Welcome back to our application spotlight series, where we explore how UltiMaker 3D printing technology powers smart solutions across industries. From cutting costs to keeping production lines moving, each story shows how additive manufacturing brings value to everyday operations.
This week, we’re taking a closer look at how a manufacturer optimized its conveyor belt system with a simple but impactful 3D printed part: the transition comb.
In conveyor belt systems, transition combs play a vital role in ensuring products move seamlessly from one belt to the next. Acting as guiding teeth between belts, they prevent products from snagging, tipping, or jamming during transfer - critical for keeping high-speed packaging lines efficient.
Traditionally, sourcing custom transition combs has been both costly and time-intensive. Each comb needs to be precisely designed to fit the conveyor geometry, and manufacturing replacements through conventional methods often meant long delays.
By switching to UltiMaker 3D printing with Nylon CF Slide, the manufacturer was able to produce lightweight yet strong transition combs directly in-house. The material’s wear resistance and low-friction properties made it ideal for continuous use in demanding conveyor environments.
Each comb could be tailored exactly to the conveyor’s needs - and when wear eventually sets in, new parts can be printed in just hours instead of waiting weeks.
Efficiency gains at a glance:
The printed geometry of the combs was optimized to guide products smoothly with minimal friction. Thanks to Nylon CF Slide, parts required fewer supports, were easy to post-process, and showed excellent layer adhesion - ensuring long service life even under constant use.
Transition combs may not be the flashiest components on the line, but their role is critical. With 3D printing, they can be made faster, at lower cost, and in designs tailored for maximum efficiency.
For this manufacturer, the result was a smoother, more reliable conveyor system—and a powerful reminder that even the smallest parts can deliver big value when produced with additive manufacturing.
Discover how UltiMaker’s professional 3D printing solutions can help you cut lead times, reduce costs, and keep operations running smoothly - no matter your industry.
