FDM vs SLA Printing: Comparing 3D Printing Technologies
april 1, 2025
Fused Deposition Modeling (FDM) and Stereolithography (SLA) are two prominent 3D printing technologies.
While both create three-dimensional objects layer by layer, they employ fundamentally different processes and materials.
Introduction to FDM and SLA 3D printing
FDM printing - also known as FFF printing - works by extruding thermoplastic filaments through a heated nozzle. The melted plastic is deposited in thin layers that fuse together as they cool. Common FDM materials include ABS and PLA plastics. This technology is known for its affordability, ease of use, and ability to produce functional prototypes and parts.
SLA 3D printing uses a laser to cure and solidify liquid photopolymer resin. A build platform is lowered into a vat of resin, and the laser traces each layer, hardening the material. SLA is capable of producing highly detailed parts with smooth surface finishes. It excels at creating intricate geometries and is often used for jewelry, dental applications, and high-resolution prototypes.
Key differences between FDM vs SLA printing include:
  • Materials: FDM uses thermoplastic filaments, while SLA uses liquid resins
  • Resolution: SLA typically achieves finer details and smoother surfaces than FDM
  • Post-processing: SLA parts require washing and post-curing, while FDM parts may need support removal
  • Applications: FDM is versatile for prototyping and some end-use parts, while SLA specializes in high-detail models
Understanding the strengths and limitations of each technology allows designers and engineers to choose the most suitable 3D printing method for their specific applications and requirements. Let's explore how FDM printing works in more detail.
How FDM printing works
FDM printing, or fused deposition modeling, works by extruding melted thermoplastic filament through a heated nozzle to build up a 3D object layer by layer. The process involves the following key steps:
  1. A spool of thermoplastic filament, typically ABS or PLA, feeds into the 3D printer's extruder assembly.
  2. The extruder heats the filament to its melting point, usually between 180-230°C depending on the material.
  3. The molten plastic is forced through a small nozzle, typically 0.4mm in diameter.
  4. The printer's motion control system precisely moves the extruder in the X and Y axes to deposit the melted plastic in the shape of the current layer.
  5. As each layer is completed, the build platform lowers slightly to allow the next layer to be printed on top.
  6. This process repeats, building up the 3D object one thin layer at a time until the print is complete.
The FDM printing process allows for relatively fast and affordable 3D printing of plastic parts and prototypes. Key factors that affect print quality include nozzle size, layer height, print speed, and material properties. Support structures are often required for overhanging features.
While FDM 3D printing has some limitations in terms of resolution and surface finish compared to other additive manufacturing methods, it remains one of the most widely used 3D printing technologies due to its accessibility and range of compatible thermoplastic materials. Now, let's examine how SLA technology differs in its approach to 3D printing.
Understanding SLA 3D printing technology
Stereolithography (SLA) is a 3D printing technology that uses light to cure and solidify liquid resin into three-dimensional objects. The SLA process works by using a laser or light projector to selectively harden thin layers of photopolymer resin, building up the 3D model one layer at a time.
Some key aspects of SLA 3D printing include:
  • High resolution and accuracy - SLA can achieve layer heights as fine as 25 microns, allowing for extremely detailed prints with smooth surfaces
  • Wide range of materials - SLA resins are available in various formulations with different properties like flexibility, durability, heat resistance, and biocompatibility
  • Isotropic parts - The chemical bonding between layers results in uniform mechanical properties in all directions
  • Support structures - Delicate supports are required for overhangs and must be removed after printing
  • Post-processing - Prints require washing in solvent and post-curing with UV light to achieve final material properties
Compared to FDM 3D printing, SLA offers superior surface finish and ability to produce fine details, but tends to have higher material costs and more involved post-processing. SLA excels at producing smooth, accurate prototypes and parts for applications like jewelry, dental models, and intricate functional prototypes.
The SLA printing process involves several key steps:
  1. The build platform is lowered into a vat of liquid resin
  2. A laser or light source traces the cross-section of the first layer, curing and hardening the resin
  3. The platform rises slightly and more resin flows under
  4. The next layer is traced and cured
  5. This process repeats layer by layer until the full 3D object is formed
While SLA 3D printing requires more specialized equipment than FDM, it enables the production of highly accurate parts with excellent surface quality, making it a valuable technology for many prototyping and manufacturing applications. With an understanding of both FDM and SLA processes, we can now compare their print quality and resolution capabilities.
