3D Printing vs CNC: Comparing Additive and Subtractive Manufacturing
april 9, 2025
3D printing and CNC machining represent two distinct approaches to creating three-dimensional objects. While both technologies can produce complex parts, their methodologies and capabilities differ significantly.
Introduction to 3D printing and CNC machining
3D printing, also known as additive manufacturing, constructs objects layer by layer from the ground up. This process involves depositing material, typically plastic or metal, in thin layers according to a digital 3D model. The technique allows for the creation of intricate geometries and internal structures that would be challenging or impossible to achieve through traditional manufacturing methods.
CNC machining takes a subtractive approach to manufacturing. It employs computer-controlled cutting tools to remove material from a solid block or workpiece, shaping it into the desired form. CNC machines can work with a diverse range of materials, including metals, plastics, and wood, offering high precision and repeatability in production.
Key distinctions between these technologies include:
  • Material usage: 3D printing adds material, while CNC machining removes it
  • Geometric complexity: 3D printing excels at complex shapes, while CNC has certain limitations
  • Production speed: CNC is generally faster for larger quantities
  • Precision: CNC typically offers tighter tolerances
  • Material options: CNC works with a broader range of materials
When choosing between these technologies, consider factors such as part complexity, material requirements, production volume, and desired accuracy. Each method has its strengths, making them suitable for different applications across industries like aerospace, automotive, medical, and consumer products.
Key differences between 3D printing and CNC machining
Building upon the introduction, let's delve deeper into the fundamental differences between 3D printing and CNC machining that impact various aspects of the manufacturing process:
Manufacturing process
3D printing builds objects layer by layer, while CNC machining cuts away material from a solid block. This core difference influences the entire production approach and the types of parts each method can create effectively.
3D printing excels at producing complex geometries and internal structures. CNC machining, while highly precise, has some limitations on part complexity due to tool access constraints. This makes 3D printing particularly suitable for intricate designs or parts with internal features.
Material options
CNC machining works with a wider range of materials, including various metals, plastics, and wood. 3D printing materials, while expanding, are more limited, typically focusing on plastics and some metals. The choice of material can significantly impact the final product's properties and applications.
Precision and accuracy
CNC machining generally offers tighter tolerances and better surface finish. 3D printing accuracy depends on the specific technology used, but it continues to improve. For applications requiring high precision, CNC machining often has the edge.
Production volume
CNC is better suited for medium to high volume production, while 3D printing shines in prototyping and low volume production. As production quantities increase, the economics often shift in favor of CNC machining.
Cost factors
3D printing typically has lower setup costs and is more cost-effective for small batches. CNC becomes more economical at higher volumes due to faster production speeds. The break-even point depends on various factors, including part complexity and material costs.
When deciding between these technologies, carefully consider how these differences align with your specific project requirements, production goals, and desired outcomes. With this understanding of the key differences, let's explore the material considerations for each method.
Material considerations for 3D printing vs CNC
Material selection plays a crucial role when comparing 3D printing and CNC machining. The choice of manufacturing method often hinges on the material properties required for the final product.
CNC machining materials
CNC machining offers a broad spectrum of material options, including:
  • Metals: Aluminum, stainless steel, titanium, brass, copper
  • Plastics: ABS, nylon, polycarbonate, PEEK, acetal
  • Wood and composites
This versatility allows CNC machining to produce parts for a wide range of applications across industries. The ability to work with metals and harder materials gives CNC an advantage for producing strong, durable components.
While more limited than CNC, 3D printing materials continue to expand:
  • Plastics: PLA, ABS, nylon, TPU
  • Resins
  • Some metals: Aluminum, stainless steel, titanium
  • Ceramics
3D printing excels with plastics and polymers, offering unique material properties like flexibility or biocompatibility. However, metal 3D printing is still developing and can be more costly than CNC for metal parts.
Material properties
When choosing between these technologies, consider these material property differences:
  • Strength: CNC machined parts typically have superior strength and mechanical properties
  • Isotropy: 3D printed parts may have anisotropic properties due to layer-by-layer construction
  • Surface finish: CNC generally produces smoother surfaces without layer lines
  • Heat resistance: CNC can work with high-temperature materials more easily
The specific material requirements of a project often guide the choice between additive and subtractive manufacturing methods. For applications needing high strength or specific metal alloys, CNC machining is often preferred. However, for complex plastic parts or where material properties like flexibility are needed, 3D printing can be the better option. With material considerations in mind, let's examine how these technologies compare in terms of precision and accuracy.
Precision and accuracy - 3D printing vs CNC machining
Precision and accuracy are critical factors in manufacturing, and both 3D printing and CNC machining offer different capabilities in this regard:
Dimensional accuracy
CNC machining generally offers superior dimensional accuracy:
  • CNC machining can achieve tolerances as tight as ±0.025 mm
  • Most 3D printing technologies have tolerances between ±0.1 mm to ±0.5 mm
  • Industrial 3D printers can reach tolerances of ±0.025 mm to ±0.05 mm, but at a higher cost
Surface finish
CNC machined parts typically have a smoother surface finish:
  • CNC machining can produce surface roughness values as low as 0.8 μm
  • 3D printed parts often have visible layer lines, with surface roughness around 15 μm
  • Post-processing can improve 3D printed surface finish, but adds time and cost
While CNC machining excels in accuracy, 3D printing offers greater geometric freedom:
  • 3D printing can produce complex internal structures and organic shapes
  • CNC machining is limited by tool access and may require multiple setups for complex parts
  • Some geometries are only possible or cost-effective with 3D printing
Material properties
The precision of parts is also affected by material properties:
  • CNC machined parts maintain the full mechanical properties of the source material
  • 3D printed parts may have anisotropic properties due to layer-by-layer construction
  • Metal 3D printing can achieve near-isotropic properties with proper post-processing
Repeatability
For consistent production of multiple parts:
  • CNC machining offers excellent repeatability, with minimal variation between parts
  • 3D printing repeatability can vary depending on the technology and materials used
  • Industrial 3D printers are improving in consistency for production applications
While CNC machining remains the gold standard for precision in many applications, advancements in 3D printing technology are continuously narrowing the gap in accuracy while offering unique capabilities in terms of design freedom and material options. With precision and accuracy in mind, let's explore the cost factors associated with these manufacturing methods.
