Introducing the new Ultimaker print core CC
Built for high-strength applications
Ultimaker is proud to announce the Ultimaker print core CC – the newest addition to our line of print cores suited to specific job types and applications, from manufacturing to prototyping. It acts as both an update and replacement for the print core CC Red, offering increased robustness, reliability, and much more. We can’t wait to see what you do with it.
Welcome to the ecosystem
With a wear-resistant, hardened steel nozzle and available in multiple nozzle sizes, the Ultimaker print core CC unlocks the power to print high-strength applications with extra stiffness and rigidity, using a wide range of composite materials from the Ultimaker ecosystem.
Ultimaker print core CC video
The Ultimaker print core CC joins the Ultimaker ecosystem to stand alongside the Ultimaker print core AA and the Ultimaker print core BB. Each print core is designed to serve a purpose – giving you the freedom to design, create, and print, assured that you have the right tools for the job.
Here’s a rundown of its key features.
Multiple print cores, maximum flexibility
Two nozzle sizes – 0.4 mm, enabling you to print detailed parts, tools, or prototypes with higher visual quality, and 0.6 mm, for shorter print times and improved efficiency – will result in easier optimization of composite applications.
The Ultimaker print core CC 0.4's smaller nozzle size means your prints will feature higher levels of detail, thinner line widths, and a smooth surface finish – enabling you to print parts or prototypes with the visual quality you need.
And by using the Ultimaker print core CC 0.6 to print with bigger line widths, your composite applications will be ready as quickly as possible – saving you time in a busy, hardworking environment that requires efficiency and speed.
The new Ultimaker print core CC 0.4
The new Ultimaker print core CC 0.4 features a 0.4 mm nozzle size
Printing fine details with the new print core cc
This is ideal for printing fine detail on parts, such as text to differentiate tools
Reliable, robust, ready for work
The Ultimaker print core CC features an all-new design with an abrasion-resistant, hardened steel nozzle and titanium heat break. Reliable, robust, and compatible with a wide range of composite 3D printing materials, you'll unlock the power to print high-strength applications that are ready for work.
Ultimaker 3D printer configuration change
Ultimaker print cores are designed to enable configuration changes in a matter of seconds
Quick swap – no tools necessary
With a quick-swap design, the Ultimaker print core CC – like all Ultimaker print cores – can be quickly and easily changed, tool-free, to meet the requirements of any print job, increasing your efficiency and decreasing downtime.
Plus, the print core's EEPROM chip memorizes the size and type of your nozzle, meaning fewer printing errors and an increased chance of success.
Built for market-leading composites
The Ultimaker print core CC is ideal for printing with the wide range of composite materials available in the Ultimaker Marketplace. Here's what some of the leading material brands say about the print core...
"The Ultimaker print core CC has been a workhorse for us here at Jabil. Our PA 4035 CF filament, which is a PA 12 with 35% carbon fiber by weight, is quite abrasive, so having a highly wear resistant nozzle is a must. We were excited to learn about the 0.4 mm offering, which gives us the flexibility to print finer feature detail than the 0.6 mm nozzle, while maintaining the same reliability and durability we’ve come to appreciate." – Levi Loesch, Process Engineer at Jabil Additive Manufacturing
“The CC 0.4mm print core is very well constructed and provides the next level of accuracy when using composite materials. It allows to print smaller features with a greater level of details when compare with the 0.6mm one. In addition, the surface finishing of our CF reinforced materials get even better than before!” – Thiago Medeiros Araujo, LEHVOSS Group
"The high accuracy in printing carbon fiber or glass fiber filled parts with the print core CC 0.4mm is as good as unfilled printed parts and we did not need to adjust speed or other parameters. We printed with our Ensinger TECAFIL PA6 GF30 and there were no blobs, clogging effects or any other issue that influences the printing process or the quality of the part. Overall the print core CC works very well and as it should." – Marius Graf, AM Development Engineer at Ensinger GmbH
Want to know more?
The recommended retail price for the Ultimaker print core CC (both 0.4 mm and 0.6 mm) is €299 / $299 (excluding VAT). They are available now via your preferred Ultimaker reseller.
Want to learn more about how you can use Ultimaker print cores to make it happen?
Discover Ultimaker print cores
