Felipe Castaneda
November 19, 2024Here comes Cura 5.9 and in this stable release we have lots of material and printer profiles for UltiMaker printers, including the newly released Sketch Sprint. Additionally, scarf seams have been introduced alongside even more print settings and improvements. Check out the rest of this article to find out the details on all of that and more!
We have struck another blow against ugly Z seams by introducing lots of new experimental seam settings, including settings for using a scarf seam. There have also been improvements to how Z seams are aligned when using the 'Sharpest Corner' alignment option.
Scarf seams are a method of printing Z seams that is inspired by a type of carpentry joinery called scarf joints. A scarf joint is where you connect two pieces of wood by cutting the ends into opposing tapered angles that you can then fit together for easy gluing or fastening. You can see what that looks like in the example image below, taken from Wikipedia.
The principle behind a scarf seam is the same, except instead of cutting the filament, you create the taper ends by varying the flow rate of material through the nozzle. When first starting to print a layer, the flow rate is increased slowly in stages to make a line that is thinner at first and that gets thicker until it is the full line thickness, after which it prints at a consistent thickness until it approaches the end of the layer, at which point the process is reversed, tapering off the line so that the start and end of the layer match up. The result should be a Z seam that is less pronounced.
The image above is using our showcase model for this release which you can find, along with the settings used, here.
In this release, there are three new settings you can use for tuning your scarf seams. Each one lets you tune how aggressively you want the scarf seam to be applied. They are:
There are also more settings that have been added in this release that can be used to tune your seam, either when using scarf seams or a normal Z seam:
The above settings are all experimental. We have seen great results using them so far and we hope to make improvements to them based on further testing, as well as feedback from our users!
The new lightning-fast MakerBot Sketch Sprint has been released and is now supported inside of Cura along with profiles for the Sketch and Sketch Large printers. Material profiles have also been added for the Method series materials PETG and Tough PLA as well as new material profiles for the Labs extruder. The existing profiles for ABS and CF 12 have also been updated.
Note: We are very happy with the performance of the Sketch Sprint profiles. However, the Sprint prints so fast that some users have experienced issues with overhangs that do not print as cleanly as they would like. If you find this yourself, you can increase the 'Minimum Layer Time' setting to give the overhangs more time to cool. If the issue persists then use supports to support any overhangs that are giving you trouble. We are always making improvements to our printer profiles and we expect that overhangs will only get better over time!
The start and end G-code for both printers and extruders will now accept and run conditional statements such as If/Else statements. This makes it possible to set up much more complex printer automation that responds to things such as the status of your printer or user input.
You can edit your start and end G-code in your machine settings inside of Cura. Access them by selecting your active printer and then going to Preferences > Configure Cura... > Printers > Machine Settings.
In your machine settings, you will find tabs for your printer and extruders. At the bottom of each tab are two text entry boxes, one for the start G-code that will run before your print and one for the end G-code that will run after. For more information on how to use start and end G-code, check out our wiki on the subject. Note that some printers have custom G-Code set up by the manufacturers, with custom commands that may be necessary. Remove them only if you know what they are used for.
One of the major disadvantages of using a low infill percentage is that it can lead to blobs, pillowing, or tearing on the first layers above the infill. Since printing parts that use less material and are therefore weaker is more common with prints that are meant to be ornamental, as opposed to functional, that can be frustrating. Luckily, we have included a setting in this release that can reduce this downside.
The new “Extra Infill Lines To Support Skins” setting was contributed by the Cura community member Hello1024 alongside some other related improvements. When enabled, the new setting adds extra lines into the infill pattern to support the skin layers above.
In the image above, the left print preview does not have the new setting applied while the right does.
The following improvements have also been implemented in the Cura 5.9 stable release:
DOWNLOAD NOWThis website uses cookies and similar technologies for website operation, analytics, improving your experience, and, where applicable, advertising or marketing purposes. By clicking “Accept all,” you consent to our use of non-essential cookies as described in our Privacy Policy. If you do not consent to non-essential cookies, please click “Reject.” You can manage your cookie preferences at any time by clicking “Manage.” You may withdraw your consent at any time. Learn more.
