Explore our support content
Pricing or financing options
Press and general inquiries
David Durbin
mei 24, 2023This application concept was designed by application engineers at Ultimaker to showcase one of the many possible ways that metal FFF technology can improve existing processes.
Metal impeller pumps need to be durable, and depending on their intended function, may necessitate complex and hard-to-machine designs.
Creating multiple design iterations using traditional manufacturing techniques can be costly and time-consuming.
This rapid prototype of a centrifugal pump was produced using the BASF Forward AM Ultrafuse® 17-4PH material and metal FFF technology.
Because the design needs to cater to a range of outlet requirements (power, pressure, outflow rate, temperature, etc.) the blades can end up being difficult to manufacture using other techniques. Creating this part with traditional subtractive manufacturing, for example, would have required a 5-axis CNC machine and would have resulted in significant material waste.
Print time | Weight | Cost |
11 hours | 300 g | $72 |
Using MFFF technology for prototyping parts like this allows for faster and cheaper iterations which subsequently makes it possible to test more iterations, resulting in a better final part.
Click below for more explore more MFFF application inspiration. Or discover how to buy the Ultimaker Metal Expansion Kit for yourself.
Meet the Metal Expansion Kit
