25 mei 2023This application concept was designed by application engineers at UltiMaker to showcase one of the many possible ways that metal FFF technology can improve existing processes.
End of arm tooling (EOAT) is a crucial aspect of robotic technology. It refers to the equipment that interacts with parts and components, typically at the end of a robotic arm. Transport tools are applications that are directly involved in interacting with transporting procedures across the production line.
This end-of-arm transport tool with a vacuum gripper is used to pick-and-place products through various processes with its vacuum-powered suction cups.
This concept part was designed to print easily without requiring supports, which speeds up print time.
It was originally printed using a polymer-based material. It was updated for metal printing by reorienting it so that the inlet arms face downward. A rib was also added for support to give it strength and prevent distortion during the debinding and sintering process. National Pipe Threads (NPT) were also added and a tap was used on the final sintered part so that common off-the-shelf parts could be screwed in and the application could go right into service in the factory.
| 7 hours 31 minutes | 219 g | $32.50 |
After rethinking the part and optimizing its design, this EOAT is now more durable while remaining easy to print in stainless steel on UltiMaker printers. Machining it using traditional metal manufacturing techniques would be far more costly.
Meet the Metal Expansion Kit