Print quality and resolution - FDM vs SLA
When comparing print quality and resolution between FDM and SLA 3D printing technologies, SLA generally produces superior results:
FDM/FFF print quality
  • Typical layer heights of 50-400 microns
  • Visible layer lines, especially on curved surfaces
  • Limited ability to produce fine details
  • Surface finish often requires post-processing to smooth
SLA print quality
  • Layer heights as fine as 25-100 microns
  • Smooth surfaces with minimal visible layer lines
  • Capable of producing intricate details and complex geometries
  • Parts have a high-quality finish right off the printer
The key factors contributing to SLA's superior print quality include:
  • Use of a precise laser to cure resin, allowing for finer details
  • Liquid resin material that flows to create smoother surfaces
  • Chemical bonding between layers for more uniform parts
While FDM printing is suitable for many applications, SLA printing excels at producing parts that require:
  • High levels of detail and intricacy
  • Smooth surface finishes
  • Precise dimensional accuracy
For applications like jewelry prototypes, dental models, or highly detailed figurines, SLA is often the preferred choice due to its superior resolution and print quality. However, FDM remains a popular option for many functional prototypes and parts where ultra-fine details are less critical. Beyond print quality, it's important to consider the material properties and durability of parts produced by each technology.
Material properties and durability
When comparing the material properties and durability of FDM and SLA 3D printing, there are several key factors to consider:
Strength and durability
FDM printed parts are generally stronger and more durable than SLA parts. This is due to the nature of the thermoplastic materials used in FDM, such as ABS and PLA, which offer good mechanical strength and impact resistance. FDM prints are typically stronger than resin prints, especially for functional prototypes and end-use parts.
SLA resins, while capable of producing highly detailed parts, tend to be more brittle and less durable than FDM thermoplastics. However, engineering resins for SLA printers have been developed to improve strength and durability, narrowing the gap with FDM materials.
Material properties
FDM materials offer a wide range of material properties, including:
  • Higher temperature resistance
  • Better chemical resistance
  • Greater flexibility (with materials like TPU)
  • Improved impact resistance
SLA resins excel in other areas:
  • Higher detail resolution
  • Smoother surface finish
  • Isotropic properties (uniform strength in all directions)
  • Ability to create transparent parts
Environmental factors
When considering durability, it's important to note how the materials react to environmental factors:
  • FDM parts are generally more resistant to UV light and outdoor conditions
  • SLA parts can degrade more quickly when exposed to sunlight or moisture
  • FDM materials like ABS and PETG offer better long-term stability
Anisotropy vs isotropy
A key difference in material properties between FDM and resin prints is their structural characteristics:
  • FDM parts are anisotropic, meaning they have different strengths along different axes due to the layer-by-layer printing process
  • SLA parts are isotropic, with uniform properties in all directions, which can be advantageous for certain applications
While SLA technology offers superior detail and surface finish, FDM generally provides better overall strength and durability for functional parts. The choice between the two often depends on the specific requirements of the application, balancing factors like detail, strength, and environmental resistance. Now, let's examine how these technologies compare in terms of speed and efficiency.
Speed and efficiency comparison
When comparing the speed and efficiency of FDM printing versus SLA 3D printing, several factors come into play:
Print speed
FDM printing is generally faster for larger, less detailed parts. The extrusion process allows for quick deposition of material, especially when using larger nozzle sizes and thicker layer heights. For simple geometries, FDM can produce parts rapidly.
SLA 3D printing tends to be slower overall, but excels at producing small, highly detailed parts quickly. The laser curing process can create very fine features efficiently. For intricate designs, SLA may actually be faster than FDM.
Build volume and throughput
FDM printers often have larger build volumes, allowing for bigger parts or more parts to be printed simultaneously. This can increase overall throughput for larger production runs.
SLA printers typically have smaller build volumes, but can tightly pack many small, detailed parts in a single print job. For small, high-detail parts, SLA may offer higher throughput.
Post-processing time
FDM parts often require more extensive post-processing to achieve a smooth surface finish. Support removal and sanding can be time-consuming.
