The PET CF Expansion Kit includes everything you need to start printing high-performance parts on an UltiMaker S series printer so that you can get the full power of carbon fiber composite parts, combined with the seamless workflow and ease of use of the UltiMaker platform.
Create functional prototypes with high-performance properties including impressive strength, stiffness, and temperature resistance. Use an engineering-grade material for your engineering prototypes.
UltiMaker PET CF is the perfect material for your manufacturing needs. It provides the performance and versatility for a wide range of applications: such as jigs, fixtures, and end-of-arm tooling.
UltiMaker PET CF is the perfect solution for replacing broken or hard-to-source parts. You no longer need to shut down a production line for days or weeks while waiting for a replacement. Instead, you can print a new part using PET CF, even when you need it to be strong or temperature-resistant.
The UltiMaker PET Carbon Fiber Expansion Kit includes:
Enjoy a seamless composite printing experience thanks to the complete integration of PET CF with UltiMaker S series printers: including NFC-equipped spools, the Print Core CC, and intent profiles in UltiMaker Cura.
The suitability of PET CF, combined with the extensive testing and validation that we performed while developing it, makes it the perfect candidate for annealing. If you follow the guidelines in this article, you will end up with a part that is stronger, stiffer, and more heat-resistant.
