air filtration provides greater peace of mind when printing with multiple printers or a wide range of materials
Conclusion: 3D print indoors with more confidence
However, if you want to have more flexibility in your 3D printing setup – 3D printing with more printers or a wider range of materials – the Ultimaker S5 Air Manager as part of the Ultimaker S5 Pro Bundle is now available.
This top enclosure integrates with the Ultimaker S5 to provide a fully validated air filtration solution. It includes a multi-speed fan and EPA filter that removes up to 95% of UFPs – a percentage that's based on data rather than guesswork.
The beta version of Ultimaker Cura 4.9 has landed. The release contains a bundle of feature improvements and bug fixes – including optimizations to print visualization.
News
Trends
Applications
News
The Ultimaker Cura slicing algorithm has been enhanced with the Arachne code library. This fundamentally changes how Ultimaker Cura handles inner parts of a model. Try it now – and give us your feedback – in this beta version.
News
Trends
Applications
Applications
News
Trends
Applications
News
News
Applications
News
Applications
Applications
News
News
News
Applications
Trends
Applications
Applications
Applications
News
News
Applications
Applications
Applications
Applications
Applications
News
Applications
Trends
Applications
News
Applications
Trends
Applications
Applications
Applications
News
News
Applications
Trends
Applications
News
Applications
News
News
News
News
News
Applications
Applications
News
News
Applications
News
Trends
Applications
News
News
News
Applications
News
News
News
News
Applications
News
Applications
Trends
News
Applications
Trends
Trends
News
Trends
Applications
News
Applications
Applications
News
News
News
News
News
News
Trends
News
News
Applications
Applications
News
Applications
Trends
Trends
Applications
Applications
Applications
Applications
Applications
News
News
Applications
Applications
Applications
News
Applications
News
Applications
News
Applications
Trends
News
News
Welcome to Ultimaker Cura 3.0
News
Applications
Applications
Applications
Applications
Applications
News
Understanding firmware
Applications
Applications
News
News
News
News
News
News
News
News
News
Ultimaker Original upgrades
News
Trends
Applications
Applications
Applications
News
News
Applications
Applications
Painting 3D-printed models
Applications
