maart 25, 2025The full stable release of Cura 5.10 has arrived, and it brings support for the new Ultimaker S8, as well as new materials and profiles for previously supported UltiMaker printers. Additionally, you can now control your models in Cura using a 3D SpaceMouse and more!
The new and super-productive UltiMaker S8 is now supported in Cura. The S8 is the newest professional desktop printer in the S series, and it achieves up to 4x the speed of its predecessor while also improving print quality. That is possible thanks to the new UltiMaker Cheetah motion planner and new high flow cores, all of which will be usable at launch with Cura!
Check out the official integration page provided by 3Dconnexion to find out more!
Lots of new material profiles this release with the Method X and XL printers both getting profiles for the PC-ABS and PC-ABS-FR materials. All S series printers also now have support for the Nylon Slide material and all Sketch printers have a new Metallic PLA material profile. The Sketch Sprint has also received new ‘Visual’, ‘Extra Fast’, and ‘Draft’ intent profiles. In addition, the MakerBot Replicator+ printer is also now supported in Cura!
Note that the beta release of 5.10 included 'High Speed' and 'High Speed Solid' intent profiles for Method series printers. However, they did not meet our quality standards and have therefore been temporarily removed. They will be reintroduced in a future Cura release after further optimization.
The following improvements have also been implemented in the Cura 5.10 stable release:
DOWNLOAD NOW