Cost factors - comparing 3D printing and CNC machining
Several key cost considerations come into play when evaluating 3D printing versus CNC machining:
Initial investment
  • CNC machines typically require a higher upfront investment, with industrial-grade machines costing hundreds of thousands of dollars
  • 3D printers have a lower barrier to entry, with desktop models available for a few hundred dollars and industrial printers ranging from $5,000 to $500,000
Material costs
  • CNC machining often results in more material waste, as it cuts away excess material
  • 3D printing uses material more efficiently, only depositing what is needed for the part
  • However, specialized 3D printing materials can be more expensive per kilogram than bulk materials used in CNC
Labor and operating costs
  • CNC machining requires skilled operators, increasing labor costs
  • 3D printing can often run with minimal supervision, reducing labor expenses
  • CNC machines consume more power during operation compared to most 3D printers
Production volume
The cost-effectiveness of each method varies based on production quantity:
  • For low volumes (1-10 parts), 3D printing is often more economical
  • As volume increases (10-100 parts), CNC becomes more competitive
  • For high volumes (100+ parts), CNC machining or other traditional manufacturing methods are typically more cost-effective
Part complexity
The geometry of the part impacts costs differently for each method:
  • Complex geometries increase CNC machining costs due to additional setups and tool changes
  • 3D printing costs remain relatively stable regardless of part complexity
  • For intricate designs, 3D printing can be more cost-effective even at higher volumes
Post-processing
  • CNC machined parts often require less post-processing to achieve desired surface finish
  • 3D printed parts may need additional finishing steps, adding to overall costs
Design iteration costs
  • 3D printing allows for rapid and cost-effective design changes
  • Modifying CNC machined parts can be more expensive, requiring new programming and tooling
When deciding between these technologies, carefully consider these cost factors in relation to your specific project requirements, production volume, and part complexity to determine the most cost-effective manufacturing method. With cost considerations in mind, let's examine how these technologies compare in terms of production speed and scalability.
Production speed and scalability
Production speed and scalability are crucial factors when comparing 3D printing and CNC machining:
Production speed
  • CNC machining is generally faster for producing larger quantities of parts, especially those with simpler geometries
  • 3D printing excels at rapid prototyping and producing small batches quickly
  • For CNC, production speed depends on part complexity and material hardness
  • 3D printing speed is primarily determined by part size and layer thickness
Scalability
  • CNC machining scales well for medium to high volume production runs
  • 3D printing is ideal for low to medium volume production and customized parts
  • As production volume increases, CNC becomes more cost-effective per unit
  • 3D printing costs remain relatively constant regardless of quantity
Setup and changeover time
  • CNC requires more initial setup time for programming and fixturing
  • 3D printing has minimal setup requirements beyond loading the design file
  • Changing designs is faster with 3D printing, requiring only a new digital file
  • CNC may need retooling and reprogramming for design changes
Production capacity
  • CNC machines can run continuously with minimal supervision
  • 3D printers are limited by build volume and print time per part
  • Multiple CNC machines can be operated by a single technician
  • Scaling 3D printing often requires additional printers and operators
When deciding between these technologies for production, consider your volume requirements, part complexity, and potential design iterations. For high-volume, consistent production, CNC machining often provides better scalability. However, for lower volumes, complex geometries, or frequent design changes, 3D printing offers greater flexibility and faster turnaround times. 3D printing outshines CNC in three key areas: fast turnaround time for low quantities, shorter manufacturing workflows, and easier design iterations. With these production considerations in mind, let's address a common question about the relationship between 3D printers and CNC machines.
Is a 3D printer a CNC machine?
While both 3D printers and CNC machines are computer-controlled manufacturing devices, they operate on fundamentally different principles. 3D printing is an additive manufacturing process that builds objects layer by layer, while CNC machining is a subtractive process that cuts away material from a solid block.
Key differences between these technologies include:
  • Manufacturing approach: 3D printers add material, CNC machines remove it
  • Geometric capabilities: 3D printing excels at complex shapes, CNC has some limitations
  • Material options: CNC works with a wider range of materials
While 3D printers use computer numerical control in their operation, they are not typically classified as CNC machines. The term "CNC machine" usually refers specifically to subtractive manufacturing devices like mills, lathes, and routers.
However, both technologies have their strengths in digital manufacturing:
  • 3D printing is ideal for rapid prototyping, custom parts, and complex geometries
  • CNC machining excels at precision, repeatability, and working with a variety of materials
When deciding between these technologies, consider factors such as part complexity, material requirements, production volume, and desired accuracy. In many cases, the two technologies can be complementary, with each suited for different stages of the product development and manufacturing process.
If you are looking to print a wide variety of filaments with precision and speed, UltiMaker's new S8 printer might be the solution for you. Powered by the new UltiMaker Cheetah motion planner, you get up to 4x productivity making it the fastest dual material 3D printer made in Europe.
Discover the new S8
Explore S8
