mei 15, 2025Welcome back to our application spotlight series, where we explore how UltiMaker 3D printing technology powers smart solutions across industries. From speeding up production to cutting costs, each story shows how additive manufacturing is changing the way companies operate.
This week, we’re heading to sunny Seville to see how the Heineken brewery optimized its packaging line with a simple but effective 3D printed solution: the conveyor wedge.
In high-speed packaging environments, even small guiding components play a crucial role. A conveyor wedge is an element mounted alongside a conveyor belt. Its job? To align, stabilize, or divert products as they move through the system, without gripping or touching them actively.
For Heineken’s Seville brewery, ensuring smooth transitions and proper product orientation was key, especially in tightly spaced conveyor layouts. But sourcing custom components like these through traditional manufacturing was costly and time-consuming.
By turning to 3D printing with UltiMaker’s Nylon CF Slide, the brewery was able to produce a durable, low-friction wedge in-house, tailored exactly to the line’s specifications. The part’s wear-resistant surface and mechanical strength made it ideal for continuous operation. With dual extrusion, it is even possible to create a "wear indicator" for when the part is wearing out to a critical stage and prepare for replacement in time.
Switching to 3D printing brought dramatic efficiency gains:
The wedge’s printed geometry was optimized for performance on the packaging line, guiding bottles with minimal friction and no need for complex assembly. Using Nylon CF Slide also meant fewer supports, easier post-processing, and strong layer adhesion—ideal for both performance and production speed.
This application highlights how additive manufacturing isn’t just for complex or flashy components. Conveyor wedges can be made in various types and sizes, in some cases in geometries that are not possible with conventional methods.
These parts can deliver real operational value when they’re precisely designed, quickly produced, and built to last. For Heineken, the result is a faster, leaner, and more responsive packaging line.
Discover how UltiMaker’s professional 3D printing solutions can help you cut lead times, reduce costs, and keep operations running smoothly - no matter your industry.