SLA parts emerge with a smoother surface finish, but require washing and post-curing steps. However, these can be largely automated with accessories.
Material efficiency
FDM printing allows for variable infill density, potentially saving material on non-critical areas of a part. However, support structures often use additional material that becomes waste.
SLA 3D printing produces fully dense parts, but unused resin can be recycled. Support structures tend to use less material than FDM.
Operational efficiency
FDM printers are generally simpler to operate and maintain, with fewer consumables to manage. This can improve overall workflow efficiency.
SLA printers require more careful handling of liquid resins and additional post-processing equipment. However, the consistent quality of SLA prints may reduce failed prints and reprints.
The speed and efficiency considerations of FDM and SLA technologies directly impact their cost-effectiveness for different applications. Let's explore the cost considerations for both technologies in more detail.
Cost considerations - FDM vs SLA
When comparing the costs of FDM vs SLA printing, several factors need to be considered:
Initial equipment costs
  • FDM printers are generally more affordable, with entry-level models starting around $200-$300
  • SLA printers tend to be more expensive, with desktop models typically starting at $1000-$3000
  • Professional and industrial-grade printers for both technologies can cost tens of thousands of dollars
Material costs
  • FDM filaments are relatively inexpensive, typically ranging from $20-$50 per kilogram
  • SLA resins are more costly, usually $50-$200 per liter
  • Specialty materials for both technologies can be significantly more expensive
Operational costs
FDM printers generally have lower operational costs due to:
  • Simpler mechanics requiring less maintenance
  • No need for post-curing equipment
  • Lower energy consumption
SLA printers have additional operational considerations:
  • Resin tanks may need periodic replacement
  • Post-curing equipment adds to overall costs
  • Proper ventilation systems may be required for resin fumes
Cost per part
The cost per printed part depends on several factors:
  • Part size and complexity
  • Material usage and waste
  • Print time and labor costs
  • Post-processing requirements
For larger, simpler parts, FDM printing often proves more cost-effective. However, for small, detailed parts, SLA printing can be more economical due to its higher precision and lower material waste.
Long-term considerations
When evaluating SLA vs FDM costs over time:
  • FDM may have lower ongoing costs for hobbyist or low-volume use
  • SLA can be more cost-effective for businesses requiring high-detail, production-quality parts
  • The specific application and production volume will ultimately determine which technology offers the best value
Understanding the cost implications of FDM and SLA technologies is crucial for making informed decisions about which method to use for specific applications. Let's explore the various industries and applications where each technology excels.
Applications and industries
Both FDM printing and SLA 3D printing have found widespread use across various industries, each excelling in different applications based on their unique capabilities:
FDM applications
  • Automotive: Functional prototypes, custom jigs and fixtures, end-use parts
  • Aerospace: Lightweight components, ducting, interior parts
  • Consumer goods: Rapid prototyping, small production runs
  • Education: Affordable 3D printing for schools and universities
  • Manufacturing: Custom tooling, assembly aids, spare parts
SLA applications
  • Dental: Highly accurate dental models, surgical guides, aligners
  • Jewelry: Intricate patterns for casting, prototype designs
  • Medical: Anatomical models, surgical planning tools, prosthetics
  • Product design: High-detail prototypes, form and fit testing
  • Engineering: Fluid flow analysis, wind tunnel models
Key factors influencing the choice between FDM and SLA 3D printing for specific industries include:
  • Required level of detail and surface finish
  • Mechanical properties and durability needs
  • Production volume and speed requirements
  • Material compatibility with end-use applications
  • Post-processing capabilities and time constraints
For example, the automotive industry often leverages FDM for its ability to produce strong, durable parts using engineering-grade thermoplastics. Conversely, the dental industry predominantly uses SLA due to its superior accuracy and biocompatible materials.
As both FDM printing and SLA 3D printing technologies continue to advance, their applications are expanding into new industries and use cases.
This growth is driving innovation in materials, print speeds, and machine capabilities, further broadening the potential applications for additive manufacturing across various sectors.
Advanced FFF 3D printers like the UltiMaker S8 can expand your possibilities, whether you're creating rapid prototypes, end-use parts, or pushing the limits of additive manufacturing, the world of infill patterns offers a vast playground for optimization and creativity.
Discover the new S8
Explore S8
