Over 280 materials to choose from.
Explore our support content
Pricing or financing options
Press and general inquiries
Contact our support team directly
Arun Chapman
maart 25, 2025The full stable release of Cura 5.10 has arrived, and it brings support for the new Ultimaker S8, as well as new materials and profiles for previously supported UltiMaker printers. Additionally, you can now control your models in Cura using a 3D SpaceMouse and more!
The new and super-productive UltiMaker S8 is now supported in Cura. The S8 is the newest professional desktop printer in the S series, and it achieves up to 4x the speed of its predecessor while also improving print quality. That is possible thanks to the new UltiMaker Cheetah motion planner and new high flow cores, all of which will be usable at launch with Cura!
Check out the full announcement for more info about the S8, or go straight to the product page to order one for yourself.
Support for the SpaceMouse has been added in this release. Commonly used in CAD and 3D design software, a 3D mouse makes working with 3D models more precise and efficient. The SpaceMouse, along with the CadMouse, are a perfect fit for Cura and should help make your 3D printing workflows more efficient, especially when switching between Cura and CAD or design software. A big thanks to 3Dconnexions for helping to make this integration possible!
Check out the official integration page provided by 3Dconnexion to find out more!
Lots of new material profiles this release with the Method X and XL printers both getting profiles for the PC-ABS and PC-ABS-FR materials. All S series printers also now have support for the Nylon Slide material and all Sketch printers have a new Metallic PLA material profile. The Sketch Sprint has also received new ‘Visual’, ‘Extra Fast’, and ‘Draft’ intent profiles. In addition, the MakerBot Replicator+ printer is also now supported in Cura!
Note that the beta release of 5.10 included 'High Speed' and 'High Speed Solid' intent profiles for Method series printers. However, they did not meet our quality standards and have therefore been temporarily removed. They will be reintroduced in a future Cura release after further optimization.
A heads up for anyone who uses Cura with a USB-connected printer. From Cura version 5.11 onwards, we are changing how printing via USB works. Note that this refers to having your PC and printer directly linked via a USB cable, not printing with a USB hard drive.
In Cura 5.11, USB printing will no longer be enabled by default. Instead, it will be disabled by default, and new users will need to enable USB printing manually if they wish to use it. Anyone who has already printed using USB before updating will not have their settings changed and can continue printing as normal.
The reason for this change is that many people now print wirelessly or via USB hard drive/SD card, and this functionality was causing more people errors than it was helping. In this release, we have already added the ‘Enable/Disable USB Printing’ setting in the preference menu so that you can set your preference now in preparation for the next release. Don’t worry, though; the functionality is not going anywhere, and you will still be able to enable it later at any point, even if you do not take any action now.
A quick heads-up for anyone using Digital Factory to print over the cloud. To keep things running smoothly, you may need to update to a workspace. We made some changes for non-subscribed users in November 2023, and if you haven’t updated yet, now’s the time! Just click here, or check your account settings—it should only take a few seconds and does not require a paid subscription. If you have already joined someone else's workspace without upgrading your account, you may still need to make a workspace. Please follow these support instructions to find out how!
The following improvements have also been implemented in the Cura 5.10 stable release:
Note that Cura 5.10 supports Mac OSX 12 Monterey or higher. This is because the tools that we use to create Cura builds no longer support older versions of Mac OSx.
Check out the full release notes on GitHub for a complete list of changes.
Download this latest release to start discovering new 3D printing possibilities right now. And please, go to the UltiMaker community site to give us your feedback.
DOWNLOAD NOW
