Ultimaker-webinar-support-materials-strategies-3d-printing
Strategies for support materials
Free webinar | Viewing time: 45 minutes
Design with more freedom. Print stronger parts. Achieve smoother surface finishes.
With the right support material strategies, you can do more with additive technology and deepen your 3D printing mindset.
Join Matt Griffin as he explores the support strategies used by Ultimaker Application Engineer, Guenael Morvan.
Then, Matt is joined by a special guest, Brandon Cernohous, Lead R&D Supervisor at Infinite™ Material Solutions.
Brandon reveals the new 3D printing applications made possible by AquaSys® 120 support – paired with three popular build materials also found in the Ultimaker Marketplace.
In this 45-minute webinar, you will discover:
  • The support material trick that Matt uses to avoid dramatic increases in costs and print times
  • How to fine-tune settings to optimize material bonding if the profile doesn't work as expected
  • New potential applications made possible by printing soluble support with PP, PC, TPU, PVDF, PAHT
  • A in-depth Q&A session, plus much more...
Sound good?
Then click below, fill out the form, and immediately start watching this high-value presentation.
Watch the webinar
