CPE+
for S series
UltiMaker CPE+ material is chemical resistant with high dimensional stability, with the added advantages of increased temperature resistance and higher impact strength compared to regular CPE.
Shop CPE+
CPE+ Material properties
Print Core
AA
Hardness
77 Shore D
Impact strength
37 kJ/m²
Thermal resistance
100 °C
Spool weight
700 g
Filament diameter
2.85 mm
Material properties
Select the material properties you would like to compare all S series materials.
1
Properties to compare
2
Available materials
Additional UltiMaker S series materials
A proven selection of polymers to help you address a wide range of use cases.
Tough PLA
Print Core
AA
Hardness
80 Shore D
Thermal resistance
58 °C
Impact
strength
9 kJ/m²
Learn more
PLA
Print Core
AA
Hardness
84 Shore D
Thermal resistance
59 °C
Impact
strength
4 kJ/m²
Learn more
PETG
Print core
AA
Hardness
76 Shore D
Thermal resistance
76 °C
Impact
strength
8 kJ/m²
Learn more
ABS
Print Core
AA
Hardness
76 Shore D
Thermal resistance
87 °C
Impact
strength
14 kJ/m²
Learn more
CPE
Print Core
AA
Hardness
76 Shore D
Thermal resistance
77°C
Impact
strength
6 kJ/m²
Learn more
CPE+
Print Core
AA
Hardness
77 Shore D
Thermal resistance
100 °C
Impact
strength
37 kJ/m²
Learn more
Nylon
Print Core
AA
Hardness
81 Shore D
Thermal resistance
89 °C
Impact
strength
14 kJ/m²
Learn more
PC
Print Core
AA
Hardness
81 Shore D
Thermal resistance
111 °C
Impact
strength
12 kJ/m²
Learn more
TPU 95A
Print Core
AA
Hardness
48 Shore D
Thermal resistance
116 °C
Impact
strength
24 kJ/m²
Learn more
PP
Print Core
AA
Hardness
42 Shore D
Thermal resistance
99°C
Impact
strength
49 kJ/m²
Learn more
PET CF
Print Core
CC
Hardness
76 Shore D
Thermal
102 MPA
Impact
strength
102 MPA
Learn more
