januari 24, 2025New research has prompted an important question: Do all the benefits of in-house 3D printing come at the cost of indoor air quality?
But as 3D printing becomes more mainstream, what impact does it have on indoor air quality? You’ll find the answers – based on data from independent testing — in our free whitepaper, 3D Printer Emissions and Air Quality.
Download the PDFYour print job's duration will cause the emission of different levels of UFPs and VOCs.
However, if you want to have more flexibility in your 3D printing setup – 3D printing with more printers or a wider range of materials – the Ultimaker S5 Air Manager as part of the Ultimaker S5 Pro Bundle and the UltiMaker S7 which include an integrated EPA filter are now available.
This top enclosure integrates with the Ultimaker S5 and S7 to provide a fully validated air filtration solution. It includes a multi-speed fan and EPA filter that removes up to 95% of UFPs – a percentage that's based on data rather than guesswork.
Updated Jan 24, 2025
